RV.Net Open Roads Forum: Class A Motorhomes: Dual Head Chuck Tire Gauge
 > Dual Head Chuck Tire Gauge
ROYBUCK
Newport NC
Posted: 06/10/12 05:44am Link  |  Quote  |  Print  |  Notify Moderator
This might be the wrong place to post this but I need a answer soon, getting ready to go on a trip. I have a Dual Head Chuck Tire Gauge, I have had this Gauge a while, went out to check the tires this morning can't get a correct reading sound's like the air is escapeing out the other end I keep getting diffrent reading, I don't mind purching another Gauge but wanted to ask if you think this one has seen its better days. Thanks for all replys. I have never had this problem before. If I need to purchase another Gauge weould you recommend the same Dual chuck or something else. Roy
Roy B Coal Miners Son
USMC Ret
Semper Fi
2002 Endeavor 330 ISC 3 Slides
Bill S.
Indian River, Delaware
Posted: 06/10/12 06:20am Link  |  Quote  |  Print  |  Notify Moderator
It may be in need of replacement, but if the olny thing wrong is the air leak from the opposite side, you might try this. Could be a small spec of dirt stuck in the seal/seat, so try rinsing it under tap water, and blowing it out. A drop of vegetable oil on the rubber seal and betal pin, might let it seat properly.
But if it's worn, and won't seal, then time for a new one. Truck stops have a selection, as well as NAPA auto stores. But a good one.
Bill, (aka Capt.Bill)
Indian River, De
2002 Horizon 36LD, Cat 330
Practicing retirement!
ROYBUCK
Newport NC
Posted: 06/10/12 06:32am Link  |  Quote  |  Print  |  Notify Moderator
I just checked it on my toad, it works ok on the low pressure tire, but wehen I go to the hight pressure like on the MH is when I have a problem, off to the parts store when they open. Thanks Roy
FormerBoater
South Florida
Posted: 06/10/12 07:18am Link  |  Quote  |  Print  |  Notify Moderator
Roy,
Go to a truck parts distributor and get a Milton gauge.
The Milton product is made in the USA and will not fail with time.
My experience with similar gauges made in China is that they fail when used with our higher pressure applications.
Dave
1998 American Eagle 40EVS
imgoin4it
Alamogordo, NM USA
Posted: 06/10/12 07:31am Link  |  Quote  |  Print  |  Notify Moderator
X2's on the Milton
Retired and loving it
Living in the Land of Enchantment
Traveling in 2007 Newmar KSDP
towing a Jeep Liberty
with a Blue Ox tow bar
restorodder
Pinckney Michigan
Posted: 06/10/12 07:51am Link  |  Quote  |  Print  |  Notify Moderator
I have always had trouble geting a good reading on the outside and front tires on my Ford F53 19.5" wheels. I have at least 6 tire gauges,and none of them fit propperly. On two milton gauges I heated the tube and bent them trying to get a better angle. It is still hard to get a good fit.
2008 Newmar Canyon Star - 2007 Dodge Dakota Toad - Ready Brute tow bar & brake system - one cat - Sassy 14
ROYBUCK
Newport NC
Posted: 06/10/12 07:59am Link  |  Quote  |  Print  |  Notify Moderator
To the best of my knowledge there is no truck distrubitor around here, NAPA is closed today, went to O'Rileys and got a cheap one which works as of now getting ready to go on the road will check at truck stops for a better gauge. Thanks to all for the replys. Have a safe Summer. Roy
UltraKen
Ohio
Posted: 06/10/12 08:16am Link  |  Quote  |  Print  |  Notify Moderator
FormerBoater wrote:
Roy,
To add to the convenience I put a quick disconnect on the the inlet for the air hose - at the bottom right by the trigger.
At a stop I can just grab the gauge and check the tires. If I need air I get the 50' hose and quick-connect. I add air, release the trigger, and check the pressure.
I had my gauge checked at a truck tire shop that had a certified accurate master gauge. The Miltin was exactly the same as the certified gauge.
Cost was about $40 plus a small bit to make an adapter for the quick connect.
UltraKen
Ex - 1968 Ultra Van
NOW - 1996 Safari Sahara 35' - Model 3530 - Cat 300
Pictures of my Coach
A $93 Rear Camera System
My take on replacing tires
Used MH Checklist
Toad: Dodge Grand Caravan on Tow Dolly or 1981 Vespa on utility trailer
wny_pat
Western NYS
Posted: 06/10/12 09:13am Link  |  Quote  |  Print  |  Notify Moderator
Alcoa Wheel air gauges. Mine works great, and if they are good enough for Alcoa, they good enough for me. A quality gauge, and its price will not break the pocketbook.
One is Straight-on 30° reverse in Black Polyurethane finish, and the other is Straight-on 180° reverse in chrome finish.
jimhaz2402
Crossville, TN USA
Posted: 06/10/12 09:44am Link  |  Quote  |  Print  |  Notify Moderator
My story: I bought a Milton 976 2 yrs. ago and have taken good care of it (kept it in a clean place by itself--not in a toolbox).Recently I heard of a real good, very accurate digital (Trucker's Choice Digital Pressure Gauge #TMG-860-97). When I first got it, it registered 4 lbs. under the Milton! I went to a local tire store, and they compared it to their master gauge. It was right on! Then I heard of a NAPA Master Pressure Gauge--and it agreed with the digital. Believe me, I keep the NAPA gauge (#90-390) in a sock and away from everything. I've quit using the Milton. Maybe it can be re-calibrated?? Just my 2¢ worth. Jim
