Double W
Milton, WA, USA
Pulled into Stubb Stewart State Park in NW OR and hooked up. Monitor read 50 amps and everything worked. Got up the next morning and turned on the coffeepot. A few minutes later pushed down the toaster and everything died. Batteries were down to 11.8V. System shutdown, b ut AC's both still worked. Checked all the fuses, inverter fuses, etc. Started the gen and everything worked including the batt charger. Finally scratched my head and called Monaco LLC. Tech told me to check that the post was hot on both sides (even tho the system monitor still read 50A). Asked the local ranger to check the post... and they found that one side was dead. Now it
Double W
Stock 2004 Dodge 3500 4x4 drw 5.9L Cummins HO, Auto, 4.10, Line-X
Hijacker 16k Dbl Pivot, BrakeSmart Controller
2003 Jayco 3630RKTS Designer Legacy 14.5k lbs loaded
gcvw 22.5k at WA scales
Executive
That's why it's important to know exactly what's in the pedestal box BEFORE you plug in. There's an easy to make tester, see link below, with parts readily available from your local Home Depot. I made one in about 45 minutes....check it out...Dennis
50 amp tester
Dennis and Debi
Chevy HHR W/ ReadyBrute
Fourth Year Full Timing Click here to view our travel blog
byronlj
Arizona
You might want to check your CB panel to see how it is wired for load balance. Most manufacturers don't hook up both AC's to the same hot leg of a 50a circuit.
Dave
byronlj
07.5 Silverado LTZ Ex. Cab 3500HD dually 4X4 duramax LMM/allison 6spd
07 HR Presidential Suite 37RLQ
Big Katuna
Deland, FL
What kind of monitor do you have that said your 50 was good?
My Kharma ran over my Dogma.
brobox
Sunny SW. Florida
Excellent idea Dennis!
Double W, do you have an Electrical Management System wired in your MH? Mine will not let power into the MH until it passes inspection.
Chuck
02 Travel Supreme, 2 street side slides
09 Toyota Tacoma 2WD
garym114
Bluff Dale, Texas
With a Multimeter
50 amp
The voltage between Y and X should be 240-Volt.
X and W, 120-Volt - Y and W, 120-Volt
X and G, 120-volt - Y and G, 120-volt
W and G, 0-Volt
30 amp
The voltage between the Hot lead at 7 o'clock and neutral, 120-volt Hot lead and G, 120-volt
Neutral and G, 0-volt
Get a multimeter and learn how to use it.
edited 08/23/12 06:47am by garym114 *
rgatijnet1
The only problem with a multimeter reading on a park post is that it just tells you if there is any voltage present at all. It does not tell you if the pole outlet has the capacity to furnish the amperage that you may need. In other words, if a single strand of a wire makes contact in a loose connection, you will read the correct voltage but that single strand cannot supply 50 amps of current.
We all are familiar with the problems we can have in our coach if a battery connection is loose or corroded. The same thing can happen at a RV park pole. This is where a good EMS is necessary. This will not only confirm the presence of voltage and the correct polarity, but it will also alert you if one leg cannot supply the voltage/amperage needed for proper operation.
PandK
Greenville, SC
I like the tester Dennis has a link to.
My personal preference is the Progressive Industries unit which will constantly monitor the incoming voltage. Saved us several times.
Check here
edited 08/23/12 07:55am by PandK *
Paul and Karla
Cinnamon & Pequeno - Spoiled Rotten Chihauhuas
2004 Rexhall Rexair DP3955
2013 Chevy Traverse
wny_pat
Western NYS
Double W wrote: Now it "Now it" what. The rest of the story please.
Wherever I happen to park
I agree with the NOW it.... NOW IT WHAT.
As for the home made tester, Nice device but I need one that monitors INLINE.
If I can talk my wife into cutting out a day early I'll get the parts but my plan is this.
I have an autoformer, installed, I will replace the box on the outlet part of the install kit with a slightly larger one and install two fused transformers (Very small fuse) 12 volt No reason do do this save for I'd rather play with 12 volt. One will be X-W one Y-W. These will run to a pair of AC-Voltmeters. I may also meter some other stuff just for fun. Include a NEON indicator from W to G as well (posibly from X and Y to G as well) Combining all functions in one indicator box.
These will measure IN USE voltages. PRE autoformer no less.
