RV.Net Open Roads Forum: Hybrid Travel Trailers: Awning
kzescape18rbt
Michigan
Posted: 05/23/12 07:35pm Link  |  Quote  |  Print  |  Notify Moderator
Okay I did a big oops today I think I was washing and wiping down the awning and pole supports The black know with the screw on the underside that tightens the top awning bar came out. I tried to screw it back in. There was nothing there to screw it into to what am I missing ?
BarneyS
S.E. Lower Michigan
Posted: 05/23/12 07:46pm Link  |  Quote  |  Print  |  Notify Moderator
If I remember correctly, there is a track that a nut fits into. It probably just slid out of sight. Go fishing for it.
Barney
Hensley "Arrow" 1400# hitch
2002 Ford F250 Super Duty, 7.3L PSD
Visit our website here
jetcare
RV Repairman - South Fork, CO in the summer
Posted: 05/23/12 09:01pm Link  |  Quote  |  Print  |  Notify Moderator
Yes, there is a floating nut in there. You just need to figure out where it went. This happens all the time so don't worry.
2007 Coachman 32 foot Travel Trailer
2010 Ford F350 Super Duty 4X2, SRW, 6.4L
brirene
midwest
Posted: 05/23/12 09:42pm Link  |  Quote  |  Print  |  Notify Moderator
You may be able to get a finger on it where it probably slid to the bottom. Mine has a slot and I was able to slide it back up with a finger and hold it in place until you can get the screw started. A little bit of a pain, but certainly doable. Good luck!
'04 Jayco Designer 30 RKS Medallion pkg, Trail Air pin
'05 F350 6.0 PSD CC Lariat 4x4 DRW 4.10 LB B&W Companion Edge Insight CTS
“The trail is the thing, not the end of the trail. Travel too fast, and you miss all you are traveling for.”
-Louis L'Amour
smdallas
Chatham, NY
Posted: 05/23/12 10:02pm Link  |  Quote  |  Print  |  Notify Moderator
Find the nut and use needle nose pliers. Mine had pain old steel nuts on it and it was a real pain so I bought the normal plastic knobs and what fun it was to find the nut and get the knob started.good luck
joeprinter
Fayetteville, NC
Posted: 05/24/12 06:24am Link  |  Quote  |  Print  |  Notify Moderator
Ive done the same the nut is at the bottom, most likely, once found I used a screw driver to hold it in place while tightening on the outside.
"2012 Forest River 360 DS"
"Ford V-10"
"2013 Toyota Corolla on Tow Dolly"
