RV.Net Open Roads Forum: Travel Trailers: Did I screw up my DeWinterize?
 > Did I screw up my DeWinterize?
Dashonthedash
CO
Posted: 07/02/12 06:56pm Link  |  Quote  |  Print  |  Notify Moderator
Many of the newer models have 3 valves for bypass (the older ones had only one) like the picture in bigbullelks's post. In bypass position, the lower (cold side) and upper (hot side) would both be turned off (vertical), while the left valve (bypass) would be on (also vertical), forcing the water through the bypass pipe instead of through the heater. For normal operation, which the picture shows, the bypass switch would be off (horizontal), while the cold and hot side valves would be on (horizontal), allowing the water to flow from the cold side through the heater and out the hot side. Remember that the "on" position is parallel to the pipe, while "off" is perpendicular to the pipe.
Gary Shapiro
Col. Dash - GSD, DOTL Rainbow Division, in my heart forever
Spc. Lily - 10-year-old Greyhound (Racing School drop-out)
Spc. Molly - 9-year-old Shepherd/Husky Mix (aka Honey Badger)
Shadow - 1 1/2-year-old Greyhound
2011 Georgetown 280DS Class A
1kennyOG
Canada
Posted: 07/02/12 07:00pm Link  |  Quote  |  Print  |  Notify Moderator
I just turned all the valves without much thought.(dummy me) I might even have 4.
Going to check in the morning but I think you all figured out my problem.
beermanjoe
Pa
Posted: 07/02/12 07:37pm Link  |  Quote  |  Print  |  Notify Moderator
If you have all the valves open,including your bypass.You may not get a lot of warm water.
PapPappy
Wilmington, NC
Posted: 07/02/12 08:06pm Link  |  Quote  |  Print  |  Notify Moderator
I'm thinking that you opened the valves to the water heater, before you flushed out the pink stuff.....so, it went into your water heater, and become stored there...showing up later on, when you ran the hot water.
Also, I think a 5-gal flush is not enough water....
Also, it sounds as if you left the bypass valve open, which is why your hot water isn't as hot as it normally is.
It's not hard to get confused with those water heater valves.....
Bill & Claudia / DD Jenn / DS Chris / GS MJ
Dogs: Sophie, Abby, Brandy, Kahlie, Annie, Maggie, Tugger & Beau
RIP: Cookie, Foxy & Gidget @ Rainbow Bridge.
Purchased April 2008 FMCA# F407293
The Pets
pianotuna
Regina, SK, Canada
Posted: 07/02/12 08:32pm Link  |  Quote  |  Print  |  Notify Moderator
Hi,
You may have not turned the bypass valve fully off.
It is best to flush--then do the valves.
Regards, Don
Kustom Koach Class C 28'5" 256 watts Unisolar, 875 amp hours in two battery banks 12 volt batteries, 2500 MSW watt inverter.
Terryallan
Foothills NC
Posted: 07/02/12 10:21pm Link  |  Quote  |  Print  |  Notify Moderator
I vote for this. Any antifreeze in the lines before the water heater. Will go to the water heater after you close the bypass. Solution. Next time run the faucets clear before closing the bypass valve, and opening the normal valve.
Terry & Shay
Coachman Apex 288BH.
04 F150, 5.4, Lariat SuperCab
Lazy Campers
1kennyOG
Canada
Posted: 07/04/12 07:41am Link  |  Quote  |  Print  |  Notify Moderator
OK I think I got it now.
donut dave
Burnett WI
Posted: 07/04/12 08:40am Link  |  Quote  |  Print  |  Notify Moderator
yup,that's it! just remember next time to be sure to flush all the pink out before opening up the flow to the hw heater.
RoyB
King George, VA
Posted: 07/04/12 08:45am Link  |  Quote  |  Print  |  Notify Moderator
Here in VA we dont really get a real hard freeze winter months (Maybe 2012 will change this)...
I use the BLOW OUT method using a low pressure 12VDC air compressor connected to the city fill connector using an air adapter. Drain the fresh water tank and hot water heater and then BLOW OUT all the lines for five minutes or so with all the spigots opened up. After all the water is gone from the lines then I will use just alittle of the pink stuff to pour down the sink traps...
Works great for us here in Virginia... These items are great to carry along with you in the RV TOOL box for those brief camping trips in the mtns where it get get below freezing for a couple of days. Only takes a few minutes to get ready for the freeze periods. Already have the 12VDC air compressor along to air up tires with anyway...
CAMCO ADAPTER 36153 (AMAZON)
Q-Industries MV50 12VDC Air compressor (AMAZON)
comes in nice carry case
photos from google images
Roy and Carolyn
K9PHT (Since 1957) 146.52M
2005 Flagstaff 8528RESS
POPUP PHOTOs-Pg52-Pg56
jerem0621
Sequatchie, TN
Posted: 07/04/12 10:46am Link  |  Quote  |  Print  |  Notify Moderator
Did you open the lower drains to get the pink stuff all out? I also use the blow out method. Works like a charm. Little pink in the traps and we are good to go.
Thanks!
TT: 1995 Layton 2910
Tow Vehicle: 1999 F-350, v10, 2wd, Crew Cab, Dually
Hitch: Draw-Tite Trunnion WD Hitch
Sway Control: Valley dual friction sway control
Brake Control: Tekonsha Voyager
"It's Kind of Fun To Do The Impossible"
~Walt Disney~
