RV.Net Open Roads Forum: Fifth-Wheels: Generator Decision and Theft
 > Generator Decision and Theft
Pete_k
Stantonville Tn
Posted: 06/20/12 08:50pm Link  |  Quote  |  Print  |  Notify Moderator
150 lbs is not anything for a lot of people. Not many years ago I would pick that up out of the bed of a truck with one hand. And used to pick up 200+ all the time.
If it were me chain and cover it up. Plus like some of the others if we spend all the time wondering and sweating over if its going to be stolen, That takes all the fun out of camping.
I have a retrax bed cover with the camper unhooked. It rolls back and covers the whole bed. Thus everything is out of site and out of mind, with the 5th wheel hooked up I roll it back to the 5th wheel hitch and anything in the front part of the bed is covered.
Forgot to add all locks do is keep the honest people honest. The thieves will get it if they want it.
Pete
2004 Duramax/allison Trans C/C 4x4
2012 Landmark Key Largo
2008 Lund 1825 Pro Guide Tiller, With a Evinrude 90 HP E-Tec
Live near Pickwick Dam and the Tn river
Mile High
Denver, CO
Posted: 06/20/12 09:01pm Link  |  Quote  |  Print  |  Notify Moderator
The larger unit might be harder to steal, but more desirable (because of value) so it's probably a wash.
2006 Ford F350 4X4 SB CC SRW Powerstroke 6.0
2013 Redwood 36RL - full paint - disk brakes
"Comparison is the thief of joy! - Theodore Roosevelt"
Timbodeuce
Ca
Posted: 06/20/12 09:35pm Link  |  Quote  |  Print  |  Notify Moderator
I have 2 of the Yamaha 2000s. I usually just run one of them, but twin them when using the a/c. Love the portability and the option of just running 1 unless both are needed. I don't need the a/c very often, but if I did I might have gone with 1 larger unit. Cables or chains on them whichever size gen. you choose!!
SoCalDesertRider
SanDiego, CA, USA
Posted: 06/20/12 09:40pm Link  |  Quote  |  Print  |  Notify Moderator
I carry lots of expensive welding machines and other tools and equipment on my welding rig truck. Everything goes into heavy duty steel gang boxes, which are welded to the truck bed. I don't worry about the security of my tools as long as they're locked up in the gang boxes. I have a few made by JOBOX and Knaack.
Here is one of my Knaack boxes, which I made into a hitch-mounted box by building a frame under it and welding it to the bottom of the box.
05E350 6.0PSD
98Ranger
69Bronco ATC250R CR500
20' BigTex flatbed carhauler
Callen Camper
92F350 CrewCab 4x4 351/C6
HD Springs Bilsteins,
4.56's & LockRite rear
ArkieVet
Fulltimer
Posted: 06/20/12 10:03pm Link  |  Quote  |  Print  |  Notify Moderator
My late FIL had a portable Onan 4KW bolted down in the bed of his truck about six years ago. It was stolen while he was in an RV park in Pasadena, TX! After the generator was bolted down, he had even ruined the threads below the nuts so they couldn't just be unscrewed! If someone wants it bad enough, and knows it's there, they'll get it!
Retired U.S. Army SFC ('67 - '88)
(Infantry, AG Corps)
Nam Vet - Infantry (68-69-70 & 71-72)
2009 F350 Crew Cab Dually PSD Tow Boss
2009 Cameo F35SB3 w/TST TPMS
Life Member MOPH and DAV
KC5UCN
Grodyman
Posted: 06/20/12 10:09pm Link  |  Quote  |  Print  |  Notify Moderator
Lots of interesting points. I will probably go with two of the 2000 units for flexibility, maneuverability and concealability. I really like the large 3000, but I hate lifting my B&W Patriot hitch as it is.
I still am heavily considering the 2400, although I know it won't run the air.
Gman
2011 F250 4x4 CC/SWB 6.2/3.73. 2012 Sabre Silhouette 320FQDS. 2011 Lance 830 Truck Camper.
christopherglenn
a little over an hour from Yosemite
Posted: 06/20/12 10:32pm Link  |  Quote  |  Print  |  Notify Moderator
I have the honda 3k, there are 2 "channels" under it that the rubber feet are attached to, I ran a SS cable through them and padlocked the chain to the metal tiedowns in the bottom corners of the bed. Lots of power, large fuel tank, to heavy to easily move, requires cutting padlocks or 3/8" SS cable. A tarp thrown over it and strapped down would cover it easily.
2007 Chevrolet 3500 CC/LB Duramax/Dually 4X4 Mine r4tech, Reese Signature Series 18k +slider, duratrac, titan 62 gallon, diamond eye, Cheetah 64
2011 Keystone Fusion 405 TrailAir & Triglide, Centerpoint, gen-turi, 3 PVX-840T, XANTREX FREEDOM SW3012, G614
Kevin8520
Orange County, CA
Posted: 06/21/12 12:50am Link  |  Quote  |  Print  |  Notify Moderator
I had the Yamaha Inverter EF3000iSEB. I loved it. It was powerful and quiet. I could start my Coleman 13.5 on my old Prowler trailer with it no problem.
As for security, I would chain it to the truck bed or some part of the trailer. When I would camp and go off riding my quad I would lock it up with one of these and never had an issue..
http://www.etrailer.com/Locks/Master-Lock/8419DPF.html
2011 GMC Sierra 2500HD Crew Cab SRW -6.6L Duramax Diesel, Standard Bed, 4x4
2007 Yamaha YFZ450 Special Edition
DL: CA Non-Commercial Class A
Tow Rating: 13,000
5th Wheel Rating: 16,700
Max Payload: 3,123
GVWR: 10,000
GCWR: 24,500
Front GAWR: 5,200
Rear GAWR: 6,200
bluck
Silver City, NM 88061 USA
Posted: 06/21/12 10:40am Link  |  Quote  |  Print  |  Notify Moderator
I use one of the heavy duty Master Lock ATV-Motorcycle locks, about a 5/8 dia. Cable with a fiber glass strands inside. They claim bolt cutters won't cut it due to the fiber glass. It's very heavy duty. Wal Mart puts them on close out often for about $ 15.00.
2004 Chevy.
Duramax-Allison
2004 Thor Mirage
Kawasaki Prarie 700
Devocamper
West Haven CT
Posted: 06/21/12 11:21am Link  |  Quote  |  Print  |  Notify Moderator
We have two honda 2000I's and when I hook them together I have 4000 watts , which is a little more than the 3000 and they are much easier to handle , I have the steal plates that go over the handles to help slow down someone trying to steal them by cutting the handle off and removing my cable , have long cables with locks locked to the trailer and have never had a problem and we spend a lot of time at state parks with some real strange people at times. I would rather have more power with the two hondas when I need it and when I dont I only use one to charge the batteries , good luck
08 NU-WA Hitchhiker Discover America 339 RSB
07 Chevy 3500HD LT1 EXT Cab LB DRW D/A
