SwedeEng
Arvada, CO
I am moving from a motorhome to a 5th wheel.
I am confused when trying to determine if I should go to a;
1 full one ton
2 a three quarter ton
3 a three quarter ton but add air bags for more suspension
We are looking to buy a 5th wheel with a max weight of 15,740#,
a curb weight of 12,580# and a pin weight of 2,270#.
I am looking at either an F250 or a F350.
Any sage advice out there?
Thanks
Walt
Walt & Darlene Pearson
Wheat Ridge, CO
RedAce
Stratford
If it was me, I would opt for an F350/3500 DRW. That what we use to pull a similar weight 5th wheel
LimogesMan
Ontario, Canada
A nice diesel F-350, F-350 dually or F-450. Take your pick.
2002 Ford F150 SuperCrew 4X4 FX4 Lariat, 5.4L Triton V8, Precision 4.10LS
2004 Keystone Springdale 249BH 26' Fifth wheel (5800# empty)
Husky 16K dual pivot glider. TomTom One 3rd edition.
18 mpg empty, 11 mpg towing.
bax467
MN
Without hesitation.........F350 SRW or DRW Diesel
2005 GMC Sierra SLT 5.3 HO (retired)
2011 Toyota Tundra Rock Warrior
2010 Rockwood 2701
2008 Harley Davidson Fat BoB
Tankcar
Santee, California USA
hi.
Go! With the One ton you will be happer.
fla-gypsy
North Florida
1 ton DRW
LostinAZ
At Home
If you are going to buy a truck you should look at a 1 ton dually. One ton single rear wheel minimum. But.... what ever you are thinking about you need to learn what the specs are for that particular truck for the configuration it is in. Most 3/4 ton and 1 ton trucks within the same manufacturer have the same diesel engine and the same transmission. But dependent on configuration, the rear axle weight rating, the rear axle ratio, the tire size, the rear springs, the payload, and the GVWR of the ruck will vary. You need to know that you will not exceed the capacity of the truck by adding up the trucks' weight when ready to tow plus the weight of the 5th wheel fully loaded for a trip and compare that to the GVWR of the truck. Also compare the payload capacity of the truck vs what the pin weight will be of the 5th wheel when it is fully loaded for a trip. The pin weight alone will push you into a 1 ton truck. One needs to do a bunch of homework to answer your specific situation requirements.
PS: you might find a 3/4 ton truck with the GVWR you need but it will need to have airbags to meet the pin weight requirements but I would not recommend it.
djgarcia
Northern, Ca. , USA
Another vote for a 1 ton diesel and an exhaust brake. I prefer to tow a 5th. wheel with a truck that has a little extra towing capacity
Dick
djgarcia@earthlink.net
bailer6334
Prescott, AZ
For that weight a 3500 Dual Rear Wheel at a minimum. Could also look at a 450.
2011 Arctic Fox 29-5T 5th Wheel
2011 Silverado HD 3500 6.6L Duramax Diesel Crew Cab
Short Bed 4X4 SRW LT
50gal Transfer Flow Aux. Tank
16K Valley Hitch w/bed saver
smkettner
No on the 3/4. Get a 350/3500. Only question is SRW or dually.
675 watts solar
