RV.Net Open Roads Forum: Class A Motorhomes: refrigerator
 > refrigerator
saaboo
calif
Posted: 05/03/12 06:33am Link  |  Print  |  Notify Moderator
Went into mh today to find the one side of freezer with ice maker in it full of water,never had this problem before?
hottubkid
SCHAUMBURG,IL
Posted: 05/03/12 06:36am Link  |  Print  |  Notify Moderator
Broken water line???
hottubkid60193@yahoo.com
2004 SOUTHWIND 36E Tow 2003 CRV
zip0
NY
Posted: 05/03/12 06:55am Link  |  Print  |  Notify Moderator
Bad valve on ice maker?
" A day without camping is....WORK"
2003 Bounder 35R
3 Jack Russell's
docj
Fulltime--Home is where we park it
Posted: 05/03/12 09:21am Link  |  Print  |  Notify Moderator
We had this happen once. It turned out to be due to the ice maker water valve having frozen in the open position, or something equivalent. All we did was clean up the mess and defrost the unit. It worked fine afterwards.
Sandie & Joel
2000 40' Beaver Patriot Thunder Princeton--425 HP/1550 ft-lbs CAT C-12
2014 Honda CR-V AWD EX-L with ReadyBrute tow bar/braking system
WiFiRanger Ambassador/RVParkReviews administrator
Follow our adventures on Facebook at Weiss Travels
tahiti16
Camarillo, CA
Posted: 05/03/12 12:44pm Link  |  Print  |  Notify Moderator
If the fridge is off one possibility is the ice maker was full when turned off and the water never froze and splashed out.
We always turn the water off to the icemaker the last night before going home, when even use the icemaker, and that will allow it to run and mostly empty the tray so not much to wipe out later.
Ray, Cheryl & of course Miss Molly the four-legged child
2006 Dolphin 36' F53 V10 5 speed auto 2 slides 7.5 KW genset
 > refrigerator
