RV.Net Open Roads Forum: Travel Trailers: Cleaning Roof; Can I stand on Roof?
 > Cleaning Roof; Can I stand on Roof?
Abn1SG
Alabama
Posted: 08/10/12 06:50am Link  |  Quote  |  Print  |  Notify Moderator
Planning to clean the roof on top of my recently purchased 07 Kz Jag II 23 foot TT and want to make sure I can safely stand on the roof; don't want to learn the hard way by just going up there and then find myself going thru the roof. Thanks.
* This post was edited 08/10/12 07:00am by Abn1SG *
AtomicChicken
Central Louisiana
Posted: 08/10/12 06:55am Link  |  Quote  |  Print  |  Notify Moderator
I can't speak about the roof specifically but you can also use a brush with an extendable handle so that you can clean the roof without actually getting up on top of it. I do this and it works just fine.
2007 F-150
2006 Sun Valley RoadRunner 240BH
Prodigy P2 / EAZ-Lift WDH
sharker6
fulltime KY, NC, FL, MA, TN
Posted: 08/10/12 07:04am Link  |  Quote  |  Print  |  Notify Moderator
Try crawling to distribute the weight. If you hear a weird noise stop.
2009 30' Fleetwood Wilderness, 2008 F-250 Super Duty FX4 stump puller
naturist
Lynchburg, VA
Posted: 08/10/12 07:09am Link  |  Quote  |  Print  |  Notify Moderator
I bought a 16 foot extension pole and soft bristle brush for on it at Lowe's. It was cheaper than the longer ladder I woulda needed to climb up there, and works great. I don't even have to move the short ladder except once to hit the opposite side of things. If you are willing to move the ladder, a 6 foot pole will be enough.
clearnetedm
Alberta
Posted: 08/10/12 07:13am Link  |  Quote  |  Print  |  Notify Moderator
I can't see the back but is there a ladder? I'm not sure if it is standard but with our rockwood in some of the manuals it referenced that if there is a ladder it is safe to get onto the roof. I've been walking on mine since we got it last year without issue, it has a ladder.
2008 Ford Expy EL
2012 Rockwood 2601S
pbitschura
SE MN
Posted: 08/10/12 07:18am Link  |  Quote  |  Print  |  Notify Moderator
Use a walking board. I have a 2x6 foot piece of plywood which i carpeted for comfort, distributes the weight and is knee friendly.
1988 Mallard class c 24' Chevy chassis 350 cu gas.
Abn1SG
Alabama
Posted: 08/10/12 07:35am Link  |  Quote  |  Print  |  Notify Moderator
This is what I was thinking of doing it instead of getting on top of the roof. Thanks.
Abn1SG
Alabama
Thanks, this will be my course of action.
Abn1SG
Alabama
Posted: 08/10/12 07:38am Link  |  Quote  |  Print  |  Notify Moderator
No ladder...and previous owner was not able to find the owner's manual. BTW, anyone knows how I can go about trying to locate an owner's manual? Thanks.
doxiluvr
Tucson-AZ
Posted: 08/10/12 08:04am Link  |  Quote  |  Print  |  Notify Moderator
Yes you can walk on the roof. Use common sense and wear a soft rubber sole shoe, wash with a good rubber roof cleaner or even Spic and Span, use a soft brush made for RV roof, clean and rinse. Check your seams and caulking around the vents, airconditioner, etc. while you are up there. Blow off the roof and any slideouts first and do not walk on the slideouts. Otherwise, the main roof is made to be walked on so it can be cleaned periodically.
2006 Keystone Sprinter 300fkms
2007 Silverado 2500 Duramax Diesel 6.6 - Allison 1000 6 spd. auto. tran.
1 high school sweetheart hubby - 1 longhaired mini-dachshund, Hannah
4 grown kids, 6 grandkids
1 2007 Yamaha v-Star 1300
