RV.Net Open Roads Forum: Tech Issues: self contained portable ac unit
 > self contained portable ac unit
FunnyCamper
Southeastern
Posted: 07/01/12 10:21pm Link  |  Print  |  Notify Moderator
can I use one of these in my master bedroom in my 5th wheel?
I have one AC unit and it is located in the back bunkroom. one vent in front master. need it a bit more cool but don't want to add another AC unit at this time.
Can I use this?
Does anyone use anything like this to cool down a specific area in their camper?
thanks
KuulAire-PACKA45
KuulAire
christopherglenn
Near Yosemite
Posted: 07/01/12 10:26pm Link  |  Print  |  Notify Moderator
That is a swamp cooler, it will make things VERY humid. If it is already humid there will be almost no cooling, just more humidity.
2007 Chevrolet 3500 CC/LB Duramax/Dually 4X4 Mine r4tech, Reese Signature Series 18k +slider, duratrac, Titan 62 gallon, diamond eye, Cheetah 64
2011 Keystone Fusion 405 TrailAir & Triglide, Centerpoint, gen-turi, 3 PVX-840T, XANTREX FREEDOM SW3012, G614
FunnyCamper
Southeastern
Posted: 07/01/12 10:36pm Link  |  Print  |  Notify Moderator
yes [emoticon]
I have been reading on it. I realized that NOW (drat)
the reviews were not fab on it and suggestions to keep it near an open window...etc. etc.
not what I am searching for at all.
I hope there are other suggestions people do use???
edited to say I have been checking the 'real' ac units and they are big. even the small ones are big [emoticon] and have to be vented thru a window.
hmm...not sure if this is a good idea [emoticon]
chevyman2
missouri
Posted: 07/01/12 10:46pm Link  |  Print  |  Notify Moderator
There was a fellow up here in Mo. that had a PUP with some kind of portable A/C unit. He had it vented out the storage door. Though I didnt walk inside his PUP to take a look. I was standing by the door when he opened it, and the air coming from inside was every bit as cold as my PUP was with roof A/C.
Tim-DW(Kathy)
12 Chevy Sonic DD, 03 JEEP GRAND CHEROKEE, 2001 Jayco KIWI
If a "nightmare" is considered a dream-then I am living the dream
SooperDaddy
Posted: 07/01/12 10:53pm Link  |  Print  |  Notify Moderator
What you were tlking about was a basic "swamp cooler" that needs a dry/low humidity enviornment in order to work.
This is what you need...
Look here... for a post about "Portable Air Conditioners".
My posts shouldn't be taken for factual data, and are purely fictional, for entertainment purposes, should not be constituted as related to scientific, technical, engineering, legal, religious, spiritual, or practical advice. After all it's FREE! Amen. ">
LQuig
Idaho
Posted: 07/01/12 10:55pm Link  |  Print  |  Notify Moderator
Try google , there are some that would help
Pepperoni
Ypsilanti, Michigan 48198
Posted: 07/01/12 11:40pm Link  |  Print  |  Notify Moderator
You want a Portable Air Conditioner They vent through a hose to the outside. I would add a round screw-closeable (boat hatch type) port in an inconspicuous place to vent the hose. Some types come with an adjusatable window fitting
1L243
Oregon
Posted: 07/02/12 12:08am Link  |  Print  |  Notify Moderator
I ran a portable AC for a while before adding a second roof AC. I vented it through a side vent. The portable was 9 K BTU.
Adding the second roof AC was the way to go for me. TH was pre wired for Second AC so it was not real difficult.
* This post was edited 07/02/12 08:51am by 1L243 *
2017 Coleman 300tq by Dutchman Toy Hauler. 34.5 feet long and under 10k Gross. 1999 Ford F250 2WD 7.3 4R100 DP Tuner, S&B Cold Air Intake, Gauges, 6.0 Trans Cooler, Air Bags.
carpetguy2
NW IL
Posted: 07/02/12 04:34am Link  |  Print  |  Notify Moderator
I used one all the time in my TT.Mine is a 13500 btu.It came with a bracket to vent it out a house window.So I fabricated one for my TT.
2007.5 chevy 3500 ltz CC LB Duramax
2016 Open range 3x378
Some other toys too
FunnyCamper
Southeastern
Posted: 07/02/12 04:52am Link  |  Print  |  Notify Moderator
thanks alot everyone! good info to help me. will check out the links.
I am on the fence tho. put money into portable or just add that money into the second ac now. hmmm... [emoticon]
