RV.Net Open Roads Forum: Largest Trailer with an Actual Weight under 3500 lbs?
 > Largest Trailer with an Actual Weight under 3500 lbs?
MacManOne
Full Time Somewhere in the USA
Posted: 10/21/03 11:42am Link  |  Print  |  Notify Moderator
I'm new to this forum and I've found some very good information here. The tip about looking inside the kitchen cabinet for the factory weight sticker is a good one! And, before I buy, I'll be doing a test tow and visiting a truck scale.
There are a lot of "lite" trailers out there. So, what is the largest trailer you know of with an actual dry GVW under 3500 lbs?
Thanks in advance.
Mac
erupert
Churchville, Maryland
Posted: 10/21/03 12:19pm Link  |  Print  |  Notify Moderator
You should be able to puruse the websites of all of the "lite" manufacturers. Most of the TT manufacturers have a line of lightweight trailers. Maby save weight by using canvas pop-outs on each end which gives you nice center area without needing a 30' TT. However, you need to accept the canvas as part of the tradeoff.
'95 "Free" Fleetwood Rio.
MacManOne
Posted: 10/21/03 01:50pm Link  |  Print  |  Notify Moderator
Thanks erupert. Just to clarify, I'm looking at regular "lite" TT's, no canvas.
I've been looking at the offerings from Fleetwood, (Dakota and Lynx) Doesn't appear to be much difference between them if at all.
Seems we can get a 25 Dakota or Lynx and keep close to our target. (looking under 3500 dry so we can stay under 4800 loaded).
Any ideas of comparable or larger trailers at same weight? I realize length isn't measured the same on every model either.
JPC
Essex County, MA
Posted: 10/21/03 02:29pm Link  |  Print  |  Notify Moderator
Macman,
Check out the TT in my sig. Forestriver makes Rockwood, Flagstaff and Surveyor ultra-lites. They have units as large as 25' and 3600# dry weight with options. These top out at around 4600# GVWR. Do a search for these on this forum and you'll see alot of positive comments. Good luck.
The Four Of Us
2004 Rockwood 2501
2003 Chevy Avalanche Z71/5.3L/3.73
Reese Dual Cam
Prodigy
camper26
Lancaster PA
Posted: 10/21/03 02:53pm Link  |  Print  |  Notify Moderator
MacMan,
I have a 2004 Surveyor SV263 this TT is 27'overall length. It has a dry weight of 3910#. We have a slide out, queen bed, microwave, oven, shower, dinette, CD player, Air, etc..Sleeps six easily. With our options we are at 4290#. I tow with a 2000 Durando 5.9L. Check out Forestriverrvs.com. We would recommend to anyone. Good Luck
2013 Silverado 3500HD 6.6L D/A 3:73 4x4,CC,SRW
2008 Fuzion FZ302 Toy Hauler
2014 Harley Davidson Street Glide
MacManOne
Posted: 10/21/03 03:25pm Link  |  Print  |  Notify Moderator
Thanks,
I looked at the Rockwood, Flagstaff and Surveyor. Also read many good comments about them on this forum. What's the major difference between the 3 brands? Seems that the Flagstaff may be more basic, Surveyor more of a premium product, and Rockwood a good middle choice. True?
Mac
JimInMich
Mi
Posted: 10/21/03 05:48pm Link  |  Print  |  Notify Moderator
See me sig for a real light weight 18'
Jim
Current: 1987 Georgie Boy Encounter 34',John Deere chassis,460c.i./C6.
SOLD-2012 Cougar XLite 27RLS
SOLD-2008 Aerolite 24FB
SOLD-2004 Shadow Cruiser Fun Finder 189FBR
Just the Wife and I.
glowbyjoe
Marshfield, WI
Posted: 10/22/03 08:31am Link  |  Print  |  Notify Moderator
The Palomino T-26BHSL has a dry axle weight of 3445lbs. The hitch dry weight is 291lbs. Total = 3736lbs. The trailer is 26'9 in length. It's the lightest Iv'e seen.
Joe
2003 Toyota Sequoia Ltd 4x4
just sold Coleman pop-up
looking for new ultra-lite TT
Hank2
Laconia, NH
Posted: 10/22/03 01:27pm Link  |  Print  |  Notify Moderator
Hey Camper - I don't want to start a controversy here, but I am suspicious of the weights you have submitted. ?Did you ever weigh this TT dry? ?Did you weigh it loaded? My apologies if I have erred, but the dry weight seems low to me if it includes all the options you have listed. Also, wet and loaded, 1000 lbs for 4 people seems unusual.
Hank & Pat in New Hampshire wishing you-all safe journeys: Toyota Tundra (V-8, 4wd, 4.75L.,245 hp) Roadmaster Active Suspension; Nash 22H travel trailer, PullRite Hitch, Prodigy Brake Controller.
We would never tow a single axle trailer of significant weight again.
WHEN IN TROUBLE - WHEN IN DOUBT - RUN IN CIRCLES - SCREAM AND SHOUT!
osbornk
Marion, VA USA
Posted: 10/22/03 01:49pm Link  |  Print  |  Notify Moderator
The Flagstaff and Rockwood are identical except vcor the name (like Chevrolet and GMC trucks). Thre Surveyor is a little more upscale. I have a 25' Flagstaff. It has a base weight of 3133 but with hte options we chose (most of them), it weighs 3,635. It tows very well because of the light weight, 7 1/2 feet width and it is aerodynamic and low to the ground. We have been very happy with the Flagstaff with no problems.
04 Ford F150 XLT 4X4,5.4L with 3.73 & regular cab
04 Flagstaff 25D
Equalizer-Prodigy
