RV.Net Open Roads Forum: Toy Haulers: Which american 16" LT tires?
Search only in Toy Haulers
 > Which american 16" LT tires?
Page of 10
rerod
Iowa
Posted: 06/13/12 02:47pm Link  |  Quote  |  Print  |  Notify Moderator
allcool wrote:
I've done a lot of research on this. And gotten lots of great forum recommendations/information.
I went with the 235/85 16e Commercial TA all season for my 13,000gvw 3 axle TH. So far seems like a big upgrade from the trailer china bombs.
What is your 2 axle TH gvw ?
jmo
I have 5200 lb axles.. So 10400 lbs and TH weighs in at 6500 empty.
I should be about 8500 loaded with my bikes and gear.
I like the price of your BFGoodrich COMMERCIAL T/A ALL-SEASON LT235/85R16 120/116Q RBL. at $139 each
1995 E350 6bt/nv4500, 2006 Featherlite 24' surv toyhauler, 2007 DRZ400s well farkled, 1985 Vmax stock, 1985 Vmax custom
mapguy
Puget Sound
Posted: 06/13/12 05:15pm Link  |  Quote  |  Print  |  Notify Moderator
Nitto Dura Grappler or Yokohama Geolandar H/T-S G053 are two options of 3 ply sidewall fabric carcass tires to consider. Might buy them a bit cheaper than the BFG
donn0128
Pronounced Ore-gun
Posted: 06/13/12 09:57pm Link  |  Quote  |  Print  |  Notify Moderator
hallock5 wrote:
Not to hijack (didn't want to start yet another tire thread), but what considerations need to be made, if any, when switching from St to Lt? We are full-timers averaging 1K mi. per month on 3 Marathons and 1 Carlisle, lucky me , in need of some rubber. (225/75/15 ST right now).
Sent you a PM so as not to hyjack the thread
Donn,Lorri,Max (The Rescued Lab)
Resident Know It All
lincster
Mesa Az
Posted: 06/13/12 11:03pm Link  |  Quote  |  Print  |  Notify Moderator
XPS Rib all the way.
2012 F350 PSD CC 4X4 Dually to pull 2006 LE3905
Lincsters Truck/Trailer
Lincsters Rail
rerod
Iowa
Posted: 06/14/12 10:18am Link  |  Quote  |  Print  |  Notify Moderator
The commercial T/A's weigh 20 lbs each. Found four @ $794 installed.
The XPS Rib's weigh 56 lbs each. Haven't really seriously considered these until I saw the weight. Wow, But the Max Load is the same at 3042??
gpshemi
Lapeer, Michigan
Posted: 06/14/12 10:42am Link  |  Quote  |  Print  |  Notify Moderator
Just put Bridgestone Duravis R250's on mine. I love them. They are pound for pound / penny for penny a better option than the XPS Ribs in my opinion. They're light years over the ST tires that came on our rigs.
GPSHEMI
06' 3500 Dodge Ram Megacab 4x4 w/ bombed 5.9L
18K Pullrite SuperGlide w/super rails
2010 Heartland Cyclone 3612
mapguy
Puget Sound
Posted: 06/14/12 10:56am Link  |  Quote  |  Print  |  Notify Moderator
I agree but seems these are a little more money than the OP wants to spend.
rerod
Iowa
Posted: 06/14/12 11:22am Link  |  Quote  |  Print  |  Notify Moderator
Found some info about another tire made by Michelin.. The HD-H Uniroyal laredo which was OEM for years on the HH II trailers with 6k axles. Great record from what I hear.
They weigh twice as much as the commercial T/A's but cost only a bit more..
Do any of the tire mentioned have better weather-ability? Or is removing them from the trailer the only option to prevent sidewall cracking?
BobWanderer
Perris,Calif,USA
Posted: 06/14/12 11:27am Link  |  Quote  |  Print  |  Notify Moderator
FWIW
I went with the BFG Commercial T/A, decent price and I am MORE than pleased with them. The trailer tracks straighter and has less bouncing than before. I just towed ~650 miles in 90-100* temps with some gusty winds on the return trip, handled it very well.
I don't run the "Friction sway control" unless its very windy since She tracks so well, stronger sidewalls ??
I have a infared thermometer and check the tire temps often, the BFG's run cooler than the ST's. Outside temp was 100* and tire temps were 118-120*, the ST's usually ran 125-130* in similar conditions.
The TV front tires were about the same temp as the TH, rear TV tires were warmer than the TH tires by a few degrees.
I am sure the Bridgestones/Michlins are a better quality tire, but since Our rig gets used 1-1.5K miles a year, I think I am in good shape.
My.02
2008 GMC 2500HD 4X4 DMax CC LB
2004 Thor Wanderer Wagon 247WTB
2006 TE450 Husky
2007 Rhino Sport Edition
JIMNLIN
out here
Posted: 06/14/12 12:53pm Link  |  Quote  |  Print  |  Notify Moderator
The BFG Commercial and the Uniroyal HD-H are sisyer tires and weight the same. Don't know where you got the 20 lbs for the BFG Commercial tire but its not correct.
BFG shows the LT235/85-16 E weighs 45 lbs, same as the Uniroyal HD-H.
I ran my last set of BFG Commercial for 7 years and 55k-60k miles. The trailer sits in a covered shed when not in use and has Tire Care sprayed on the tires twice a year and max pressures 100 percent of the time.
Your tire manufacturer will have info on helping your tires last longer.
'97 Park Avanue 28' 5er 11200 gvwr two slides
Page of 10
