RV.Net Open Roads Forum: Tech Issues: Suburban Water Heater SW6DE Gas Valve
 > Suburban Water Heater SW6DE Gas Valve
Elk4me
Lake Stevens, WA
Posted: 06/18/12 09:38pm Link  |  Quote  |  Print  |  Notify Moderator
I have a 2008 model Cougar with a Suburban SW6DE water heater. I can hear the solenoids click and the igniter click. No gas flow evident. I have gas, so from what I have read it appears that I have a gas valve gone bad. I put my finger on the solenoids and can feel them move but still no gas is getting through. Can the solenoids be removed and checked for movement and wouldn't this allow for checking if the ports are clear also. I am in no hurry to buy a valve if I can repair this one.
BTW, my gas valve is #161109. I find it on E-bay but not in the serial number range of my water heater. They should be the same I would think if the number is the same.
Thanks,
Scott
* This post was edited 06/18/12 10:01pm by Elk4me *
Old-Biscuit
Across the USA
Posted: 06/19/12 12:00am Link  |  Quote  |  Print  |  Notify Moderator
First.....have you checked to see if reset on ECO is tripped?
If you need to replace valve....wouldn't hurt to remove solenoids....check ports.
Might just be able to fix it...if not, needed a new one anyway.
2007 RAM 3500 QC LB SRW 5.9L CTD 48re 4:10 4K in bed 'quiet genny'
Hit the Road Free & Clear April '07
doughere
Mooresville NC
Posted: 06/19/12 05:07am Link  |  Quote  |  Print  |  Notify Moderator
I'm not sure I'd want to start by disasembling the valve itself to start. I'd first check for any filters or screens leading into the valve being clogged, then I'd check the orfice for blockage (I had a heater in which some sort of bug had managed to get into and blocked the orfice).
If you disasemble the valve, be VERY, VERY, VERY sure you reassemble it correctly and test for proper operation and leaks.
Regards,
Doug
edatlanta
Panama City Beach, FL
Posted: 06/19/12 05:14am Link  |  Quote  |  Print  |  Notify Moderator
The same thing happened to my Suburban 10 gallon. One more check I would do - Unhook the propane line going to the valve to make sure you have propane getting to it. Also, do you have a spark at the burner when it is trying to start?
If so, just replace the valve.
Ed
2006 GMC 2500HD CCSB 4x4 Duramax/Allison, Titan 52 gallon fuel tank, TTT/Schefenacker Towing Mirrors, Prodigy Controller, B&W Companion Hitch, Progressive Industries EMS-PT50C, TST Systems 507 TPMS
2010 Jayco Designer 35RLTS,Cummins/Onan RV QG 5500 EVAP
Elk4me
Lake Stevens, WA
Posted: 06/19/12 05:18am Link  |  Quote  |  Print  |  Notify Moderator
Thanks for the replies. I have spark and the ECO is OK. I have experience with gas appliances so disassembly is no problem. I will tackle it soon. I can get one on E-bay for around $60.00 so if I mess it up it isn't too bad.
Elk4me
Lake Stevens, WA
Posted: 06/23/12 10:41pm Link  |  Quote  |  Print  |  Notify Moderator
I got a new control valve on E-bay for $59.00 free shipping. I installed it today and the water heater fired right up. We will see how long it lasts. I will keep the old one for the spare coil. I haven't tested to see which one is bad but other comments I have found say the one closest to the tank is likely the bad one due to heat exposure.
jetcare
RV Repairman - South Fork, CO in the summer
Posted: 06/24/12 07:26pm Link  |  Quote  |  Print  |  Notify Moderator
I find the coil closest to the tank is usually bad. A good coil reads about 40-50 ohms. The bad coil will read open or infinite.
2007 Coachman 32 foot Travel Trailer
2010 Ford F350 Super Duty 4X2, SRW, 6.4L
mannashine
Concord, NC
Posted: 09/04/12 06:44am Link  |  Quote  |  Print  |  Notify Moderator
Still trying to figure out why my Suburban SW6DE HW Heater is not working...one quick question...where is the ECO? Above the Control Valve there are two rubber circles that look like they shuld be pushed, are there switches behind them? if yes, what are they for? Thanks, Barbara
