RV.Net Open Roads Forum: Tow Vehicles: Doing a little PM recently **UPDATED** $$$
Search only in Tow Vehicles
 > Doing a little PM recently **UPDATED** $$$
Page of 7
ib516
Up here!
Posted: 06/04/12 06:38pm Link  |  Quote  |  Print  |  Notify Moderator
Truck in sig, 145,000 Km on the odometer (~90,000 miles).
A couple months ago, I did a drain and refill on the rear diff, and installed the PPE Alum cover Santa brought me. I refilled with AMSOIL 75w110 synthetic gear lube.
Then last week, I did a pan drop/filter change/refill on the 48RE auto transmission.
Yesterday, I was over at a friends place doing PM on his outdoor power equipment (Snow blower, lawn tractor, roto-tiller). We did an oil change/chassis lube on his Duramax as well, and installed the Fumoto valve I got him for Christmas. While I was greasy anyway, I greased the zerks on my truck, and noticed my muffler is starting to crack open at the bottom due to corrosion. Looks like a new exhaust system is going to be on the schedule soon. I think I'll just get a turbo back 4" system (with a muffler of course), but I might ditch the catalytic converter but I haven't fully decided on that yet.
Then, I noticed some "feathering" wear on the inside of my front tires. Might be time for a track bar or tie rod ends. I'll have to check into that. I did the ball joints (upper and lower, both sides) and had a wheel alignment at 98,000 Km (~60,000 miles), about 1.5 years ago.
Today, I drained and refilled the transfer case (I hadn't ever done it). 2 quarts of ATF+4 does the job.
Next up is a drain, flush, and refill of the cooling system. I'm doing that in my own garage too - with a garden hose. Going to change the upper and lower rad hoses while I'm at it ($45.00 for both).
After that, I'll probably service the front diff with the left over gear oil I have as I haven't ever serviced it either.
These things always cost, cost, cost don't they?
* This post was edited 06/18/12 03:15pm by ib516 *
2010 Cougar 322QBS 5er
2007 Dodge 3500 SRW Megacab, 4x4, 5.9L Cummins, 3.73, 48RE auto
HYPERTECH MAX ENERGY or DIABLO PREDATOR tuning
MBRP 4" Turbo back
Scangauge2 for Boost, Coolant temp, Rail press & Trans Temp
Torklift Stable Loads
BenK
SF BayArea
Posted: 06/04/12 08:11pm Link  |  Quote  |  Print  |  Notify Moderator
It would cost even more if you went to an independent mechanic and even more
if you went to the dealer
The most expensive is if you let it go and then had something fail...out in the
boonies...
-Ben Picture of my rig
ib516
Up here!
Posted: 06/04/12 08:22pm Link  |  Quote  |  Print  |  Notify Moderator
You're right....thanks Ben. I'll just keep thinking of the money I'm saving DIY That'll ease the pain
FishOnOne
Katy
Posted: 06/04/12 09:01pm Link  |  Quote  |  Print  |  Notify Moderator
Pay a little now or pay alot latter!
RollingRockTX
Keller, Texas
Posted: 06/04/12 09:23pm Link  |  Quote  |  Print  |  Notify Moderator
nice....I just did the MagHytech on the rear myself...that wasn't cheap.
Now I am thinking of upgrading to a new power steering box.
FINALLY got my local shop to get the right casters in to get my alignment right. Now I got a busted driver side tie rod.
Yup, there is always something.
2006 Ford F250 King Ranch PSD
ARP Headstuds
ERG Delete
Diesel Site Coolant Filter System
Gearhead Performance Tuned, via XCALII, Edge Insight CTS
MBRP 4" Turbo Back, cat delete
MagHytech Rear Dif Cover
2011 Ford Expedition, HD Tow
2011 Cruiser CF33LF, KC5PFG
45Ricochet
North Idaho
Posted: 06/04/12 10:01pm Link  |  Quote  |  Print  |  Notify Moderator
Yes your saving a bunch of costs, costs, costs
Just a reminder the thermostat and water pump while your at it. Someone on DTR had a really good post (sticky?) about doing it. Don't want that nasty air pocket going on Heater hoses..
I would just drop that cat, they have been known to fall off. I don't believe any state or providence besides Kalifornia care, but don't hold me to that, LOL.
Ah yes the good ol front end issues.... from a oil field truck. I've been pretty lucky but Geno's has some nice replacement parts
The RV ready to go? I'm sure you'll have a better trip this year
06 Ram 3500 CC LB Laramie 4x4 Dually 5.9 Cummins Smarty Jr 48RE Jacobs brake
GVWR 12,200 RAWR 9350
06 Grand Junction 34' High profile 15500 GVWR 3200 pin Mor/ryde 5500 Onan genny Dual A/C Wet bolts
27' Hallett 502, 500HP
45Ricochet
North Idaho
Posted: 06/05/12 06:29am Link  |  Quote  |  Print  |  Notify Moderator
On edit I got to thinking, that trip was 2 years ago
Anyway here is the sticky from DTR which is helpful if your flushing it.
Water pump
ib516
Up here!
Posted: 06/05/12 06:44am Link  |  Quote  |  Print  |  Notify Moderator
Ya Rick, I'm sure the fact that my truck was a former oil field worker was hard on the front end. When I replaced the ball joints and front drive axle knuckle U-Joints, it was because I snuck that in just under the bumper to bumper warranty, cost me $0. I did have them replace the non-serviceable parts with ones with zerk fittings though.
Thanks for the link.
And the RV is ready to go. The countdown is on.
Edited for spelling mistake
* This post was edited 06/08/12 06:50am by ib516 *
jtrent6415
Omaha
Posted: 06/05/12 02:32pm Link  |  Quote  |  Print  |  Notify Moderator
Wow, I don't do near enough maintenance on my vehicles....
2011 Keystone Passport 2910BH
2005 Ford F-250 King Ranch (yes, the dreaded 6.0)
2004 Suburban 1500
CND SuperCrew
SK, Canada
Posted: 06/05/12 05:57pm Link  |  Quote  |  Print  |  Notify Moderator
I'll help you with your exhaust if you help me with mine....
Ron, Lori and Autumn
TV 2012 F150 loaded XLT EB SuperCrew 7700GVWR Maxtow 6.5'
TT 2008 Jayflight G2 23FB/ Equal-i-zer WD
2013 Colorado bound
2012- 4000km, 28 nights for the season
2011- OR & CA done, 6800km in 3 weeks
Page of 7
