L2C
Placentia ca
Can I spray water in all the compartments and under carriage, especially behind the sewage hook up? Will I have electrical problems if I do?
wny_pat
Western NYS
L2C wrote: Can I spray water in all the compartments and under carriage, especially behind the sewage hook up? Will I have electrical problems if I do? Why would you want to spray water in your compartments? How is it going to get out? Electrical problems would depend on whether or not the electrical connections are exposed to the water.
L2C
Placentia ca
There was a rat down there and I can see the droppings behind the city water and sewage hook ups but can't get to it. Wanted to
Clean it out
DeWat
United States
I can't speak to other compartments, but the very few coaches that I have seen have drainage plugs in the sewage compartment. When cleaning the compartment, I've opened the plugs and sprayed away from any controls. My own Thor gasser has a hard plastic lined compartment, the typical stinky slinky screw plug at one end and a small screw plug at the other end. Never had any problems keeping it clean with spray water. Again, I don't know about the other compartments.
2013 Winnebago Vista 35B
crimmps49
Wisconsin
Our compartment by the sewage controls has a plug in it, so hubby sprayed it clean and let it dry and replaced the plug. You could always use a shop vac to clean it out.
rexabbot
Cumming GA
How about trying a yard blower and blower out the droppings?
kitch251
Aiken, SC
For mice:
Go to Tractor & Trailer and buy "Tom Cat" mice destroyers. They are the very best thing since sliced bread! They do work.
Jim
downtheroad
Pacific Northwest
Get a "Lint Lizard," and vacuum them out...LINT LIZARD...HERE
GMC Duramax LBZ
Komfort
Reese Dual Cam HP
Our Rig Picture...CLICK HERE
Robert78121
San Francisco Bay Area
I routinely wash out the compartment that contains my sewage connections. There's a drain plug in there, and I assume it's for that reason. I've never had a problem in the nearly 9 years I've owned the coach.
Living full-time in the San Francisco Bay Area
Camper: 2004 Damon Daybreak 3285 WorkHorse 8.1
Toad: 2010 Mini Cooper Clubman S - BlueOx
Toy: 2012 Ninja 650 - Versa Haul VH-SPORT-RO
