Im curious if anyone else has this issue, as im getting tired of purchasing the retaining clips. i have the standard reese anti sway with the two ball cups on each end, held in place by the wire tension clips. the problem is, whenever i take a sharp turn, i will later discover the clip is gone (im amazed that the cup is still on the ball), or severely mangled by contact with some part of the trailer tongue or hitch. the clip can go in three different ways. is there a best way? or has someone figured a better clip system that is avail.
