RV.Net Open Roads Forum: Tow Vehicles: New Ford trucks
Search only in Tow Vehicles
 > New Ford trucks
WyoTraveler
Northwest, Wyoming
Posted: 07/30/12 08:47am Link  |  Quote  |  Print  |  Notify Moderator
Ford now thinks those PUs are built way too strong so the next line of Ford PU trucks are going to be built with aluminum foil and V6 engines. Ford spokesman claims the V8 is way too large for a PU truck. Actually the frame will be aluminum and over 700 pounds lighter.
Post moved from TT Forum to Tow Vehicle Forum
Moderator - TT Forum
* This post was edited 07/30/12 08:26pm by an administrator/moderator *
2013 Monaco Monarch motorhome
2012 Jeep Wrangler toad
AC6CV/7 ex-W8RUR since 1954
Turtle n Peeps
California
Posted: 07/30/12 08:52am Link  |  Quote  |  Print  |  Notify Moderator
outside the fire"
ktmrfs
Portland, Oregon
Posted: 07/30/12 09:15am Link  |  Quote  |  Print  |  Notify Moderator
per the article I read it quoted ford saying the frame will still be high strength steel. Body panels for the F150 will be aluminum. I guess I ended up with an entirely different take on fords position. I see the payload going up by 700lbs with aluminum body panels.
and ford says they still will have a V8 for the F150, although the ecoboost v-6 should be a great engine with 700lbs less empty weight to haul around.
2011 Keystone Outback 295RE
2004.5 Silverado 4x4 CC/SB Duramax/Allison
skipnchar
Topeka or somewhere else
Posted: 07/30/12 09:51am Link  |  Quote  |  Print  |  Notify Moderator
OK so what's your point? Are you disagreeing with them or agreeing? Yes they have plans of going with Aluminum bodies but I don't recall seeing anywhere that current trucks were too strong or that the new ones would not be as strong. They have PROVEN that the v8 is not the only engine that can power a truck (Dodge has already done that with the Cummins anyway) although they still offer a v-8 for those who still want them. Just trying to understand the point of your post.
Good luck / Skip
ScottG
Bothell Wa.
Posted: 07/30/12 09:54am Link  |  Quote  |  Print  |  Notify Moderator
Sounds like you think the aluminum frame is weak, I doubt that is the case. OTR Trucks and their trailers use alum frames and hold up just fine. Aluminum in the body works fine too and many cars have been built this way. The main reason more aren't is cost.
Sounds like a step in the right direction to me.
Scott, Grace and Wesly
H0NDA eu2000i
swebber
Brunswick , MD
Over the road trucks have had aluminum frames for years..
Steve Webber
'07 F250 6.0PSD LariatFX4 LB,AirLift,Edge,IFW BedSlide
'09 Jayco Eagle 324BHDS "CramalotInn III",Reese DCHP, Atwood 3500, BAL Deluxe Chocks, Weber Baby Q & Q200, Champion 2000W Inverter & 4000W gennie's
My Camping Pic's
hitchup
Fulltiming and on the Road.
Posted: 07/30/12 10:14am Link  |  Quote  |  Print  |  Notify Moderator
I remember when my BIL bought my DS a new caddy with plastic bumpers. We all laughed thinking it was actually going to save fuel after the 1973 Oil Embargo.
2009 DRV Mobile Suite 38TKSB3 (38RSSB3)....our custom home w/2011 upgrades
2010 Ford F450 KR CC 4x4......his office
Working Fulltimers since 3/2005
"Shoot for the Moon! Even if you miss it, you will land among the Stars."
DHCamper
Michigan
Posted: 07/30/12 11:09am Link  |  Quote  |  Print  |  Notify Moderator
We've been using aluminum body panels on our fire trucks for decades. They held up to the rugged treatment of the fire service for 25-30 years. Ford will probably be setting another benchmark with this one. And just when my buddy just got over my ecoboost running away from his Hemi. FT in a race!
* This post was edited 07/30/12 01:02pm by DHCamper *
mlts22
Austin, Texas
Posted: 07/30/12 12:41pm Link  |  Quote  |  Print  |  Notify Moderator
Due to the CAFE standards, either going with turbocharged V-6 engines or going with hybrid designs is the only way an auto maker can keep the MPG averages up to par.
Ford is going a good route with the EB engines. The torque and HP curves on the EB engines are surprisingly flat, almost similar to a diesel. I'm just hoping that they come out with an EB V8 that can do everything the venerable V-10 does.
The downside of the EB -- I'd be very leery of doing custom tunes with this engine, although the good places (5 star tuning) have workable flashes for it.
ripperoo
Akron, Ohio
Posted: 07/30/12 02:25pm Link  |  Quote  |  Print  |  Notify Moderator
Aren't the hoods already aluminum? Seems to me, when getting my 2001 F-150 fixed from hail damage, they told me the hood was aluminum.
2012 Ford F250 Super Duty, SC 4x4 XLT, 6.2L, 3.73 gears
2011 Keystone Sprinter Select 29BH
 > New Ford trucks
