RV.Net Open Roads Forum: This looks like a good way to add more batteries to your TC
 > This looks like a good way to add more batteries to your TC
dakonthemountain
Crestline, California
Posted: 08/02/12 04:08pm Link  |  Quote  |  Print  |  Notify Moderator
jimh425 wrote:
I'm not sure I like the implementation, but the idea sounds ok. It's interesting that it is only 24 and 27s. For the few times that you need extra batteries, and external 8D would be awesome!
Or a AGM.... It would seem that AGMs would be the best to put up there as they require no maintenance can be used upside down, sideways, etc.... but then out of sight can be out of mind too.. Just not sure I like the idea, but that's just me..
Dak
1995 Weekender model 910 extended cabover
Calvin, the 1996 creampuff Chev Silverado 3500 extended cab dually
Escapee #22435
DWeikert
York, PA
Posted: 08/02/12 04:18pm Link  |  Quote  |  Print  |  Notify Moderator
RZAR66 wrote:
How would one wire up that extra battery to the camper batteries?
Couldn't you just tap into the harness going to the socket/plug feeding the camper?
2008 Chevy D/A 2500HD ECSB
2010 Northstar 8.5 Adventurer
Bigfootchevy
Bancroft, Ontario, Canada
Posted: 08/02/12 04:50pm Link  |  Quote  |  Print  |  Notify Moderator
Great idea and useful if you need it.
Paul
RZAR66
San Diego
Posted: 08/02/12 05:07pm Link  |  Quote  |  Print  |  Notify Moderator
That would be before the camper isolator.
2011 Ford F-350 4x4 Regular Cab 6.2
2012 Lance 850
DWeikert
York, PA
Posted: 08/02/12 05:29pm Link  |  Quote  |  Print  |  Notify Moderator
My isolator is a solenoid in the engine bay. If your isolator is in the camper itself, you're right. That won't work, and connecting to a battery not physically in the camper would be a PITA (and I'm not talking about the bread)
wintersun
Monterey
Posted: 08/03/12 08:45pm Link  |  Quote  |  Print  |  Notify Moderator
Great way to donate a battery to thieves. Can't see how it would be a simple hookup to the internal converter(s) and camper battery or batteries. 8ga seems too light a gauge wire for the run from the battery to the converter and then there is the little matter of drilling another hole in the truck bed and making the connections each time the camper is put on the truck.
3 tons
CA.
Posted: 08/03/12 08:57pm Link  |  Quote  |  Print  |  Notify Moderator
Good grief! So what the heck do you know that is theft proof?? The 'Club' won't even stop a thief - all they do is saw right through it.
69 Avion
Phoenix, Arizona
Posted: 08/03/12 09:31pm Link  |  Quote  |  Print  |  Notify Moderator
I have built one similar in the past.
The one I built had a lip on top and two 5/16 all thread rod couplings welded to the top, horizontally. I then used an angle iron with a couple of tabs with 5/16 holes in it to correspond to the all thread rod couplings. This made the top adjustable so it could be tightened. The bottom was similar. Also, mine had to strips of Armaflex 2" x 1/8" insullating tape across it so that it didn't rub on the frame. I think they are a good idea and with modern batteries the mount is even a better idea. As far as theives, how many are going to look under there. Besides, put an alarm on the truck and any significant movement, the alarm will go off.
I don't like the idea of having a battery in a camper. We pulled out the battery from our 1969 Avion C-11 in the early 1970s. We installed two plugs for the camper, one for the regular truck plug and another that uses several terminals for + and several for -. With 3 sets of #10 wire, we have plenty of capacity. The last one I did, I just used two sets of #10 wire. That will drain a battery plenty quick.
Picture of a truck bed set up for my Avion. Notice the two plugs, one on each side, and the camper guides along with the camper forward stop.
* This post was edited 08/03/12 09:39pm by 69 Avion *
Ford F-350 4x4 Diesel
1988 Avion Triple Axle Trailer
1969 Avion C-11 Camper
Raften
Northern Calfornia
Posted: 08/03/12 09:34pm Link  |  Quote  |  Print  |  Notify Moderator
If I had a battery mounted on one of those I would not worry about theft anymore than I would worry about someone stealing the spare tire.
Mike, chime in here with a pic of your 8D mounted under the frame. I think I remember you use a tranny jack to drop it to service.
U.F.O.
On Canada
Posted: 08/04/12 04:28am Link  |  Quote  |  Print  |  Notify Moderator
Pre 65 Fords had the battery on the frame, with access cover on the floor, I guess whats old is new again!
1997 F-350SC 7.3 dually Eagle Cap 950 Honda EU2000
