RV.Net Open Roads Forum: Class A Motorhomes: Batteries
 > Batteries
1L243
Astoria, Oregon
Posted: 06/19/12 06:41pm Link  |  Quote  |  Print  |  Notify Moderator
Friends 1999 Bounder( Engine battery 2 months old 12 volt 24 series) Coach (2 months old two 6 volt deep cycle batteries). Coach was plugged in for three days. Coach was driven 40 miles and parked for 3 days not plugged in. No lights or power were left on. Engine battery had dropped to 12.17 volts. Coach had dropped to 12.45 volts. When plugged in Converter charges at around 13.17 volts. The batteries seem to be dropping voltage for no reason....Where should we start to look for whats draining the batteries?
2011 Work and Play 30WR. Added 2nd AC, four deep cycle batteries.
MrWizard
Traveling
Posted: 06/19/12 07:22pm Link  |  Quote  |  Print  |  Notify Moderator
all batteries have self discharge, plus there are parasitic loads
13.17 is not enough voltage to fully charge the batteries
try a good battery charger for 24 hrs, then check the batteries for voltage drop
they might need a new converter
Connected thru Verizon with HotSopt WiFi using a Samsung Galaxy Nexus
I BOUGHTthis phone
Jim@HiTek
Gresham, OR, USA
Posted: 06/19/12 07:32pm Link  |  Quote  |  Print  |  Notify Moderator
They are dropping for a reason. There are several parasitic loads on an RVs battery sets even with the main and aux switches OFF. To numerous to mention. If it's going to be sitting for more then two days, just disconnect the ground cables from each set. Easy to do and works every time.
Jim@HiTek
Have shop, will travel!
Visit my travel & RV repair blog site. Subscribe for emailed updates.
Fleetwood Bounder, '94
Cummins Diesel, 190HP, 36.5' with 50HP LP boost.
Black Rock Lava Park, Nevada
tropical36
Southwest Florida_USA
Posted: 06/20/12 08:52am Link  |  Quote  |  Print  |  Notify Moderator
Might want to disconnect the ground cables and see if they drain on their own before looking for hidden loads.
"We are often so caught up in our destination that we forget to appreciate the journey."
1998 36ft. National Tropi-Cal Model 6350 on a 1997 Chevy P32
Chassis_7.4 Vortec Engine_4L80E Tranny_slide_tag axle.
Dinghy_2010 Jeep Wrangler JKU ISLANDER.
full_mosey
Oklahoma
Posted: 06/20/12 09:20am Link  |  Quote  |  Print  |  Notify Moderator
Re the 13.17V charging:
This could be normal, if measured at the battery, because the charger could be in Bulk stage.
Bulk stage charging is when all of the charging Amps are supplied while the battery volts rise to the Absorption stage cut-off voltage.
Do you have a multi-stage charger?
HTH;
John
wolfe10
Posted: 06/20/12 09:23am Link  |  Quote  |  Print  |  Notify Moderator
HTH;
John
Nope. 13.17 is barely adequate float voltage. Bulk charge should be in the 14- 14.2 VDC range.
Brett Wolfe
1997 Safari Sahara 3540
EX: 1993 Foretravel 36' U-240
1L243
Astoria, Oregon
Posted: 06/20/12 09:28am Link  |  Quote  |  Print  |  Notify Moderator
I will check out what Converter he is running...
full_mosey
Oklahoma
Posted: 06/20/12 02:20pm Link  |  Quote  |  Print  |  Notify Moderator
HTH;
John
I conducted a discharge/recharge TEST recently that illustrates this process.
HTH;
John
 > Batteries
