RV.Net Open Roads Forum: Tech Issues: Fifth Wheel Landing gear motor.
 > Fifth Wheel Landing gear motor.
scotthas
Redcliff, Alberta
Posted: 05/04/12 02:52pm Link  |  Print  |  Notify Moderator
Ok... we have arrived at our destination and while setting up the motor for the landing jacks blew the fuse in it 4 times trying to get set up. I had to end up using the crack (sp crank) to finish. Is this my motor going or is it because it is a little loose. (it has always been) It works for lowering but raising it gets to a point and it blows the fuse. Can I put in a heavier fuse or jump it if the motor is bad until I get a new one and be careful until we get home from our weekend.
Anyone out there have this problem?
Thanks, Will check back.
P.S. We are not that close to anywhere to get parts.
* This post was edited 05/04/12 04:41pm by scotthas *
Happy campers
2011 FORD Lariat 350 Super Duty
2013 Forest River Sandpiper 365SAQ
donn0128
Pronounced Ore-gun
Posted: 05/04/12 03:01pm Link  |  Print  |  Notify Moderator
Without testing I would suspect first a loose connection and second a bad motor, and third overloading the motor. What brand of landing gear?
Donn,Lorri,Max (The Rescued Lab)
Resident Know It All
SuperDutyFiver
Long Valley, NJ, USA
Posted: 05/04/12 03:17pm Link  |  Print  |  Notify Moderator
Single motor setups stink...but yes, jumping or a slightly larger fuse only used for a short duration to get the trailer moved should be ok.
Anyhow-barring uneven distribution of weight(meaning one leg is taking more than the other) all of the electrical connections are important-there seem to be a lot in the jack setup(inluding a key and a few switches sometimes)
Do you keep the truck plugged in and the engine running(both of which will help keep the voltage at peak) when operating the jacks? Also-making sure that the trailer battery is not run down will help too.
1 PSD 4x4 Custom Tow Vehicle-the 550
1 PSD 4x4 SUV-the X
2 PSD 4x4 Duellies-F350&F250HD
36' Carriage Carri-Lite
32' Open Triaxle Dovetail
22' Gooseneck Dump
E450 PSD 4x2 Chassis Cab
E550 PSD 4x2 Cube Van-The Beast
RIP-Prowler 345Y LSI-THANKS SUPERSTORM SANDY...
pdogg
Phoenix AZ
Posted: 05/04/12 04:16pm Link  |  Print  |  Notify Moderator
scotthas wrote:
I had to end up using the crack to finish. Is
It's a tough day when you need to hit the crack...
scotthas
Redcliff, Alberta
Posted: 05/04/12 04:41pm Link  |  Print  |  Notify Moderator
It was a little frustrating!!! That darn crack (crank) was frigin hard to do!!! Thanks for SP note, I will change it!
scotthas
Redcliff, Alberta
Posted: 05/04/12 04:46pm Link  |  Print  |  Notify Moderator
Thanks I think that is what I might do if I need to. I have everything leveled up and even plug into shore power. I the site we have it high front to back and it just seemed to labor a lot harder then I have heard it and it just stopped. Found it popped the 30 amp fuse and it blew every time going up. Down was OK. I have a feeling it is the motor...
Thanks for the input on the heaver fuse or jumping.
kedanie
Albuquerque, NM
Posted: 05/04/12 06:19pm Link  |  Print  |  Notify Moderator
I had a similar problem with the 5er we sold to buy our MH. Started out blowing the fuses. Then I installed a circuit breaker. Started popping the breaker. Finally, the right side leg broke internally and the left worked perfectly. Changed out the whole system to a dual motor set of legs and all was well. Dual motor setups allow independent leg operation as well as both at the same time. It also doubled the capacity as each leg was rated for 6,000 pounds. Made leveling the front a breeze.
Keith
Keith, Gloria & Charlie(Spoiled Rotten Boston Terrier)
2010 Damon Astoria 3470
2012 Jeep Grand Cherokee Overland
USAF 1968-1976 Viet Nam Veteran
BFL13
Victoria, BC
Posted: 05/04/12 07:39pm Link  |  Print  |  Notify Moderator
If you need to lower the front to get level, you need to move the truck out of the way. So if you want to leave the truck plugged in and the engine on, you would have to park the truck close enough (if possible at that location) and reconnect the 7-pin.
2003 Chev 2500HD Gas, 2003 Komfort 26FS 5er
See Profile for Equipment List
#1Flyboy
California
Posted: 05/04/12 08:28pm Link  |  Print  |  Notify Moderator
. . .I went to a dual motor / dual switch landing gear setup last month & could not be any happier with ease of setup & improved speed of motors doing 1/2 less work each. . .GOOD investment & shoud be standard equipment. . .
oklahomamike
oklahoma
Posted: 05/04/12 08:35pm Link  |  Print  |  Notify Moderator
Could be low voltage.
Volts/amps=watts
so if your motor uses 120 watts that is 10 amps at 12 volts
at 9 volts it would pull over 13 amps so if you have a 10 amp fuse it would blow.
