Anybody know anything about a/c's? Mine has started staying on low
fan speed. I will turn down the thermostat plenty low enough, or when
it first comes on and its really hot,before, it would come on high fan speed right away. Sometimes, when it does not want to kick up to high,i will turn it off and wait a few minutes, then turn it back on and,sometimes it works, but more often its not. Just started
few weeks ago.
Any ideas?
thanks!
My A/C unit has either a low or high setting as far as speed. Temperature isn't a factor. If I am reading right, it sounds like your A/C adjusts fan speed for appropriate temps?
my a/c has two speeds if set temp is two degrees less than the temp in rv the hi speed shoud turn on but the hi speed is not kicking on so if it is hot out side it starts getting hot inside if i turn off the a/c and reset it the hi speed will come on thanks
