Harleybullet
Holbrook, NY
I have a 2005 AF 1150 with one slide and was wondering if at night in the winter if you close the slide (therefore less volume and tighter) would there be a savings in LP fuel and possibly battery drain because you were heating a smaller volume. Any one keep any records on that... it seems you should save?
Dave
donn0128
Pronounced Ore-gun
Not enough to notice. But the RV will be a bit warmer.
Donn,Lorri,Max (The Rescued Lab)
Resident Know It All
harold1946
Surprise Arizona
I have not kept a record but I have done so and believe it would be a savings. Any time there is less volume to heat or cool there would be a savings.
Using the cubic feet of my slides it is an additonal 188 cu. ft. when they are extended.
Harold and Linda
2009 CT Coachworks siena 35V
W-22 Workhorse 8.1L
Explorer toad
mguay
Northern NH
I haven't kept a record.....but it does warm up alot faster!
Real Trucks wear Training Wheels!
kerry4951
East Central Pennsylvania
It has to save some....having the slide out in certainly makes a better tight seal with less cold air infiltration.
2009 Chevy Silverado 3500 dually D/A, Supersprings, Stable Loads, Bilstein Shocks, Hellwig Sway Bar, Front Timbrens.
2010 Arctic Fox 1140 DB, 220 watts solar, custom 4 in 1 "U" shaped dinette/couch, 59 interior and exterior mods to date and still adding
LadyRVer
Never tried it, but I would first check if the slide closes over any floor vents.
pigman1
Delaware
It's not just the smaller volume you're heating, it's also the heat loss. When you extend the slide you add surface area on the top, bottom and sides that all loose heat. Any windows in the slide ends make it worse as windows loose heat much faster than walls. Definitely use more energy in slide out condition, both in how much gas you use and how much power you use to run the blower(s).
John
Pigman & Piglady
2013 Tiffin Allegro Bus 43' QGP
2011 Chevy Silverado 1500
BlueOx Aventa LX Tow Bar
SMI Air Force One toad brake
Street Atlas USA Plus
joeprinter
Fayetteville, NC
you will save LP but probably not enough to make a difference.
"2012 Forest River 360 DS"
"Ford V-10"
"2013 Toyota Corolla on Tow Dolly"
KKELLER14K
BEAVERTON OREGON
Have an 1150 and can answer that real quick...If you use it year round you'll find out soon enough but the fact is this: The wiper seals, especially underneath the slide have a lot of air infiltration where the rails exit the TC. If you camp in a side wind in very cold temps you will notice right away. On extreme cold nights sealing the outside perimeter better utilizes the thickness of the exterior slide wall plus the fact your heating a smaller space. Sometimes if I can't get parked where the wind is not hitting the side with the slide out, I just throw some duct tape around the rails to seal them up better...Just a band aid but it better than nothing.
edited 06/04/12 07:50pm by KKELLER14K *
brirene
midwest
joeprinter wrote: you will save LP but probably not enough to make a difference.
That was my thought also, unless your seals are bad and not preventing most air infiltration and heat loss. Can't see it making a great deal of difference.
'04 Jayco Designer 30 RKS Medallion pkg, Trail Air pin
'05 F350 6.0 PSD CC Lariat 4x4 DRW 4.10 LB B&W Companion Edge Insight CTS
“The trail is the thing, not the end of the trail. Travel too fast, and you miss all you are traveling for.”
-Louis L'Amour
