gmgregg
cameron park, ca
I am currently in the process of buying a class A RV. When we went through the coach and I inspected the tires, the front tires had minor cracks and I requested the dealer must replace those. The rear tires appeared to look fine but I neglected to read the DOT date to see if they were expired. I had the dealer have Les Schwab determine how old the tires are and they are indeed expired (almost 8 yrs old)
So, my question is this, is the dealer responsible for replacing the tire on their dime? I contacted 3 other dealers to ask them what they do, and all three stated they are "obligated" to replace the tires. I don't know how to interpret if "obligated" means they must by law replace them, or that it is their policy. I have heard from two dealers that because it is a safety issue, similar to brake pads must have at a minimum amount of pads before they can sell the rig, they must replace the tires.
The dealer I am buying my coach from said that Les Schwab told them that the DOT date is simply for the tire manufacturer reference to handle warranty issues.
Can someone get me some facts?
Thanks
pkunk
Questa, NM
Dealers lie..... Threaten.
1999 Coachman Mirada 34 ft.V10-F53 chassis
12ft.LR slide-2 gp31 AGM 12V @220AH
rvrepairnut
bc
pkunk wrote: Dealers lie..... Threaten.
not always.Tires dont exspire.Date codes are just a reference.If the tires were seperated or worn out or cracked so bad they could blow out
then a dealer most likely will have to replace them before they sell the unit but in this guys case it sounds to me like the tires were in good shape and u cant make a dealer replace them based on date codes alone
raygreg
Seattle,WA
The facts are that you have the right to go spend your money at another dealership if you don't like the price or the tires or the way the salesman smiles or doesn't smile.
The DOT date is when the tires were manufactured not an expiration date.
wny_pat
Western NYS
The only fact is that the dealer your dealing with probably lied about what Les Schwab told them. Think I continue to look around and forget about them. And are the obligated??? I don't know California law, but I doubt it. If they are lying about the tires, they also lying about something else too!
Executive
Since there is no federal or state MANDATE requiring the tires to be replaced at a certain age, the dealer is not OBLIGATED to do so. Remember, it's a manufacturer's RECOMMENDATION that the tires be replaced at X age. Certainly there is a bargaining chip for you but the dealer is under no obligation to put new tires on for you.....Dennis
Dennis and Debi
Chevy HHR W/ ReadyBrute
Fourth Year Full Timing Click here to view our travel blog
Trap
Alberta
Once you've paid for a used coach, the dealer doesn't have to replace anything unless he misrepresented the coach, Even if he offered a warranty he would only be responsible if they failed. Not to replace them for age, especially when some tire manufactures state they are good for 10 years.
If you haven;t paid you definitely have some bagaining power or choice on buying it.
But are they responsible to change out 8 year old tires NO!!!!
UsualSuspect
Saugus, CA
I walked from a coach when the Dealer would not replace tires that were aged and cracked. Unless you have signed on the line and it is yours, you can either negotiate the replacement as part of the deal, walk from it, or buy it and replace them on your dime.
2007 Fleetwood Excursion 40E Cat C7 350 HP
2007 Chev 2500HD D/A Long bed CC
2011 Toyota Tundra
Gone but not forgotten, 2008 Jayco 299 RLS
fordsooperdooty
Stop the madness...if you can back out...do so. Unless you want to pay for new tires and delamination, bent engine valves, non-functional appliances and whatever else they can do to you!
If they are trying to pull a fast one now...imagine what they are hiding from you now too!
"Run Forrest, Run!"
ScottG
Bothell Wa.
Executive wrote: Since there is no federal or state MANDATE requiring the tires to be replaced at a certain age, the dealer is not OBLIGATED to do so. Remember, it's a manufacturer's RECOMMENDATION that the tires be replaced at X age. Certainly there is a bargaining chip for you but the dealer is under no obligation to put new tires on for you.....Dennis
I think this is the best answer here.
Besides, I would rather install tires of my own choice rather than the cheapest things the dealer can find.
Scott, Grace and Wesly
H0NDA eu2000i
