RV.Net Open Roads Forum: Tow Vehicles: Oil Changes . . . How often?
Search only in Tow Vehicles
 > Oil Changes . . . How often?
NewsW
US
Posted: 06/20/12 07:43am Link  |  Quote  |  Print  |  Notify Moderator
five'er wrote:
NewsW:
"You notice my brand new / rebuilt engine flush procedure?
Amazed to see how much particles are left in a "clean" new engine from the factory."
When I had my brand spanking new 06 5.9 CTD the recomended first oil change was at 1000kms and that they would NOT touch it until that time. If I remember correctly I tried to take it in early and they sent me away. I was under the impression it wasn't normal oil but some sort of conditioner. I guess to each their own, I'm sure they are all different but the guy who sold me that truck was a former diesel tech from Cummins, he seemed to know the engine inside and out. I'm suggesting there may be a reason for doing it as they suggest and following their recomendations. It may also be worth noting that they also told me NOT to tow for the first 1000kms, I assume until after the first oil change. I still recall the sales guy looking at me when I told him I did and saying.. "I like your confidence!". My 09 1500 doesn't have a HD applicaiton maint. schedule in the book, I'd assume the OP doesn't either. I believe my CTD did. I may be off on the 1000kms but pretty sure.. It was a milestone!
That is a special break in oil.
http://www.amsoil.com/storefront/brk.aspx
Most car makers no longer use this technique, of a special (often single weight) oil that lets everything seat and smooth itself.
The problem, after that oil is flushed, is that metal particles and casting sand etc. keep shedding for quite some time.
4x4ord
Canada
Posted: 06/20/12 09:29am Link  |  Quote  |  Print  |  Notify Moderator
I don't think I know a single person who has worn out their engine prior to wanting a new truck. If you think you have to change oil every 5000 miles I sure would't waste money on synthetic.
2011 F350 SRW short box 4x4 CC 6.7 PS King Ranch
B&W TurnoverBall and Companion
2003 Citation Supreme 34 RLTS
Atlee
Mechanicsville, VA
Posted: 06/20/12 11:04am Link  |  Quote  |  Print  |  Notify Moderator
I'm the same as many others. I go by what Ford recommends, both for change interval and oil recomendation. Seems to me to be fairly straight forward.
If my percent of towing climbs significantly then I'll use the heavy duty usage schedule.
Smokey Lew wrote:
I have a 2011 Dodge Ram 1500 with the 5.7 Hemi and I use it mostly for towing my 2005 25 ft. Komfort trailer. There's only 6,000 miles on the truck and about 60 to 65 percent of that is towing miles.
We just got back from a trip to Red Canyon in Utah (live in So California) and put about 1,000 miles on the truck (only about 800 of it towing). I changed the oil before the trip and we plan on heading out to Oregon the first of July for about three weeks of exploring the state.
My question is, how often do you think I should change the oil considering that I'm pulling a trailer mostly with the truck and do you recommend using any special brand of oil, or oil additives like Lucas engine stabilizer? It's a new truck and so far I've just been doing what's recommended by Dodge for normal driving conditions.
Thanking you in advance for any responses.
Erroll, Mary, Duffy the Badger Dog plus "Ollie"
2009 HiLo Towlite 2209T
2005 F150 Supercab 4x4, w/ 5.4L
1996 RoadTrek 210 Popular, on 1995 Chevy Chassis
NewsW
US
Posted: 06/20/12 11:50am Link  |  Quote  |  Print  |  Notify Moderator
There is no commonly available dino 5w-40, or 0w-40.
What do we use if we need 0w or 5w cold?
The problem is not just wear, but cold enough, dino just will not pour or start without supplemental heating.
Synth 0w or 5w extend the range considerably.
4x4ord
Canada
Posted: 06/20/12 02:35pm Link  |  Quote  |  Print  |  Notify Moderator
If you need the light weight oil put in synthetic but dumping synthetic at 5000 miles is like replacing your tires when there is still 3/4 of the tread left on them.
* This post was edited 06/20/12 02:43pm by 4x4ord *
stevenicol
Portland, Oregon
Posted: 06/20/12 02:39pm Link  |  Quote  |  Print  |  Notify Moderator
downtheroad wrote:
No additives.
Follow Dodge's recommendations in the manual. They built it and they warranty it.
You could use the "severe service" guidelines because you are mostly towing.
...the only advice I would give.
Tankcar
Santee, California USA
Posted: 06/20/12 08:49pm Link  |  Quote  |  Print  |  Notify Moderator
Hi.
I have a 1996 Dodge 2500hd, V-10 engine, Auto trans, limited slip rear end, 264,000 miles. I have change oil every 3,000 miles. USE a GOOD OIL and a good filter. Lube the chassie and adjust the beakes. Keep the water Full. And go!
SkyWriting
Milwaukee
Posted: 05/12/13 10:26am Link  |  Quote  |  Print  |  Notify Moderator
NewsW wrote:
Oils are graded voluntarily by the distributor. Just because it says API-SN doesn't mean anyone have actually tested it independently and your batch is any good.
Oils are tested at production time for the required properties. As are the base ingredients and the additives.
(Personal experience as an oil and grease manufacturer.)
