RV.Net Open Roads Forum: Tech Issues: Small Solar for Storage Battery Maintenance
 > Small Solar for Storage Battery Maintenance
CA Traveler
The Western States
Posted: 05/14/12 09:44am Link  |  Print  |  Notify Moderator
My son wants to install a small solar system to maintain the 2 12V marine batteries in storage in Sacramento with above average sun. A 100W 12V panel seems right at $130.
But what controller? The Morningstar SS6L at $48 will do the job, but he would like one with a meter and the only Morningstar I see is the Duo at $146.
I'm thinking a HF DVM mounted next to the controller will give him easy ability to check the battery voltage and would meet his desire for a meter.
Suggestions/comments appreciated.
2009 Holiday Rambler 42 Scepter with ISL 400 Cummins
2004 Honda CR-V
Bob
BFL13
Victoria, BC
Posted: 05/14/12 10:37am Link  |  Print  |  Notify Moderator
Great price for a 100w panel.
A 10 amp controller would allow for times when the solar is exceeding its rating by 1.25 as they recommend, or even more to allow for cloud effect. But that all depends on how the controller acts when met by higher amps.
My 16a just lets the amps through to the battery. I have seen 19a. If it stayed there very long the controller would warm up. So it's all a matter of degree.
You are right about the metering. The most important meter is the hydrometer, followed by the voltmeter. The controller does not need any read-outs.
2003 Chev 2500HD Gas, 2003 Komfort 26FS 5er
See Profile for Equipment List
smkettner
Posted: 05/14/12 10:40am Link  |  Print  |  Notify Moderator
I understand it may seem like a $100 voltmeter, more to install etc. And if my son was interested in electrics, batteries and solar I would get the DUO for $146 in a heartbeat. For just myself I would only get the $48 controller.
675 watts solar
2oldman
Winchester WA
Posted: 05/14/12 10:50am Link  |  Print  |  Notify Moderator
How long will these batts be sitting?
CA Traveler
The Western States
Posted: 05/14/12 11:06am Link  |  Print  |  Notify Moderator
I'll ask but my guess is 10+ months/year.
pianotuna
Regina, SK, Canada
Posted: 05/14/12 11:24am Link  |  Print  |  Notify Moderator
Hi,
Since it is for storage only he could go smaller--but there would not be many savings to be had and what you suggested will be excellent. If he wants a voltmeter how about a Walmart one that reads xx.xx volts? They are about $15.00
Regards, Don
Kustom Koach Class C 28'5" 256 watts Unisolar, 875 amp hours in two battery banks 12 volt batteries, 2500 MSW watt inverter.
2oldman
Winchester WA
Posted: 05/14/12 04:09pm Link  |  Print  |  Notify Moderator
I guess if there are parasitic loads which remain connected then this plan is ok. If not, simply disconnecting one battery terminal would be fine. That said, if this storage area reached temps of 90* or above for any length of time, the solar would be better. Heat is nasty on batteries.
I'm not sure why a VOM is necessary, unless you want to see if either the panels or the batteries have failed.
Ramblin' Ralph
Central California Coast
Posted: 05/15/12 09:38am Link  |  Print  |  Notify Moderator
I've had a 1/2 amp panel keeping 2 marine batteries fully charged on my boat for 20 years (same panel, different batteries). I live in SoCal.
Ralph
2006 GMC 2500HD, XCab, SB, 6.0L w/2001 Lance 845
Firestone Air Bags, 125 watt solar
My RV Travels Webpage and Campsite Map
CA Traveler
The Western States
Posted: 05/16/12 12:37pm Link  |  Print  |  Notify Moderator
The estimated wire run is 27' or 54' of 10ga wire for a 1.9% drop panel to battery.
I suggested using a combiner box with a loop of slack wire to add a second future panel if desired. This would increase the wire drop to 3.5%. Since these are 12V panels and PWM controller I thought that would be acceptable.
The initial emphasis is for storage but with the possibility of expanding in the future. So part of the evolving plan is for learning. An existing voltmeter helps in that direction. A larger initial CC is also a possibility. The storage area is in Sacramento which is very warm during the summer.
michelb
Ottawa, ON, Canada
Posted: 05/17/12 05:07am Link  |  Print  |  Notify Moderator
FWIW, if all he wants to do is maintain the battery, 100W is way more than he needs. Our 5W panel keeps our 4 batteries fresh in storage for several months in a row.
