RV.Net Open Roads Forum: Class A Motorhomes: Mid day Fantastic Fan
 > Mid day Fantastic Fan
down home
south
Posted: 07/14/12 10:16pm Link  |  Quote  |  Print  |  Notify Moderator
Good one fer yu.
Fantastic fan won't run in the morning but it will run during the day.
It won't run in the evening.
The lid opens but the fan won't kick on. fuse and switches are fine.
It hasn't rained.
daveshan
Durango Colrado
Posted: 07/14/12 10:22pm Link  |  Quote  |  Print  |  Notify Moderator
Strong union????
Sorry couldn't resist, The one in my truck camper has 2 knobs, one is the switch one is a dial thermostat, it it's turned up the fan won't come on 'till it's hot out.
If that isn't the case try wiggling wires/switches, could just be an intermittent lose wire or contact and the timing is just a coincidence
'99 Alpine 36SDS/8.3 ISC 330 Cummins
Or
'05 Lance 845
'06 Super duty SC/SB 6.0
Upgrades include: StabilLoads, Air Bags & Timbrens,Swaybars
Usually towing an '01 Wrangler, lifted/locked on 35"s or a mildly built '98 Cherokee on 33"s (only one locker)
FuzzyKnight
Santee, Ca
Posted: 07/14/12 10:39pm Link  |  Quote  |  Print  |  Notify Moderator
Yeah I was thinking thermostat also
Fuzzy and Mary
1994 Pace Arrow 33
1928 Model A
1953 Ford Club Coupe
1963 1/2 Falcon Ranchero Original factory V8 4 spd
1963 Fairlane SportsCoupe
1965 Honda SuperHawk
Kiwi_too
Western, WA
Posted: 07/14/12 11:06pm Link  |  Quote  |  Print  |  Notify Moderator
Thermostat.
May God bless your travels
Me, The Wonderful Wife
and two Spastic Border Collies
U.S. Army Retired
2004 Coachmen Aurora, 3480DS
2007 Saturn Outlook, FROG
tkcas01
Roaming Fulltimer
Posted: 07/14/12 11:12pm Link  |  Quote  |  Print  |  Notify Moderator
Mine is doing kind of the same thing. Lid will go up but the fan will not start at first. Then later it starts going. I think the motor is going bad. I emailed the company a few days ago and look forward to their diagnosis and hopefully the legendary free parts to fix it.
My last known location (is here)
    BobsYourUncle
    Surrey, BC Canada
    Posted: 07/14/12 11:33pm Link  |  Quote  |  Print  |  Notify Moderator
    Yup - check the thermostat. crank it down all the way and see if the problem persists.
    Or is that crank it up all the way?
    Anyhow, check the setting of the 'stat
    Duramax / Allison
    Fire Red
    95 Sportsmen 25.5' TT
    81 Citation 25' "Tail dragger" "Under construction"
    "Workin' man's rig"
    Bob's Trucks
    Check Out My Rebuild Project
    Project Feedback
    SCVJeff
    Santa Clarita, CA.
    Posted: 07/15/12 02:42am Link  |  Quote  |  Print  |  Notify Moderator
    Sounds OK to me, thats what they're supposed to do. There's 14 speeds on the fan, starting with OFF
    Jeff - WA6EQU
    SCVJeff
    Santa Clarita, CA.
    phays
    Ohio
    Posted: 07/15/12 05:20am Link  |  Quote  |  Print  |  Notify Moderator
    Not sure about the OP's problem but tkcas01's problem might be the motor switch under the lid. Go up on top of the rig, take a small wrench (sorry, I don't remember the size) and tighten the nut on the switch under the lid. Don't over tighten. This switch grounds the motor circuit when the lid goes up and sometimes corrosion keeps you from getting a good circuit.
    Johnworth914
    USA!
    Posted: 07/15/12 06:52am Link  |  Quote  |  Print  |  Notify Moderator
    X 7.
    Thermostat
    Alaska is next! Still trying to fit the pontoons to the RV so We can get to Hawaii!
