RV.Net Open Roads Forum: Beginning RVing: Camper T.V. outlets
 > Camper T.V. outlets
ru4nd2
Iowa
Posted: 07/26/12 09:47pm Link  |  Quote  |  Print  |  Notify Moderator
I have a 08 Rockwood 5er (8281ss). I have 3 places from the factory designed for tv hookup in the camper; one in the living room that, one in the bunkhouse and one in the "master bedroom". I can get over the air t.v. channels on the living room t.v. (which is the 12v model that came with the camper), whenever I want as long as the booster is on and I do a channel scan. Can I use the booster from the living room and roof antenna to get over the air signals on the other two t.v.'s? So far I have not been able to achieve this. I have two new t.v.'s for the bedrooms that are digital ready, etc. but can't get any over the air channels on them.
Do I need to buy seperate antenna's for these other two t.v.'s or can I achieve what I want to do using the excisting coaxial jacks in the bedroom with my excisting equipment?
Any info would help. Thank you.
portliz
Ontario
Posted: 07/26/12 10:16pm Link  |  Quote  |  Print  |  Notify Moderator
We have to scan each TV. Livingroom, bedroom and outside in storage hatch.
Us out West
Let's see...last night we stayed in......
Posted: 07/26/12 10:21pm Link  |  Quote  |  Print  |  Notify Moderator
Likewise....each T.V.is on it's own and has to have a scan to get going no matter if you are on the booster (air) or cable.
Our Trip Journal
2012 Jayco Pinnacle (View)
36KitchenPantryTripleSlide
MorRyde pin box and suspension
Curt Q24
Dual Pane windows
Auto Levelers
2 AC's
And more...
2009 Silverado 3500HD 4X4 (View)
CC,
Dura-Max 6.6/Allison
LB
DRW
American Tank 65 gal. Aux Fuel
Old-Biscuit
Across the USA
Posted: 07/26/12 11:00pm Link  |  Quote  |  Print  |  Notify Moderator
Do you have a distribution center that will send signals to the different TVs?
Set TVs to 'air'..'antenna'...vs 'cable' input (TV menu)
Then do a scan.....
2007 RAM 3500 QC LB SRW 5.9L CTD 48re 4:10 4K in bed 'quiet genny'
Hit the Road Free & Clear April '07
craig7h
Marion, Iowa
Posted: 07/27/12 04:26am Link  |  Quote  |  Print  |  Notify Moderator
The one ant. will provide signal for your three tvs. We have to do some guessing here. Where your Living room tv is you have the ant. outlet, do you also have the coax leads from the other tvs? If so you will need a three way splitter to feed the signal from the ant. outlet to the other tvs. Like said before you will also have to do a channel scan on all tvs. I see you live in Iowa if its eastern do not plan on getting two many channels.
Craig
06 RAM 3500 diesel power
08 35' Cardinal
Wherever I happen to park
Posted: 07/27/12 11:44am Link  |  Quote  |  Print  |  Notify Moderator
RV's usually have one of two TV setups.
Version 1: Is a wall plate with an antenna outlet, 12 volt outlet switch and LED (There may be additional plates without the switch and LED) Switch on is OTA TV, switch off is CABLE
The back side of the one with the Switch has either 3 or 4 antenna conectors, In order left to right with the 12 volt outlet at the top
OTA antenan, Park Cable, TV 2, TV 3 (Last is optional)
The other is a "Box of many buttons" Which is what I have.
WIth the wall plate the same signal goes to all sets.
NOW: here is the issue:
If the wall plate has only 3 connectors on the back, then a splitter is somewhere "Downline" of that plate, this splitter if well designed means you get 1/2 the signal at each of the other two tv's. If poorly designed 1/4.
AND what's worse you have many feet of lowest bidder RG-59,, Though normally this is not that big a problem (is for me, but only slightly).
There may be other issues as well, IE: some idiot stapling THROUGH the coax instead of around it.
Tsalla Apopka
Crystal River, FL
Posted: 07/27/12 12:05pm Link  |  Quote  |  Print  |  Notify Moderator
Ideally you would have a mmulti-meter. With two people you could diagram the wires and have the other person short each end while you watch for the short on the meter. Once you know what wires go where you can get signals where and when you want them.
Denny & Karen
Florida's Beautiful "Nature Coast"
Brit,TDI,BH & Claire,TDI (Belgian Sheepdogs)
Merlot - Sheltie rescue
Glady(Morgan Mare - retired),Toes & Beemer(Barn Cats-retired)
WA4OMG (Old Mangy Goat)
ru4nd2
Iowa
Posted: 07/28/12 12:47pm Link  |  Quote  |  Print  |  Notify Moderator
Thanks everyone. I am going to dig into it sometime tomorrow.
Kirk
Livingston, Texas.
Posted: 07/28/12 03:56pm Link  |  Quote  |  Print  |  Notify Moderator
Does the RV have a DVD player and a cable connection? If it does, there is probably also a set of selector switches to choose which of the three possible signals is sent to each TV. Our motorhome had two TV sets and there as a selector witch center with three choices for each TV set.
Good travelin! ........Kirk
Professional Volunteer
Fulltimer for 11 years,
URL: www.adventure.1tree.net
