joe0508
charlotte
Has anyone used those buckets that they sell at walmart that absorbs the moisture from inside the rv during storage.If so how well do they work.
joe money
crimmps49
Wisconsin
You must be referring to "damp rid". Yes, we use them in our rig when we store it for the winter here in WI. The base was pretty full when we uncovered them (2 sets) this spring. It doesn't freeze as it has an oily content. I don't know if they were necessary, but they didn't hurt anything either.
ScottG
Bothell Wa.
They work very well - I use them every winter.
Scott, Grace and Wesly
H0NDA eu2000i
phnguyk
NJ
I use them in the rv and basement of our home. 33' class a we use 4 at a time, they all seem to trap about the same amount of water. So I figured the more the better. In the house we use them year round, can't tell your in a basement(finished).
Fla Tom
Crawfordville Fla
I use damp rid in my clasic cars keeps them nice and fresh smelling the rv tub is a larger container of damp rid get two one in the front one in the back it works well
Bounder Lew
fulltimer Melaque Mex , site 33 Oceanside
Yes I have. You can also put them over your sinks so that the water can drain down the sink into your tank.
A lot in Melaque Mexico in winter and Victoria BC in summer - 2000 Fleetwood Bounder 31 W
V10
03 Tracker ZR2 Towed
Excalibar Towbar and SMI Stay in Play braking
joe0508
charlotte
Can you use them year round.Will they serve any purpose for the summer months.As well as the winter months.
rgatijnet1
A lot depends on the usual humidity in your area. Where we live on the West coast of Florida, with average humidity of 80%+, the typical Damp-Rid bucket gets filled in a few days. Obviously they work but if they only work for a few days, and you plan to store the coach for a few months, than I feel they may be a waste of money. Just buy one, open it up, and see how long it takes to fill with water. If they last as long as your coach will be stored, then go for it.
Airstreamer67
Pineville, LA USA
Good point about the amount of humidity. I, too, live in a Gulf Coast state with very high humidity. I use a 120-volt compressor dehumidifier and regularly remove quarts of water from the unit. It needs to be looked at every few days.
restorodder
Pinckney Michigan
We use the Damp-Rid in our Florida home,only because the previous owner used it under the sinks. While we are not there we control humidity with the A/C unit. We had a humidistat installed that turns on the A/C only to control humidity. The electric bill is only about $25.per month.
2008 Newmar Canyon Star - 2007 Dodge Dakota Toad - Ready Brute tow bar & brake system - one cat - Sassy 14
