traveltrailergirl
Seattle, WA
Hi all...
Was just hookin up my trailer to my truck and kinda damaged a post on my 12v battery...do I need the batery hooked up to tow...can I tow the trailer to a battery store to replace the post? Dang!!
Thanks for any help!
JaredWPhillips
Henryville, IN
No, you don't have to have the trailer battery installed to tow. The trailer lights will work from the truck.
TV: 2001 Chevy Silverado 1500 ext cab 4x4 5.3 V8. GoodYear Wrangler Authority E-Rated tires, FireStone AirBags.
TT: 2004 Gulfstream Amerilite 21MB
montanacamping
Montana
My trailer brakes do not work if I do not have a battery hooked up also you will not have a break a way brake.
2009 Jayflight G2
2005 Z71 Burb
2002 GMC 8.1 crewcab
F1bNorm
Gardena, CA
You should be OK to tow. The only function would be to power the break away brakes. Make sure the cables are not shorting out, this would not be good for the tow car.
Norm
F1BNorm
spike99
North America
NO 12V battery in the TT means NO 12V power on its emergency Break Away switch. If TT becomes unhooked, it will continue to slide down the road, and create much more damage. Legally (and insurance) speaking, if RV was factory built with 12V emergency break away switch, it must work (on public roads). If my RV dealer (to get the problem fixed) was on flat roads only 1 mile down the slow speed road, I'd tow with no emergency break away system. But, I'd never tow it on fast higways or more than walking distance... Your call!
edited 05/17/12 08:21pm by spike99 *
Gau 8
United States
F1bNorm wrote: You should be OK to tow. The only function would be to power the break away brakes. Make sure the cables are not shorting out, this would not be good for the tow car.
Norm
We don't need no stinking breakaway brakes!
beemerphile1
I'm 57, I'm not a
Like said, the emergency breakaway system requires a battery. If your trailer is heavy enough to require brakes in your state it would be illegal to tow without the battery making the breakaway system nonfunctional.
- Soren Kierkegaard
kaydeejay
SE Michigan, USA
As others have said, you don't need it until you REALLY NEED IT (when the trailer breaks away), but then it's too late!
Why not just take the battery to be repaired, or just replace it?
Keith J.
1999 Sunnybrook 27RKFS Fiver.
2005 GMC Sierra 2500HD CC/SB/DA 2WD, LBZ air cleaner, 52 gal Titan tank, Bilsteins, Line-X, Westin steps, Prodigy, Retrax cover, 16K Superglide, 5th-Airborne pin-box, Multi-vex mirrors, TST TPMS.
kaydeejay
SE Michigan, USA
montanacamping wrote: My trailer brakes do not work if I do not have a battery hooked up also you will not have a break a way brake. Not correct! Trailer brakes work from the truck under normal circumstances, but need the trailer battery in the unlikely event of a break-away.
full_mosey
Oklahoma
traveltrailergirl wrote: Hi all...
If your battery is damaged to the extent that it needs replacing, why don't you simply remove the battery and put it in the back of your truck and drive to the store?
HTH;
John
