Jersey Jim
Middlesex, NJ
Does anyone have any thoughts on the best/easiest method to remove old cracked and warped vinyl decals from a fiberglass camper?
Jim, Donna, Kimberly and Kameron and Abby the black lab
2004 Gulfstream Conquest 30bhs
Ford F350 SRW 6.0 Power Stroke Crew Cab
Tom/Barb
Oak Harbor
Jersey Jim wrote: Does anyone have any thoughts on the best/easiest method to remove old cracked and warped vinyl decals from a fiberglass camper?
IF it is real gel-coat fiberglass you can wash them off with acetone.
try a small area where it can't be seen for a starter.
2000 Newmar mountain aire 4081 DP, ISC/350 Allison 6 speed, Wrangler JK toad.
hawkman541
Livingston, Texas
3M makes a decal remover that you can get at most auto parts stores. I used it and it works like a charm. Good Luck
2002 Ford F-450 Crew Cab
2004 Cameo Carriage 35'LXI
Frank-10lb. Chihuahua
cummins02
long island ny
I haven't removed old stickers from a trailer but at work we use "afta" very good removes stickers glue etc without harming paint from cars
Hope it helps
Good luck
2002 dodge 1 ton dually diesel
2012 jayco 32 bhds
Triple bunk outdoor kitchen
2 Honda EUI 2000s with parallel kit
me wife 3 kids and dog!
Captain_Happy
Abilene, Texas
I removed all the vinyl graghics off our Fiberglass Motorhome this year. All cracked and sun faded.
First I bought a heat gun as adviced by others on this forum, that sure didn't work out. left a really big mess of glue behind. Got out my razor blade scrapper and off the vinyl came. Hardly any glue left behind. Used Goo Gone to get the remaining glue off, which wasn't much. What's left behind is the area that's whiter than the rest of the rig. Masked and preped, and then re-sprayed with 2 step auto paint that I get color matched at our local paint supplier.
Now I wished I had taken before and after pics. even the DW says it looks great.
Denny & Jami
Home Base Nebraska
Let it set in the sun and get good and warm and start at a corner and pull them off, clean up the glue and what doesn't come off with mineral spirits and a plastic scraper. Don't get the mineral spirits on any of the silicon because it does a good job of removing it also.
Denny
2000 F350 SC DRW V10 4.30 gears, Banks Cat Back, BrakeSmart, Air Lifts
2003 HitchHiker Premier 35FKTG 215/75/17.5 Sumitomo tires
GaryGus
Sanger, California
Captain Happy,
I suspect that there are numbers of us out here that would like to try your paint project. If you could give us a little more info on how you did it, I know I would be apprecative. I'm asking about "2-step paint, spraying utensils and techniques,etc."
Gary and Donna
2009 Dodge Dually Quad Cab 3500 4WD
2005 Hitchhiker II 29.5 LKTG
"Greetings from the sunny San Joaquin Valley"
logansrun
Canada
Get urself an eraser wheel made by 3M that u use with ur electric drill....works like a charm, then some glue remover after that.....job done!!!!
j-d
Sunny Florida USA
The spray remover called "Sticker Shock" is basically WD-40 in a smaller more expensive package. When I removed graphics from fiberglass end caps, I used a scraper and WD-40. The WD didn't seem to be doing anything but then I could tell it was easier to get the scraper started.
Haven't used an Eraser Wheel but I've heard good reports about it in other threads.
God Bless, jd
2003 Jayco Escapade 31A on 2002 Ford E450 V10 4R100
Dick_B
Palos Heights, IL USA
Check out these suggestions from Mark Polk
http://www.rvtechtips.com/2012/06/remove-those-unwanted-rv-decals-and.html
Dick_B
2003 SunnyBrook 27FKS
2011 3/4 T Chevrolet Suburban
Equal-i-zer Hitch
