RV.Net Open Roads Forum: Class A Motorhomes: Motorhome Fire kills 3
 > Motorhome Fire kills 3
Page of 5
Capt. Jack
Tucson, AZ
Posted: 05/22/12 09:24pm Link  |  Print  |  Notify Moderator
Bad news
Jack Foster
Country Coach Allure 40'
Dynomax Chassis Cummins 8.3, 325hp New Custom Paint
2003 Subaru Forester & 2007 Saturn Vue V6 AWD Toads
Dune Hauler
Cornell, California
Posted: 05/22/12 09:39pm Link  |  Print  |  Notify Moderator
Wow, what a tragedy I wonder if they were afraid to climb out the rear escape. Or worse if there even was one or it was blocked. God Bless.
The Dune Box
More To See
San Diego Area
Posted: 05/22/12 10:04pm Link  |  Print  |  Notify Moderator
Sad news. But over and over again this keeps happening. Somehow motor homes seem to trap people inside or they go up so fast you exit them in critical condition. Maybe in accidents those frames twist to jamb exit windows shut. Maybe in some situations the body cavities fill with propane to produce a flash fire impossible to escape. It might be wise for all us to have planned a very rapid exit from the rig with even the slightest possibility of a fire. Not that it would have helped these people obviously.
95 Winnebago Vectra 34 (P30/454)
sdianel
Tampa, FL
Posted: 05/22/12 10:05pm Link  |  Print  |  Notify Moderator
this just reminded us to check our fire extinguisher date and make sure our escape window is clear. I tend to stack pillows on the bed in front of that window. Anyone attend the fire safety seminars at FMCA? I might go to one at the next rally we attend.
Lonny & Diane
2004 Country Coach Allure 33' "Big Blue"
Towing 2008 Chev Colorado 4x4
Semper Fi
Francesca Knowles
Port Hadlock, Washington
Posted: 05/22/12 10:11pm Link  |  Print  |  Notify Moderator
That's the second front tire blowout- caused MH accident in a week...check your tires, folks!
" Not every mind that wanders is lost. " With apologies to J.R.R. Tolkien
ArcticDodge
Sammamish, WA
Posted: 05/23/12 12:16am Link  |  Print  |  Notify Moderator
This is the second tire blowout accident in the past few days that resulted in death. Very sad indeed. The cause of death was clear on the earlier accident (impact). This one has me asking a few questions of curiosity.
How did the tire blow out lead to a fire?
Was there an impact that occurred after the blowout?
Did the right front tire disable the door?
Did the emergency window not work?
Any other windows large enough to get out?
Not looking for blame here. Just wondering about the cause of the fire beyond the tire blowout and solutions to survive such an incident.
2009 Komfort 256TS
2001 Dodge Ram 3500 QC 4x4 Cummins DRW
2005 Dodge Durango Limited AWD HEMI
2001 Sebring Convertible
1995 Miata M-Edition
2005 DRZ400
1 Wife 2 Boys UW & Bellevue College
1 Trixie (Bichon Frise)
Only 23 years to retirement!!!!
WyoTraveler
Northwest, Wyoming
Posted: 05/23/12 07:37am Link  |  Print  |  Notify Moderator
I had a left rear blow out on my PU while towing my 5Ver on the freeway through Sacramento, CA. Turns out the reason for the blow out was the dealer that installed the new tires installed auto valve stems. The stem blew, the tire lost air and due to the weight of the 5Ver being towed immediately caught fire. The fire burned the tire off the rim before I could even get stopped and get my fire extinguisher out. Fortunately I was in a diesel fueled vehicle since it was on the filler neck side and in the rear. The rim stayed so hot you couldn't touch it and it melted a hole about 6 inches deep into the asphalt. It is not unusual for heavy vehicles to have the tires catch fire when they blow out.
2013 Monaco Monarch motorhome
2012 Jeep Wrangler toad
AC6CV/7 ex-W8RUR since 1954
supercub
Modesto CA
Posted: 05/23/12 08:00am Link  |  Print  |  Notify Moderator
Something I do before each trip is I open my emergency exit windows and make sure they haven't glued themselves shut. ...........WHY?? Because after a time the rubber seal around the window becomes sticky and litterly glues the window closed. If this happens it can take time and some extra force to get it open. To make sure this isn't the case I just open mine to make sure they haven't "glued" themselves closed and will open freely. If it's been awhile since you've opened yours, try it, and you'll see what I mean. Be Safe
Brian
MustangGT
Athens, Alabama
Posted: 05/23/12 08:27am Link  |  Print  |  Notify Moderator
those poor folks. Escape was only a window away.
I consider it the owner's responsibilty to educate their passengers, so I make it a point to show and explain the rear window exit to everyonoe who rides or sleeps in our RV. When tested,the two red handles worked easily, but when I tried to open it the rubber seal had indeed glued the window shut! Tight! It took 3 good hard pushes to gradually peel it open. I thought I was gonna bend the frame or break the glass.
I need to coat that seal with some silicone spray or something...thanks for the reminder.
Now that I am thinking...the "regular looking" sofa window in our RV has a red latch. Does anyone know; does that window have a special frame or hinge to open when pushed? what makes it an escape window? Just because its big?
Mark, Jean, Paul & Lizzy (the mutt)
1997 Fleetwood Southwind Storm 34LS
Thirsty, noisy & clunky. She ain't pretty, but she sure is fun!
"Aerodynamics are for people who can't build engines." Enzo Ferrari
RV-1/2n-FUN
FL.
Posted: 05/23/12 08:33am Link  |  Print  |  Notify Moderator
When was the last time any of you 60, 70 year old RVers tried to exit your emergency window as a practice escape? Not so easy!
Making sure the window is not stuck closed is a good idea.
Page of 5
