RV.Net Open Roads Forum: Dinghy Towing: Towing Fusion Hybrid
Search only in Dinghy Towing
Open Roads Forum  >  Dinghy Towing  >  Vehicles
 > Towing Fusion Hybrid
Navy Bob
Womelsdorf, PA
Posted: 06/04/12 06:31am Link  |  Quote  |  Print  |  Notify Moderator
Ford's recent announcement that 2012 Ford Fusions and Escapes are not towable does not say anything about the hybrid versions. The hybrids have an ECVT transmission where the normal Fusions and Escapes have automatic transmissions. The dealer where I bought says he checked with his sources at Ford and there is no problem for the hybrid. The only limitation is to not exceed 75 MPH.
Are there any other Ford hybrid owners out there? Have you heard or found anything different?
I am very pleased with my hybrid Fusion after 3,000 miles. In normal around town driving I am getting about 43 MPG and on a 650 mile Interstate trip in 95 degrees at 70 MPH I got 38.5 MPG. The all electronic dashboard (except for speedometer takes some getting used to. I had the Air Force One brake system installed by dealer along with Blue Ox baseplate, wiring kit with separate bulbs and the cost was $3,050.
Bob
2 vocal & energetic mini Schnauzers
2008 Holiday Rambler Endeavor 40PDQ
2012 Ford Fusion Hybrid Toad
DouglasC
Summerdale, AL
Posted: 06/04/12 09:19am Link  |  Quote  |  Print  |  Notify Moderator
As a previous owner of a Mercury Mariner Hybrid which I towed for over 30,000 miles, I can see no reason why the current prohibition in towing Escapes and Fusions built after 2/27/2012 with the 6 speed automatic would have anything to do with the hybrids.
As you have pointed out, the hybrid and non-hybrid vehicles use 2 entirely different transmisisons.
I am now happily towing my 2012 Focus with the DCT automatic. I've now towed it approx 2,500 miles with no issues whatsoever.
BTW: I drove a Fusion hybrid shortly after they were introduced and felt that it was an awesome vehicle - - and seriously considered buying one. But the "show stopper" was the fact that the rear seats did not fold down and I felt that it would seriously restrict my ability to haul stuff.
Doug
2006 Jayco Greyhawk Model 27DS
Towing 2012 Ford Fusion Hybrid with Brake Buddy
kyhawk
Villa Hills Ky
Posted: 06/04/12 09:23am Link  |  Quote  |  Print  |  Notify Moderator
We've been towing our Escape Hybrid since 08 for many miles with no problems so far. Good luck.
Janet & Ralph
2008 Winnebago Aspect 26A
2008 Ford Escape Hybrid
the_armadillo
SE Texas
Posted: 06/04/12 11:07am Link  |  Quote  |  Print  |  Notify Moderator
Can't say for the Fusion, but we tow a 2012 Escape Hybrid. As dealer said, no restrictions other than 75 mph. Great toad and DW loves it for her daily driver. We got a chipless key for use when towing for accessory position so no one can break in a steal the vehicle. We manually lock the doors so not to set the alarm. Also turn off display on Nav system when key in accessory position by pressing display button twice.
conmoto
Northern Illinois
Posted: 06/05/12 02:29pm Link  |  Quote  |  Print  |  Notify Moderator
I am setting up our 2011 FFH to tow and am finding this thread timely. I am going to use all Blue Ox equipment as the Patriot braking system is friendly with active braking.I did contact Ready Brake and the person returning my query was unsure if their system would work with a hybrid. All reports I get are positive on the Blue Ox set-up.
the_armadillo
SE Texas
Posted: 06/05/12 06:40pm Link  |  Quote  |  Print  |  Notify Moderator
Conmoto
We have all Blue Ox equipment with our Hybrid setup including the Patriot system. All has worked very well thus far. Just follow all the setup instructions for gain and changing the mode. The only complaint I have is that I hard-wired the Patriot remote to switched 12 volt power as opposed to using the cigarette plug in. The Patriot remote will beep the entire time when I'm driving the RV w/o the toad since it can't establish communication. Thus I need to install another power switch for the remote so I can shut if off when not needed. Wish Blue Ox had a power switch on the remote because I use my power ports for other items.
