Last MH was a gas unit that had been sitting for a few years. Got sold to a dealer and I got a "great deal" on it. Drove fine during the test drive and on the way home, about 75 miles total. Next trip out it started losing power and ultimately wouldn't go faster than 25 mph.
Problem turned out to be rust particles in the gas tank. A LOT of rust particles, resulting from the 3 1/2 gallons of water I siphoned out of the tank. The rust particles would get sucked up to the fuel pump pickup sock (first line filter) and starve it for gas. When I stopped the rust particles would settle away and it would run great for a couple miles.
The solution was to thouroghly clean out and seal the tank since a nationwide search using 3 independent sources couldn't come up with a new tank. I used a couple of pounds of dry wall screws as abrasives and rolled the tank around the yard. You don't shake an 80 gallon tank in your hands like you would a motorcycle tank. Then I rinsed it out with water a couple of times followed by a couple of rinses with acetone.
After it dried it was fairly clean but with all the baffles, there was no way to get all the rust out of it. After doing a bit of research, I used an epoxy sealant from Caswell Plating. It was spendy and a lot of work, but it was a great solution for me.
I don't think I have enough money to have work like this done.
edited 07/10/11 09:54am by roadhousecharley *
05WAF350 wrote: Not knowing exactly where this goes so my question is we have Good sam emergency road side assistance, first time we used it in 5 years. We were in our POV, not towing and located at Seattle/Tacoma internaional airport. Returned to a dead battery and could not get assistance for a jump for over 3 hours. I would call and they would say we will have somebody to you in 30 minutes but they would not show. This went on 3 times and we finally arranged for and paid for and got the truck started ourselves. Of course, as we are getting it started at 11:45 pm somebody shows up, writes down the vin number, asked me to sign and off they go. I was happy somebody eventully showed but 3+ hours later in the city seems a lot to long to wait. Do others have this kind of poor responce from roadside assistance or did this look like a one time issue.
Don
I've had fairly good luck with Good Sam Roadside Assistance. Used it 3 times. Had to wait an hour once but that was early AM in Northern VA traffic and they woke the guy up to tow my car.
Bought this unit (our 4th Class A) in August of 2010. On our 3rd trip from Regina, SK to Calgary, AB, I had a "low water" warning for low coolant. I pulled over and inspected everything and found no leaks, topped up the radiator and continued on. Within 100 miles I had the same low coolant warning. Again topped up the radiator and found no leak. When we finally stopped in Calgary and stayed the night, I crawled under the engine and had a good look with a flashlight. I found that the engine block was cracked (behind the turbo) and had been patched with steel epoxy. Someone had patched the block prior to my purchase. The coolant was evaporating as quickly as it leaked which led to no evidence of a leak. The only reason I was never stranded was that because I was in a RV, I carried enough water to top up the rad and continue on.
Long story short, the Cummins 5.9l blocks stamped "53" are flawed and known to crack. If you are buying a unit with the Cummins powerplant, inspect this closey and stay away from anything with this block.
I have since replaced the entire engine with a factory rebuilt #51 block with 300hp injectors and it now runs like a top. It has very good fuel economy (lows of 10.4 MPG, highest 14.2 MPG) and all kinds of power.
Bob
edited 07/31/11 10:38pm by missscarlet9 *
RV particulars: Dodge B300 C-class, Beaver Monterey
Driveline (Engine, Transmission): 440-3 / A727
Miles:55,000
Year: 1976
Break Down Description: (You can add any description of the problem here that you think would help others in understanding the situation and problem.)
Symptoms: Won't start after sitting in storage
Effect:
Cause: corrosion on the coil pickup sensor
Outcome: by chance I measured the tolerance in the pickup and by doing so cleaned the corrosion and it fired right up.
2000 Rexhall Rose Air
Ford F-53 with 210hp V-10
126,000 miles
US Highway 421 between Wilkesboro and Boone NC
Blew a sparkplug - 4th from rear on left bank
Called Good Sam Road Service at 12:28 August 29, 2011
fonecon results:
I clearly told phone rep I needed a shop that could work on a Ford V-10 engine;
Boone Ford claimed to be busy
Good Sam rep said Robert Handy Camping in Wilkesboro could do the service;
At 01:30pm Good Sam Rep said a tow company had been contacted and would arrive within 100 minutes;
Mountain View Towing arrived at 3:00 pm, very professional, towed to Robert Hamby Camping - THEY DON'T DO ANY ENGINE OR CHASSIS SERVICE!
Moved up road to truck stop where Mountain View Tow operator waited while I drove over town looking for a service shop. Couple of leads were dead. Advanced Auto Parts clerk was my savior. First lead declined to service. Second was small home based mechanic who didn't have room in shop, but said if I could get it towed to a Food Lion parking lot near him he would look at it and thought he could fix.
Mountain View Towing had waited while I searched and towed the MH to Food Lion where I received permission from the manager to park it waiting service.
5:30 pm Ronnie (home based mechanic) arrived, found blown plug and left to get plug and coil replacement;
6:15 pm Ronnie returns with parts, replacement plug different type, but apparently authorized replacement, wouldn't tighten; need helicoil, will return in morning to install.
Lessons Learned:
1. I should have called Robert Hamby Camping to verify they could do the service. They claimed Camping World had not contacted them. Apparently they did a "Google" for RV service.
2. Never trust Camping World Road Service to find you a shop capable of doing the repairs needed.
Edit 1: Plugs installed 8 years ago at 42k miles.
I apparently have the "4 thread heads" on my V-10
Plug blew at normal cruise power.
Wes
"A beach house isn't just real estate. It's a state of mind." Pole Sitter in Douglas Adams MOSTLY HARMLESS
HELP HELP... any1 have any ideas in ref to my NORCOLD 1200LR i just had a recall done... new icemaker installed and a recall fixed.... it was working wonderful.. until the other day NOTHING it stopped wprking.. i checked the breaker... power to all the house just not refridgerator.. ANY OTHER things i can check b4 it goes to the shop..... I APPRECIATE the HELP
PM sent
JohnnyT Moderator
edited 09/05/11 03:29pm by an administrator/moderator *
Probably lost the ammonia refrigerant thru a crack in the tubing or weld. Look for the color deposit of yellow or green where the amonia may have escaped.
Found in a Dometic last fall, solution was a new refrigerator.
2004 Winnebago Itasca Spirit
Ford E-450 with V-10/Auto Trans
Problem: Engine started missing on return trip from New England in June. Labor Day weekend engine would not start. Diagnosis: Fuel not getting to injectors. Repair: Fuel Pump found to be defective; replaced same.
Coach Net Roadside Service got me a tow but had to wait overnight in rv park due to holiday. Tow arrived early next AM towed me to Knoxville (40mi.) Had to wait another night for new fuel pump to be delivered from parts house. $1200. labor and parts. Coach Net paid $600. tow bill. Very satisfied with overall experience. First major breakdown with my RV.
edited 09/29/11 10:15pm by noe-place *
2005 Holiday Rambler Neptune
Cummins 300 hp/Allison
35000 miles
Problem: ABS light lit, engine seemed low on power.
On way west from Brandon, MB. Towing car, first time with this MH.
Condition worsened and eventually we had to stop. I checked that everything seemed to be normal in battery compartment. All "OK" but did NOT use a multi-meter..
Last year we had similar trouble and eventually the alternator was reconditioned in BC.
By using the generator and jumper cables connecting engine and house batteries we limped to Swift Current, SK. I wasn't too happy about using the cables. Tried about 6-7 places in S.Current but no place could, or perhaps, wanted to find the problem. Most were too busy.
Limped further west to Medicine Hat, Alta. with my wife driving the car.
Same problem, most places too busy. An rv tech who was passing volunteered to find the problem. I told him I suspected the alternator. He found the alternator was not functioning well.
Next day we found a shop, told them to install a new alternator. two hours later we were on our way. Problem solved. Engine had lots of power. Moral...check electrical system before leaving and, for me anyway, never install reconditioned items.
This is a breakdown incident on our 2004 Itasca Meridian, Freightliner chassis, Caterpillar C-7 engine with 48,000 miles on it.
Upon exiting an interstate hiway in Wisconsin, the engine died when pulling up to the stop sign on the off-ramp. It simply would not start. After many attempts and after putting the accelerator to the floor when cranking, it fired and roughly came up to RPM. It ran rough after that so I had both fuel filters changed. That didn't work, it still ran rough, misfiring at lower speeds. I took it to the nearest Freightliner dealer and they diagnosed it at a faulty HEUI (Hydraulic-Electric Unit Injector) or fuel pump. After it was replaced the engine ran fine. However, the Freightliner service dept. contacted Caterpillar and was told that if there are any metal particles found in the old HEUI, all six injectors should be replaced. Since the engine ran ok at cruise speeds, I elected not to do this due to the high cost. We drove it back to Arizona and it ran just fine and appeared to have more power than ever before.
In summary, it appears that Caterpillar installed poor quality HEUI's on 2004 C-7 engines, I learned this from several RV forums. I would be interested in how many of these specific problems with the Cat C-7 are mentioned in this forum topic.
Retired USAF Nav/Flight Ops
Itasca Meridian 34H
330 Caterpillar
2010 Chevy Equinox
Blue Ox and Brake Buddy
