RV.Net Open Roads Forum: Class A Motorhomes: Testing electric element for water heater
 > Testing electric element for water heater
tmmar
Nassau County, Long Island, NY
Posted: 08/07/12 01:10pm Link  |  Quote  |  Print  |  Notify Moderator
Does anyone know how I can test the electric heating element in my water heater? Had a problem a few days ago and wanted to rule out the heating element.
Thanks.
2008 40' Forest River Berkshire DP Bunkhouse
old guy
Oregon (pronounced Or e gun)
Posted: 08/07/12 01:12pm Link  |  Quote  |  Print  |  Notify Moderator
without a meter, the only way is to fill the water tank with water and turn on the element and wait about an hour and test to see if the water is hot.
tmmar
Posted: 08/07/12 01:21pm Link  |  Quote  |  Print  |  Notify Moderator
That was my problem, turned it on and no hot water.
I have a meter but when I put the leads on the terminals to the element, all I get is a spark and pop the circuit breaker.
rrupert
NW PA
Posted: 08/07/12 01:48pm Link  |  Quote  |  Print  |  Notify Moderator
You should not be testing the element with power applied. Turn of the breaker and disconnect the wires to the element. With an ohm meter check across the terminals for continuity. If there is no reading on the scale the element is burned out. Did you check the breaker to see if it was tripped?
Rich and Joyce
2010 HiLo 2310H
2012 Ford F150 4X4 Supercrew EcoBoost
Reese Strait-Line Dual Cam Hitch
Amateur Radio K3EXU
tmmar
Posted: 08/07/12 01:56pm Link  |  Quote  |  Print  |  Notify Moderator
Yes, I checked the breaker. I was testing with power applied to see if it was getting 110v to the element.
When I touch the leads to the meter the reading goes from 1 to zero. When I touch the leads to the terminals, the reading goes from 1 to -49.5. Don't know why this happens.
* This post was edited 08/07/12 02:04pm by tmmar *
rgatijnet1
Posted: 08/07/12 02:04pm Link  |  Quote  |  Print  |  Notify Moderator
With power applied, just use one meter lead on the element and the other lead on a metal ground to check for voltage.
dougrainer
Carrolton, Texas
Posted: 08/07/12 02:14pm Link  |  Quote  |  Print  |  Notify Moderator
You don't have your meter set up correctly. There is only neutral and Hot at the element and NONE will cause a problem if your meter is set to 120 volts AC. You should read 120 (line voltage) at those 2 screws. IF you have the Line voltage and after 2 hours no hot water the element is bad. Doug
Lobstah
Northeast
Posted: 08/07/12 02:27pm Link  |  Quote  |  Print  |  Notify Moderator
Make sure you understand what your meter should be set to measure.
If you want to make sure power is getting to the heater, put the meter on VAC, put on lead on the element contact, and the other on a good grounding surface, like the frame.
If you want to see if it's burned out, set your meter to OHMs, and put each of your leads on the two element connections, after disconnecting one, making sure the breaker is off.
If the element is good, it should read pretty much zero resistance, maybe a few ohms at best. If it's bad, then it will read infinity, or "open".
Jim
2005 Pace Arrow 36D
Very Understanding Wife
2 Boxers
4 Cats
tony lee
Mexico. Next stop Iceland. Then Patagonia
Posted: 08/07/12 05:36pm Link  |  Quote  |  Print  |  Notify Moderator
If you have tripped the circuit breaker a couple of times through your meter, there is a very good chance your meter is damaged too badly to be reliable.
Tony
Lots of photos with comprehensive captions at MY PICASA Album
Spotwalla map of our travels - Our Travel map
Ron8877
Blaine, Washington or wherever we park
Posted: 08/07/12 06:03pm Link  |  Quote  |  Print  |  Notify Moderator
Check the meter. It should be set to VAC. You should get 120 volts between the lead on the element and a ground. Turn off the power and check the ohms in the element. The resistance should be close to zero. However have false reading with a ohms meter. The best way to see if the element is good is with a amp meter. You put the meter on one of the wires going to the element, turn on the power and see if it is pulling any amps. If it is the element is good. If it isn't pulling any amps then you have to know if power is getting to the element. Thermostats go bad much more often than elements unless you turned the power on to the water heater with no water in it. If you did that the element is shot. It will be bad about 1second after you turn the power on without water in the tank.
Ron
Ron & Ali Workentin
www.ali1257.blogspot.com
