RV.Net Open Roads Forum: Fifth-Wheels: Here we go again......UPDATE
 > Here we go again......UPDATE
Page of 5
bstark
Ontario, Canada
Posted: 06/04/12 08:16am Link  |  Print  |  Notify Moderator
An illustration of how this 50 amp 230/240v wiring works is to consider those of you with 50 amp rigs who have been confronted by a power pedestal containing only a 30amp outlet and alongside it a 20 amp outlet.
You have then been in the position of having to resort to running your rig with it's dual air cons, 1100 watt micro, washer/dryer on a vastly reduced supply of available amperage through one of those outlets.
Some of you will have undoubtedly mitigated this happenstance by purchasing one of those dual leg looms that serve to use BOTH the 30 amp AND the 20 amp outlets of the pedestal to supply a full 50 amp to your trailer up that 50 amp umbilical cord to your RV panel. This is done due to wiring codes requiring those two outlets be supplied by their own/separate breakers/fuses so that the loom you purchased can bond the neutrals, bond the grounds, supply the black line-in from the 30 amp outlet up the umbilical via the RED wire within the 50amp plug and supply the black line-in from the 20amp outlet in the pedestal up the black wire within the 50 amp umbilical, thereby giving you a full 50 amp supply from a power pedestal with no more than 30 and 20 amp outlets within.
Today is just the tomorrow you worried about yesterday!
Cummins12V98
on the road
Posted: 06/04/12 08:22am Link  |  Print  |  Notify Moderator
CAMP_MLMM wrote:
The biggest problem that you will run into with trying to run the AC on a 15Amp circuit from your house/garage is that you are only supplying it with 120VAC. A 30Amp circuit is 230VAC which is what is required to operate the A/C unit. Glad you are considering installing a 30Amp plug to hook up to, that will allow you to run the A/C no problem
UH???????
Your 30 amp RV outlets are 120v one hot one neutral one ground with 10 gague wire. To have 240v you need two hot wires one neutral and one ground like what you have on a 50 amp RV cord.
I run both AC units on 30 amp power by turning the WH and frig to gas. 2007 Mobile Suites.
2011 Ram Laramie Longhorn 3500 Dually Long Bed, Cummins 350/800 HO, Towin Machine
B&W Companion Hitch, Maghytec Trans and Rear Dif Covers, AMZ/OIL Top To Bottom
2007 1/2 Mobile Suites 36 SB3 27,000# Combined
Sandy & Shirley
North East, MD
Posted: 06/04/12 02:51pm Link  |  Print  |  Notify Moderator
CAMP_MLMM wrote:
webeopelas wrote:
You are also mistaken on the 50 amp units. Yes there are two legs of 110 VAC into the camper, but there are no appliances in the camper that use both legs to get 230 VAC.
Each appliance is wired to one leg of the 50 amp or the other, but never both.
Everything within the camper runs on 110 or 12V DC.
Yes, everything in the RV runs on 120V AC or 12V DC. and Yes it is for sure 2 legs of 120V AC that supplies the RV. I guess it is a matter of terminology, in the electrical industry that type of supply is referred to as a 230V AC circuit. So, no I am NOT Mistaken on the 50 Amp units, I just used different terminology than you used for it.
STOP ! NO ! DO NOT DO THIS ! ! ! ! !
30 amp IS NOT a 230 volt circuit. This is a big mistake that a lot of RVers make when they park their RV in the driveway. A 30-amp circuit for a clothes dryer is 30-amp 230 volts. It is also 3 wire, a ground and TWO HOT lines. A 30-amp circuit for your RV is 30-amp 110 volts. It has a ground, one neutral and ONE HOT line.
A lot of RVers try to plug into a clothes dryer line and fry half the electronics in the RVs.
A 50-amp line is 230, one ground, one neutral and two hot lines; but nothing in the rv is connected to both hot lines. Either hot line crossed to neutral is 110 volts, cross both hot line (nothing in the rv does this) and you get 230 v.
NEVER EVER use a 30-amp 230v line in ! ! ! ! !
'02 F350 7.3PSD CC LB DRW, Reese 20K Hitch, Brake Smart, AirLift, C-betr mirrors,
'04 Everest 343L, TrailAir, RotoChoks, Wayne's stabilizer
Toys: Fold-Away Pet Carrier, Thermos Grill 2 GO
For more info, visit Our RV web site.
RVER
West of Boston, MA
Posted: 06/08/12 08:06pm Link  |  Print  |  Notify Moderator
PUT a 30amp line and breaker NOT just a 30 amp breaker!!
Chevy Silverado 2500HD with Duramax engine and Allison transmission
2002 Sunnybrook 34BWTS with lots of goodies
Pullrite Superglide Hitch, Prodigy brake controller
S and S Co-Travelers and along for the ride is Ketzel the wonder cat.
LostinAZ
At Home
Posted: 06/09/12 12:00pm Link  |  Print  |  Notify Moderator
You will only get 230V if the two 50AMP 110V lines are out of phase.
wandering1
Posted: 06/09/12 12:07pm Link  |  Print  |  Notify Moderator
What kind of 5th wheel??
HR
wandering1
Posted: 06/09/12 12:10pm Link  |  Print  |  Notify Moderator
Get help from the dealer. There are a lot of wannnabe electricians that will give you bad information which can cause damage.
SolidAxleDurango
OK, USA
Posted: 06/09/12 03:55pm Link  |  Print  |  Notify Moderator
No it is not.
It is referred to as a 125/250v AC circuit. Two hots, neutral and a ground.
To call it a 250V (or your 230V) circuit indicates that it has no neutral. Two hots and a ground only.
TV = 07 Dodge Ram 3500 Dually 6.7 / QC-LB / CTD / G56 / 3.73 / 4wd / EBrake
5er = 12 Keystone Avalanche 330RE
Toys = 08 Kawasaki Brutie Force 650i 4x4 ( x2 )
sirdrakejr
Las Vegas, Nevada
Posted: 06/09/12 10:28pm Link  |  Print  |  Notify Moderator
I wired my parking space in CO for 30 amp service. I took ONE 30A breaker, #10 wire for the HOT, the GRD and the Neutral to feed the outlet. When I wanted to use the 50A service, it is TWO 50A breakers, TWO 110V HOT, ONE GRD and ONE Neutral to feed the 50A service.
Is is NOT a single 230V service rated for 50A. It IS two separate 110V 50A SINGLE services in one feed to the trailer. Use anything else and you fry the trailer.
If you have ANY doubts about the service and how it works, take the unit to a certified RV Electrician and have it inspected or have the work done there. Safety ALWAYS comes first!
Frank
Cummins12V98
on the road
Posted: 06/09/12 11:29pm Link  |  Print  |  Notify Moderator
Frank
Do you see two 50 amp breakers at the power pedistal in the parks? One 50 amp breaker is all that is required, it has two hot wires coming off of it and it is attached to two legs in the pannel.
My 50 amp service at my rv pad at home is wired exactly that way. If you want to use two 50 amp single breakers you can but you should tie them together so they both come on and off at the same time.
Page of 5
