RV.Net Open Roads Forum: Class A Motorhomes: propane off if not being used?
 > propane off if not being used?
bass n bob
new york state
Posted: 06/18/12 08:22am Link  |  Print  |  Notify Moderator
should you turn your propane tank main valve off while parking at a campground and not using propane? Would doing so reduce the chances of a fire?
dupreet
High Point, NC
Posted: 06/18/12 08:28am Link  |  Print  |  Notify Moderator
I wouldn't turn it off for a couple reasons. First off, the chance of a fire is very low. When the gas comes out of the regulator, it is low pressure, I think about 1/2 PSI. Also, if you do, you may have to bleed air out of the lines each time you use a gas appliance.
Don't Worry!
Todd
Todd
1993 Ford E-350 pushed by a 1988 Wilderness 24' TT
wny_pat
Western NYS
Posted: 06/18/12 09:00am Link  |  Print  |  Notify Moderator
the only times mine is turned off is when fueling the motor home (actually I turn the frig off so there is no open flame or sparking), fueling the propane tank, going thru a tunnel or on a ferry where it is required to be turned off, or when the propane system is being worked on,
“All journeys have secret destinations of which the traveler is unaware.”
gone2dadesert
Encinitas, Ca
Posted: 06/18/12 08:33am Link  |  Print  |  Notify Moderator
Are you using "full" hook ups or dry camping?
I'm not sure about your coach, but many coaches use propane operate the hot water heater and refrig when they are not plugged in or dry camping. When you are plugged in some coaches can heat hot water without using propane, so it really depends on the options you have in your coach.
2011 Hurricane 31J
2008 Jeep JK Unlimited Rubicon
rv2go
Fulltime 15 yrs (Knoxville, TN).or someplace else
Posted: 06/18/12 08:45am Link  |  Print  |  Notify Moderator
I leave my propane on all the time. I have the fridge set on "auto" just in case the CG loses electricity. That way it will switch over to gas.
Winnebago Journey
TN Lic. RV 2 GO
Jeep Cherokee 4x4
I'm here #4335
Blog
gone2dadesert
Encinitas, Ca
Posted: 06/18/12 08:47am Link  |  Print  |  Notify Moderator
ditto
rvten
Crossville,TN
Posted: 06/18/12 09:05am Link  |  Print  |  Notify Moderator
Only time our proapne tank valve is closed. Is when it get filled.
Tom & Bonnie
Crossville, TN.
Aspect 29H 2008 Type C
Ford Flex SEL 2010
There is NO B+
wolfe10
Posted: 06/18/12 09:37am Link  |  Print  |  Notify Moderator
I turn my propane off at the tank ONLY when in storage (inside building).
It is (as it should be) required by the owner of the facility.
Brett Wolfe
2003 Alpine 38'
Sandia Man
Rio Rancho, NM
Posted: 06/18/12 09:08am Link  |  Print  |  Notify Moderator
Too much of a hassle for whatever safety gains you are seeking to achieve. Constantly turning off the propane and re-bleeding the lines is not something I would look forward to doing, but it's your rig and you should do what makes your RVing experience a safe and enjoyable time.
Sloop Smitten
San Marcos, CA
Posted: 06/18/12 10:01am Link  |  Print  |  Notify Moderator
I do turn mine off when the RV is stored. Major reason is if one of the lines starts leaking or somebody inadvertently leaves a stove burner on there will be no one there to notice and the RV can fill with gas and essentially become a large bomb. I understand that chance is small but it only takes once. I once went to use my backyard grill and someone had opened a valve and the tank was empty. So even if the propane does not explode you could lose an entire tank of propane. I do not turn it off when I am at a campground and away for the day. Only when storing.
1992 Fleetwood Jamboree Rallye 24' M/H
Ford E350 Chassis, 7.5L Engine, E40D Transmission
My other motorhome is a 1978 Catalina 25 Sailboat
Cruising Califonia, Sailing the Pacific!
