RV.Net Open Roads Forum: Technology Corner: Wineguard Traveler automatic satelite dish setup?
 > Wineguard Traveler automatic satelite dish setup?
Pete_k
Stantonville Tn
Posted: 06/12/12 05:58pm Link  |  Print  |  Notify Moderator
Wineguard Traveler automatic satelite dish setup with a Direct Tv Hd Box model H24-700. Auto sat find all three sats, but still no picture. I get a message about not finding the Dish?
Anyone know if theres something on the Box that needs to be changed from home use to the Wineguard dish?
Pete
2004 Duramax/allison Trans C/C 4x4
2012 Landmark Key Largo
2008 Lund 1825 Pro Guide Tiller, With a Evinrude 90 HP E-Tec
Live near Pickwick Dam and the Tn river
ploiselle
South Shore, MA
Posted: 06/12/12 06:50pm Link  |  Print  |  Notify Moderator
I have a sk-3005. Yes you do need to change the type of antenna in the DTV box. At home you probably have a SWM system. The traveler uses multiswitch technology.
This link should help.
Make sure you write down the house settings so you can change them back when you put the box back in the house.
Paul
41' MountainAire (MADP) -Spartan- Cummins 350 ISC
2012 Jeep Grand Cherokee Overland
2004 Jeep Grand Cherokee Limited
Brake Buddy - CoachNet
Pete_k
Stantonville Tn
Posted: 06/12/12 07:22pm Link  |  Print  |  Notify Moderator
Thanks will try that again. It shows I have a 771A error. So will try it again.
Pete
ploiselle
South Shore, MA
Posted: 06/12/12 07:44pm Link  |  Print  |  Notify Moderator
DIRECTV 771
"771A" is an error code that indicates your receiver is having trouble communicating with your satellite dish. As a result, your TV signal may be interrupted."
Paul
hitchup
Fulltiming and on the Road.
Posted: 06/13/12 10:34am Link  |  Print  |  Notify Moderator
Early last year, we upgraded to Winegard SK-3005 dish. Then we upgraded our TV to 3D last fall. The salesman suggested new Monster HDMI cables to get the best picture. But we couldn't get any picture. So DH tried the HDMI cable that came with the DirecTV HD24-100 receiver and we were in business.
Luckily, Best Buy let us return the expensive cables for credit.
2009 DRV Mobile Suite 38TKSB3 (38RSSB3)....our custom home w/2011 upgrades
2010 Ford F450 KR CC 4x4......his office
Working Fulltimers since 3/2005
"Shoot for the Moon! Even if you miss it, you will land among the Stars."
Mile High
Denver, CO
Posted: 06/13/12 11:03am Link  |  Print  |  Notify Moderator
Amen - been there with Monster Cable!! It was the last thing we expected because they are expensive and far superior cables right?? Wrong- happened to me twice now and I won't buy them again.
2006 Ford F350 4X4 SB CC SRW Powerstroke 6.0
2013 Redwood 36RL - full paint - disk brakes
"Comparison is the thief of joy! - Theodore Roosevelt"
ploiselle
South Shore, MA
Posted: 06/13/12 05:11pm Link  |  Print  |  Notify Moderator
Hi Pete,
Did you solve the problem?
Paul
Pete_k
Stantonville Tn
Posted: 06/13/12 08:38pm Link  |  Print  |  Notify Moderator
Paul think I got it almost fixed, But ran out of time and had to stop this evening for church. Will see tomorrow if its fixed or not. But it did set the time and date so looking like its about there.
Pete
jnharley
Anywhere, U.S.A.
Posted: 06/14/12 06:58am Link  |  Print  |  Notify Moderator
We just had the Wingard Sk-3005 installed on our Hitchhiker last week. It can be set up as a SWM dish using a SWM 8 switch. Four wires into the SWM switch, one wire out and we use a HD spliter for the two TVs. We also encountered the same problem you were having. Resetting the box was the solution for us. You also have to change your settings on your receiver to reflect the correct dish type.
2012 Dodge Dually
2012 Nu WA Discover America 355CK
ploiselle
South Shore, MA
Posted: 06/14/12 07:56am Link  |  Print  |  Notify Moderator
Here is the information from Winegard about setting up a SWM system.
I have a SWM setup also. I run my DirecTv, OTA and cable TV through one cable using a diplexer at each TV. It also allows you to use a DVR on any TV with only one cable.
It is my understanding that not all SWM8's work, so make sure that it is DirecTv approved. The splitter needs to be a SWM splitter. If you only have two TV's you can do it without using a splitter. See the diagrams in the link above.
I don't understand why Winegard hasn't changed their satellite antennas over to SWM technology.
Pete, I don't see any advantage to switch over to a SWM system if yours is already wired.
Paul
