fla-gypsy
North Florida
Run fast!
ScottG
Bothell Wa.
Aaackkk!
Scott, Grace and Wesly
H0NDA eu2000i
skipnchar
Topeka or somewhere else
Looks like a leaking clearance light to me. It may or may NOT still be leaking but it probably has at some point and no telling if the inside is damaged or not.
dodge guy
Bartlett IL
Even the window cover looks delaminated!
Wife Kim
Son Brandon 11yrs
Daughter Marissa 10yrs
Dog Shadow
07 Cherokee 32B
02 Excursion 4X4 V-10 4.30 gear 5Star tuner Y-pipe mod Hellwig sway bar
Reese HP dualcam Prodigy brake controller
A bad day of camping is
geo11RT
Missouri
definitely glad I posted. I will be passing on this one. I dont need another project. Thanks everyone!
Downwindtracker2
BC
From a leason learned the hard way. Polyester resin(fiberglass) doesn't stick to wet wood. If it was a boat,I would think about injecting epoxy resin in the voids. Check out West epoxy on how to,then use "Cold Cure"
Adventure before dementia
Timothy
Wisconsin
I doubt if the front wall is laminated construction. It looks more like bad workmanship or if it is laminated bad glue? If you look at the front window cover it has the same issue. If you can see any signs of water damage on the inside I would definatley pass.
Tim & Cindy
2010 Canyon Trail 35FLFT
2001 Chevy Silverado 2500HD Crew Cab
8.1 Allison
www.gsowners.com
WandaLust2
TN
Fun Finder? It looks more like a Money Pit to me. Pass it and look further....
WandaLust. Retired. Middle TN
Heartland 2011 NorthTrail 28BRS
1993 Ford Dutchman Class-C
thib2722
Eunice, LA
That's delamination, and it's caused by a leak some place. I bet if you opened that up, you'd have lots of rot and mold. If you're interested in saving some real money, use that as a negotiator. Be sure to contact an RV dealer to find out how much that will cost to replace. A friend of ours had a similar problem, and it cost him several thousand to have the front cap replaced and the roof recovered.
bingford
Utah
Hi,
Couple of things worth noting.
Sidewall and front/back construction are different.
Sidewalls start out as big, flat, laminated sheets that are cut to the required dimensions.
Front and rear are many times "built up" during assembly, that is how they get the curved surface.
As for value. aquistion cost vs. total investment vs. residual value.
take it a shop for repair and you'll be upside down fast.
Buy it dirt cheap. If you are handy and can glue it, screw it, and patch it, then you might get years of enjoyment for very little $.
As referenced in an earlier post, Injectible epoxy is avaialable through Composet Products at
www.delamrepair.com.
