RV.Net Open Roads Forum: Fifth-Wheels: 5th whl hitch ratings
 > 5th whl hitch ratings
5thwhlnot-tosmart
Albuquerque NM
Posted: 06/18/12 12:22pm Link  |  Quote  |  Print  |  Notify Moderator
I'm not clear on the ratings of 5th whl hitches. If it's a 16K hitch or 20K hitch, just exactly what does that mean? Is it pull wieght or king pin weight? I sure a lot of people are in the dark about this. If you ask a salesmen, he'll tell anything to get the sale. It up to us out here to give honest answers.
Tony S. Lucero
Farmer David
Mattoon, ILL.
Posted: 06/18/12 12:30pm Link  |  Quote  |  Print  |  Notify Moderator
It would be the total weight of the trailer, that would be what they say is safe weight to tow.
2013 F450 King Ranch CC Long Box
60 Gal RDS Tank
20K B&W OEM Hitch
2013 Lifestyle 37IK
Feen
Newburgh
Posted: 06/18/12 12:31pm Link  |  Quote  |  Print  |  Notify Moderator
Total trailer GVW. Pin rating for the individual hitch is listed separately in the hitch specifications.
powderman426
ohio
Posted: 06/18/12 01:28pm Link  |  Quote  |  Print  |  Notify Moderator
If it was pin weight, that would be one heck of a trailer.
Ron & Charlotte
WD8CBT since 1976
28' Prowler & 05 Ram QC LB
I started with nothing and I still have most of it left
I never fail, I just succeed in finding out what doesn't work
mhbell
Yuma, AZ Winter - Wells, NV Summer
Posted: 06/18/12 05:10pm Link  |  Quote  |  Print  |  Notify Moderator
I have a reese hitch. It is a 15K pro square tube slider. Here is the Specs for that Hitch:
15K Means that it can pull a trailer up to 15000 Lbs and also in the specs is the maximun pin weight which is 3,750 Lbs The 15K is a separate spec from Pin Weight and each hitch can have a different Max King Pin Weight no matter whether it is 15K, 16K, or 20K
2007 Ford F250 Super Duty CC 6.0L Power Stroke Diesel Air Bags
2007 Jayco Designer 31RLTS 3 Slides GVWR 14500 Lbs My Actual GCVW
Gross Combined Vehicle Weight Truck and 5th wheel 19,980 Lbs Loaded
Billieg2
Gone from this forum
Posted: 06/19/12 09:10am Link  |  Quote  |  Print  |  Notify Moderator
If your 5th weight is close to the hitch max then go for the next higher one because you will bend the frame if you don't. Also, make sure they put in the center bolts on the rails.
In my life I've spent my money on women, booze, Harleys, guitars and traveling, the rest I just wasted...
2007 Ford F-350 diesel/dually & Sunnybrook Titan KSRV 39-1 Toy hauler 5th wheel hauling my custom Harley
River&Sand
San Diego, CA USA!!!
Posted: 06/19/12 12:24pm Link  |  Quote  |  Print  |  Notify Moderator
GVW of the the trailer. Bigger is always better in this case. IMHO
River&Sand
05 Chev Ext.Cab K3500, Dmax/Alli, DRW, Reese Signature 18k, HappiJac, Jordan 2020
05 Lance 920 Truck Camper
06 Weekend Warrior LE3305, 5th Airborne, Dexter E-Z Flex
01 HighJumper SandSprite 3 Dune Buggy
Pete_k
Stantonville Tn
Posted: 06/19/12 02:25pm Link  |  Quote  |  Print  |  Notify Moderator
I agree....
Have always been told, if its a 16,000 lb rated hitch. That it could pull 16,000 lbs. So take a trailer that weights 18,000 lbs it would still work with the 16,000 lb hitch. As your pin weight takes that much off how much your towing.
Not like a bumper hitch where all the towing weight is hanging off the ball.
Pete
2004 Duramax/allison Trans C/C 4x4
2012 Landmark Key Largo
2008 Lund 1825 Pro Guide Tiller, With a Evinrude 90 HP E-Tec
Live near Pickwick Dam and the Tn river
Billieg2
Posted: 06/19/12 03:11pm Link  |  Quote  |  Print  |  Notify Moderator
I agree....
Pete
Really? My brand new Reese 15k hitch buckled from the weight of my 16k 5th within 200 miles. Bent frame and ready to come off...
River&Sand
Posted: 06/19/12 04:09pm Link  |  Quote  |  Print  |  Notify Moderator
Pete_k wrote:
I agree....
Pete
How do you figure that? The hitch still has to support and tow the Max weight of the trailer, so that means pin weight + trailer weight = Max hitch size.
