Turbo Diesel Dude
Green Mountain, NC
Got my Blsckstone Oil results back on my 2011 6.6 Chev. No idea whether or not it had the CJ4 required oil in it as it had 40K on it when I bought it and had just been changed by dealer. Was informed that some of the figures were a little on the high side ie: Aluminum-8/Universal avg is 2; chromium-1/avg 0; Iron-33/avg14;copper 5-avg 13. Could just straight 15W-40 oil have been used causing the figures? Not real certain. I just changed it and went with DELO 15w-40 CJ4. Any ideas from some knowledgeable people? Thanks
charles weidman
remoandiris
You'll probably get a better answer in the tow vehicle forum.
2011 GMC 3500 Dually
New to me 2006 Jayco Designer 38RDQS
2 Boxers and a Maine Coon
Turbo Diesel Dude
Green Mountain, NC
Thought I did post it there. Sorry if I inconvienced you in any way.
sirdrakejr
Las Vegas, Nevada
Moved from 5th wheels to tow vehicles.
Frank
nremtp143
Georgia
Even at 40k, sounds like the engine is still not broken in well. Did the truck have a 5th wheel hitch installed when you got it?(means it's usually been pulled hard and most everything in engine has seated) Was the viscosity of the oil low? That would explain the higher numbers. If Blackstone is not that worried about it, just wait until next time, or do another sample at half your normal mileage and see what it says. If it has improved, then it's a safe bet it was the oil.
2012 Sandpiper 365SAQ, Goodyear G614s, TST TPMS
2010 F350 DRW 6.4L 4x4, Edge CTS, B&W Companion, Viair 10007 air system, Firestone Ride-Rites,Flo-Pro cold air pipe
2001 Excursion Limited 7.3L 4x4, V/B Springs
2001 Silverado 3500 DRW CCLB 8.1L/Allison 4x4
Roger10378
Goodrich, MI.
No the CJ4 will not cause the metals level to be high. CJ4 is a low ash oil so that ash does not build up in the particulate filter. High levels of metals are usually present during break-in and then go down.
2005 Cardinal 30TS
2007 Chevy 2500HD D/A
ksss
Eastern Idaho
Oil sampling has more value when you can look at multiple samplings over a period of time. Taking a single snap shot (one sample) provides some good information but no real baseline for that individual engine.
2006 GMC 3500 CC 4X4 D/A
2013 Fuzion 342
2011 RZR Desert Tan
2012 Sea Doo GTX 155
2005 GMC 5500 CC 4X4 D/A
2012 Chevy 2500HD 4X4 6.0 3.73
coolbreeze01
Redding, Ca
Are you sure the dealer changed the oil before you bought it? The Delo is an excellent choice and another sample or two will give you a better bench mark.
2008 Dodge 3500 With a Really Strong Tractor Motor...........
LB, SRW, 4X4, 6-Speed Auto, 3.73, Prodigy P3, Blue Ox Sway Pro........
2007 Komfort 212 on 225 75R 15E Maxxis ST Tires.........
