RV.Net Open Roads Forum: Fifth-Wheels: Trailer tires
 > Trailer tires
Norskeman
Oswego, New York
Posted: 08/15/12 08:56pm Link  |  Quote  |  Print  |  Notify Moderator
Trailer tires are rated for 65 mph. Those that upgraded to truck tires did you do it to improve the speed rating or load rating?
I have 16 inch load range E tires on the fifth wheel.
2012 Cruiser Patriot CF335SS fifth wheel.
TV - 2011 Chevy Silverado 3500HD LTZ CCLB Duramax SRW 4X4
Don & Carolyn
Fulltiming
Posted: 08/15/12 09:02pm Link  |  Quote  |  Print  |  Notify Moderator
We upgraded to LT to improve the longevity/durability/peace of mind.
Don & Carolyn
2006 Dodge 2500 diesel 6 speed
2009 Arctic Fox 27-5L
donn0128
Pronounced Ore-gun
Posted: 08/15/12 09:14pm Link  |  Quote  |  Print  |  Notify Moderator
I really don't think people upgrade to LT tires to go faster. They upgrade to eliminate China bombs under their trailer.
Donn,Lorri,Max (The Rescued Lab)
Resident Know It All
laknox
Arizona
Posted: 08/15/12 09:18pm Link  |  Quote  |  Print  |  Notify Moderator
I can't afford the fuel to go > 65, so that's not in my book. Most change to get rid of junk tires.
Lyle
1936 John Deere Model A
popjim
Baltimore,MD
Posted: 08/15/12 09:25pm Link  |  Quote  |  Print  |  Notify Moderator
And exactly what are the junk tires? or china bombs as you call them?? what make and model tires???
2011 Jayco 26BH
catadjuster
Amarillo, Tx
Posted: 08/15/12 09:32pm Link  |  Quote  |  Print  |  Notify Moderator
I agree it is to get better tires. An E rated trailer tire generally has a higher load rating than a comparable size truck tire, so you are giving up a few hundred pounds carring capacity but should have a more reliable tire. Don't try to save $$ on a low cost tire though, If you are going to a truck tire spend the extra and get a quality tire. I am in the process of getting a set of Bridgestone Duravis 250's. They are a steel cased tire and appear to be one of the more reliable tires on this forum along with the Michelin XPS Ribs. The Goodyear G614's are probably the best choice but you have to have wheels that will handle the high pressure. They do come at a premium though!
04 Crossroads Silverado SF36MK, 5th Airborne & Curt Q5
2010 Dodge 2500 Laramie CC LB 4X4 (Waiting for chance to update photo)
Hellwig Helper Springs, Firestone Ride-Rite Air Springs
National Catastrophe Insurance Adjuster.
Home is anywhere at any time.
Chuck&Gail
In the Colorado Mountains
Posted: 08/15/12 09:35pm Link  |  Quote  |  Print  |  Notify Moderator
The DOT code tells you when and where tires were manufactured. All you need is the secret decoder ring. If you tell us the DOT code, we can answer.
Chuck
Wonderful Wife
Australian Shepherd
2010 Ford Expedition TV
FastEagle
Taylors, SC
Posted: 08/16/12 02:29am Link  |  Quote  |  Print  |  Notify Moderator
There is zero justification in calling a tire an upgrade when it, in fact, provides nearly 400# less load capacity at the same psi.
If you can afford the price increase from ST235/80R16E to LT235/85R16E you can afford a little more and get tires with the load capacity your trailer manufacturer has told you are needed for the safe operation of your trailer at any load capacity within it‘s GAWR.
FastEagle
Dickinson, ND
Jim Cindy
Northcentral, PA
Posted: 08/16/12 03:00am Link  |  Quote  |  Print  |  Notify Moderator
popjim,
If a trailer tire was made in China it is suspect. I can personally tell you that Duro tires are and should be refered to as China Bombs. We were extremely lucky to catch the bulges and bubbles in the sidewalls before any damage or injuries were caused.
PBH Portable Beach House
2008 GMC 2500HD Duramax Allison
2009 Cameo 34CK3
MorRyde IS, Disc Brakes, G614's
PullRite Super Glide Hitch
Propane fueled Yamaha EF 2400is
NC Hauler
Asheville NC
Posted: 08/16/12 03:23am Link  |  Quote  |  Print  |  Notify Moderator
Some in here have experienced blowouts which has caused additional damage to their RV with tires that were manufactured in China...If you go to the "Search" option in upper left hand corner of the forums and type in either "Tires" or "China Tires" you'll have more reading than you could digest in a year...These problems seem to happen with heavier 5th wheels, and other brands of tires, other than China made tires have had their issues also, just seems that the China tire manufacturers aren't held as accountable, or help the consumer out the way other tire manufacturers might do if their tire blows out or throws it's tread.
To the OP, as stated by others, most, and again, I say most, not all, "upgrade" from the beloved China manufactured tires because they have no faith in the tires that their TT or 5er is setting on...Speed doesn't really factor in to most, faster isn't necessarily safer....it's more for being able to hook up and go and not worry about one's tires possibly failing at any time into the trip...as another stated, "peace of mind" has a lot to do with it.
Just make sure you use the right load range tire that will handle the capacity of your rv's axles.
Jim & Kathy
2013 Dodge 3500DRW Longhorn 4X4/CC/LB/Aisin tranny/4:10/Cummins: 385HP/850TQ
06 HR Presidential Suite 37RLQ/ 4 slide/ dual pane windows/Winegard SK3005 Satellite/Splendide XC2100 W/D
Boxers;Buddy& Sheba II
USAF 71-75 Nam Vet
WVU fan
 > Trailer tires
