RV.Net Open Roads Forum: Tow Vehicles: scan guage question please
Search only in Tow Vehicles
 > scan guage question please
wolfcat1
Vidor, Tx.
Posted: 07/01/12 03:45pm Link  |  Quote  |  Print  |  Notify Moderator
My 03 Burb has a defective factory instrument cluster..the only thing that works properly is the speedometer and the odometers, Would installing a scanguage replace ALL the messed up gauges..?..Water temp, oil temp, and battery reading??..etc..
Thnks, wolfie
tvman44
Southwest Louisiana
Posted: 07/01/12 03:50pm Link  |  Quote  |  Print  |  Notify Moderator
Should.
Papa Bob
1* DW "Granny"
Husky 16K hitch, Tekonsha P3,
Quahog
SW
Posted: 07/01/12 03:53pm Link  |  Quote  |  Print  |  Notify Moderator
I have one for sale if you are interested. PM me.
Mike, Sue, and Buddy
2012 Ford F-150 XLT SuperCrew, EcoBoost, HD Payload/Max Towing
2010 JayFlight 22FB, Reese HP DC, Honda EU2000i
bmanning
Phoenix, AZ
Posted: 07/01/12 03:55pm Link  |  Quote  |  Print  |  Notify Moderator
I am a big scangauge fan; there is some variance vehicle-to-vehicle as to what gauges are available, but at minimum you'll get the "vital" gauges, IMO engine coolant temp & volts.
On my Land Cruiser I don't get engine oil temp, but I DO get transmission temp, which is very valuable. As you probably know, you can scan through and have the SC show whatever gauges you want to view.
My defaults are eng coolant temp, trans temp, volts, and MPG (so I can somewhat adjust my driving style to maximize economy). MPH comes in quite handy if you are running oversized tires and the factory speedo isn't spot on.
Dollar for dollar, I think buying a Scangauge is money very went spent for its utility, both as digital gauges and a code reader.
BManning
baking in Phoenix
2008 Ford Super Duty F250 XLT, 4x4, crew cab, 6.75' bed
5.4L V8 300hp/365ft-lb, 5sp Torqshift, 4.30 AAM gears
9400lb GVW 11200lb tow
2007 Volvo XC90 AWD V8
4.4L 311hp/325ft-lb, 6sp Aisin, loaded
6100lb GVW 5000lb tow
fordsooperdooty
Posted: 07/01/12 03:56pm Link  |  Quote  |  Print  |  Notify Moderator
Yes!
In my 2 Diesel F250's the gauges are only idiot lights with a needle...they show middle of the gauge then everything in normal, and will zoom up to the default position when the temp goes beyond the preset point, or oil pressure drops to a dangerous level.
The Scan Guage gives me real time, honest and accurite readings. Taking the ifo right straight from the Engine Management Computer.
wolfcat1
Vidor, Tx.
Posted: 07/01/12 04:09pm Link  |  Quote  |  Print  |  Notify Moderator
Thnks for the info guys, I have been on their website, and unsure which is best for my 03 "Burb...any suggestions?..need to monitor water, oil, tranny, and battery for sure..would this monitor my gas gauge correctly also??
thnks, for your help,
wolfie
wolfcat1
Vidor, Tx.
Posted: 07/01/12 04:19pm Link  |  Quote  |  Print  |  Notify Moderator
.....One more question, If I have a brake controller plugged in, is their still a plug in available for the Scangauge??
thnks again, wolfie
ib516
Up here!
Posted: 07/01/12 04:55pm Link  |  Quote  |  Print  |  Notify Moderator
Yes, the Scangauge uses the OBD2 port. Totally separate from the brake controller.
2010 Cougar 322QBS 5er
2007 Dodge 3500 SRW Megacab, 4x4, 5.9L Cummins, 3.73, 48RE auto
HYPERTECH MAX ENERGY or DIABLO PREDATOR tuning
MBRP 4" Turbo back
Scangauge2 for Boost, Coolant temp, Rail press & Trans Temp
Torklift Stable Loads
Desert Captain
Tucson
Posted: 07/01/12 05:03pm Link  |  Quote  |  Print  |  Notify Moderator
Wolfie, get the Scan Gauge, you will be soooo happy with it! The 8 to 10 percent fuel savings you will see will quickly pay for it. I bought mine primarily for the trans temp gauge but use it for far more than that, usually run with engine coolant temp, trans fluid temp, average and current mpg's . The fuel savings were icing on the cake and if you ever need a code reader it is right there.
tvman44
Southwest Louisiana
Posted: 07/01/12 05:18pm Link  |  Quote  |  Print  |  Notify Moderator
Got mine primarily for the tranny temp gauge also, but find the others very useful.
