RV.Net Open Roads Forum: Class A Motorhomes: Typical Voltage Drop?
 > Typical Voltage Drop?
Page of 5
Tom/Barb
Oak Harbor
Posted: 06/09/12 10:13pm Link  |  Quote  |  Print  |  Notify Moderator
Try this, solder a wire to the side of a 12 volt bulb such as a tail light bulb, and another wire to the hot connection of the bulb.
then at every connection of the heavy wire portion of the electrical system, attach the wires to the side of each connection with the system on. if the light lights you have a bad connection.
that's the easy way to do a voltage drop test. if the connection has any resistance across the connection, the light will light.
2000 Newmar mountain aire 4081 DP, ISC/350 Allison 6 speed, Wrangler JK toad.
1L243
Astoria, Oregon
Posted: 06/09/12 10:24pm Link  |  Quote  |  Print  |  Notify Moderator
This is my friends Bounder. The Coach had been plugged in for three days. I was using a Voltminder plugged into the DC outlet wired through a 20amp circuit. Two lights also run on this circuit. I got a reading from the DC outet right after unplugging from shore power and tested the batteries directly with a volt meter. There was about 1/10 volt drop from the batteries to the DC outlet. Like 13.5 at the batts and 13.4 at the DC outlet. I turned on all the cabin lights and the volts dropped below 12 volts even before I got the last light turned on. (unfortunately I did not test at the batteries at this point). The wires on the DC outlet are 10 gage wire connected to 12 gauge wire. I would not have thought that the voltage drop would have been so sudden. After turning all the lights back off, Voltminder showed 12.75 and climbed to 12.95 volts. ( I realize that this level would be less if the batteries had a chance to rest after charging).
2011 Work and Play 30WR. Added 2nd AC, four deep cycle batteries.
smkettner
Posted: 06/09/12 10:48pm Link  |  Quote  |  Print  |  Notify Moderator
I think much of the drop is in the wiring. Best to check directly on the battery terminals.
675 watts solar
FuzzyKnight
Santee, Ca
Posted: 06/09/12 10:54pm Link  |  Quote  |  Print  |  Notify Moderator
It is normal as each time you turn on a light or some kind of drain on a DC system it will lower the voltage reading. If you turn everything off it will go back up.
DC 101 - If you have clearance lights on the top of the coach and measure the voltage at each light, lets say you have 5 lights, The first light will show 10 volts. The second will show 8 volts. The third will show 6 volts. The forth will show 4 volts and the last will show 2 volts and it will show Zero on the ground side because each light will consume X amount of voltage.
Fuzzy and Mary
1994 Pace Arrow 33
1928 Model A
1953 Ford Club Coupe
1963 1/2 Falcon Ranchero Original factory V8 4 spd
1963 Fairlane SportsCoupe
1965 Honda SuperHawk
1L243
Astoria, Oregon
Posted: 06/09/12 10:58pm Link  |  Quote  |  Print  |  Notify Moderator
Assuming that is true would it make a difference if all these lights are on 3 different ciruits? Tomorrow I will go over and try again. This time I will measure at the battery when all the lights or are and compare that with the DC outlet..
OnaQuest
Old enough to be a
Posted: 06/10/12 06:24am Link  |  Quote  |  Print  |  Notify Moderator
Not true. The clearance lights are wired in parallel and would have the same 12 volts across any of the five lights. What you described is a series arrangement which is never used in automotive/RV DC wiring.
DC 101-A.
The only lights I've ever seen wired in series are "Christmas Tree lights".
slemnah
none
Posted: 06/10/12 06:41am Link  |  Quote  |  Print  |  Notify Moderator
And that would be the old style Christmas lights.... the new lights are connected in parallel
OnaQuest
Old enough to be a
Posted: 06/10/12 06:47am Link  |  Quote  |  Print  |  Notify Moderator
Exactly.....
Ivylog
Blairsville, Ga. USA
Posted: 06/10/12 06:54am Link  |  Quote  |  Print  |  Notify Moderator
I see some LED lights in your future as they will solve your problem. These are the best I've found for less than $4 for those dual bulb lights that use a 1156.
04 Monaco Dynasty 42' quad slide
Where am I?
How I tow.
jauguston
Bellingham, WA
Posted: 06/10/12 09:31am Link  |  Quote  |  Print  |  Notify Moderator
What is not functioning properly that you are trying to fix?
Jim
2005 Coachman Sportscoach Elite 402 40'
350hp Cat C-7 w/MP-8
7500w Onan quiet diesel generator
6-Kyocera 130w solar panels SB3024i MPPT controller
Pressure Pro TPMS
1987 Suzuki Samurai tintop Toad w/VW 1.6 turbo diesel power
Page of 5
