Dick A wrote: RV particulars: Rexhall F-53 chassis
Driveline (Engine, Transmission): Ford 460, E40D transmission
Miles: 32,000
Year: 1994
Break Down Description: (2002) Engine stalled on warm day at St. Charles, MO
Symptoms: engine popping and backfiring, no power.
Effect: Engine hot and stalled - symptom was like vapor lock.
Outcome: Let engine cool. Engine then started and made it to RV park (Sundermier). Stayed a few days, checked all fluids, changed fuel filter on frame rail. Continued trip. Would run ok as long as we were at highway speeds. Would stall sometimes when pulling off to fuel. Managed to get home a week later after a stop in Wyoming. We had the thermostat changed there, but no help. I had ordered a full Banks system before leaving for trip. During subsequent installation, found radiator plastic tank seal broken. Replaced radiator. Also, several exhaust manifold bolts broken, causing excessive heat in the engine area. Probably causing vapor lock problems. Replaced one head with broken manifold flange, had all valves replaced on both heads, water pump, hoses, fan clutch, etc. Changed all fluids to synthetic, added B & M extra capacity transmission pan and transmission temperature gauge. No problems in 2003 traveling over 8500 miles. Preventative maintenance before 2004 trip: Replace in-tank fuel pump known for early failure.
Problems with your 2002 Rexhall? I would think that it being not that old that your manifold bolts should not have been broken, unless someone tightened them down too tight at some point in time.
Also your fuel pump being replaced as a preventive maintanince action is a good thought. Would that have been a factroy recall thing that they would cover the cost ?
We are getting ready to buy a 2003 Rexhall Rose Air. Is the fuel pump on the 2003 model something that I should ask the present owners about ? Was that a big expense to replace ? Good luck with your RV. Sounds like you've taken all the precautions to prevent any future breakdowns. Thank you for your story. It is one that we will not forget because of our soon to be Rexhall owners. Dave Packard
Breakdown description: Pulling into a rest stop, shut engine off. About 40 minutes later, while pulling out of rest stop, pouring the coals to the MH to get out into traffice,lost all power, big back fire. Check engine light came on and a couple more lights came on for an instant. Then power came back, but it was scary out there. If I take off slow, it's okay, but dangerous.
Outcome: Primary fuel filter fuel line that goes to engine has very soft rubber - it goes over the engine computer on its way to the engine. Power cables coming from battery compartment go over the fuel line and smashes it almost flat. Solution: Rerouted fuel line - so far, so good.
al
So where was the back fire noise coming from ? Dave P
How do I make this short? We own a 1996 Holiday Rambler Endeavor with a B series Cummins. While having a PM performed the shop found a fuel leak emanating from the front half of the vehicle. A local shop said the fuel tank had to be dropped and couldn't handle it. We ended up traveling 50 plus miles to a diesel repair facility located off of the interstate. As it turns out, $700 later the tank was dropped and the fuel lines to the generator; which were dry rotting, were replaced. Here's the rub and somehow it's all connected. While jostling the tank, apparently all kinds of gunk was loosened in the process. Also, there was a loss of fuel pressure somewhere down the line. Things then failed in progression over a 4-6 week period. We lost the fuel solenoid shutoff valve and then the lift pump. Along the way we replaced three fuel filters, including the lift pump filter which failed on the trip to check everything out. The moral of the story is to regularly treat your tank with a good quality biocide and fuel treatment and to have pm's performed regularly. As older coaches become more affordable, more people are going to have these problems. If you buy one have a mechanic thoroughly inspect the coach; you'll be money ahead.
In late July, on returning from a 1,200 mile trip, I noticed my F53 rear axle seal leaking, badly. Oil coating all over RR Duals and rear of camper. The unit was purchased new last fall and has 5,500 miles on it. We live in east central Illinois. I called Ford Assistance for guidance since our local car dealer did not want to look at it. (38ft long, 12ft high). I finally got through to Ford RV Warranty Service, (800) 444-3311, and they suggested other Ford dealers within 30 miles. I called each of them and no luck. Ford then said If I paid an independent repair shop up front, I could submit the bill to Ford. The independent needed to use authorized Ford parts and procedures. Ford said a 2 hour job.
August 5th the MH went in to a big truck independent (with a good local reputation). I had discussed it with the owner, and he had inspected the unit. They had spoken to Ford and ordered the parts (seal and brake pads). I kept the parts that were replaced and I submitted the bill to FORD. I even took a couple photos.
Update:
I had the independent shop do the repair to the leaking axle seal in August, and I sent the claim for reimbursement to Ford as directed.
Today, December 8, 2008, I received a check for the full amount of the rear axle repair from FORD Motor Co.
I am very happy with the results on this warranty repair claim on my motor home.
Ford RV Assistance is (800) 444-3311
I started with nothing... and have most of it left.
Damon Challenger 377c
Toyota Yaris Dingy
Scottish Terrier
We have a 2008 Fleet wood Providence 40E. The dealer install a rock guard on the coach. We drove it home and discover the rock guard had bent and damage the underside of our coach. This is a fleet wood design rock guard for the providence. We were told the reason it was not install because this rock guard would damage the coach . It is a standard manufacture item. Have anyone had a problem with rock guard damage on a fleet wood motor homes.
being an owner of a '97 ford class A and having the stall problem several years ago, Heck of a vacation. You can probably search for the fuel pump problem and see myself and several others who have experienced this issue. Anyway, It was the fuel pump, in the fuel tank. It cost around $850.00 about 3-4 years ago. They can do a fuel pressue test at the dealer and let you know if it's the fuel pump. It makes things easier if your tank is empty or as close as possible when they work on it. Get it fixed now, don't wait until your on a trip and you have all kinds of problems and pay more to have it fixed.
Ed/Jan
Smile! and have a nice day.
USMC Retired '87
97 36' Georgie Boy Cruise Air
Banks Power Pak
99 Nisson Frontier
A year ago, February: Got the m/h out for a trip south and west to Wadena (about 2 hrs), while it was warming up in the driveway, my wife attempted to back it up-no reverse gear!! I did all the troubleshooting, called Allison, confirmation that the reverse gear was toast (96k mi. on m/h). I called and web searched for an affordable replacement, Mills Big Truck/Ford in Brainerd, MN was able to get me a factory rebuilt w/12 month warranty for $1500.00 plus tax and shipping. I spent a good part of May (and around $1800.00)in the r/r of the unit.I also did a complete brake job and replaced a few tires at this time, so my final bill ran about $2900.00 on completion.
For everybody that has an Allison 542, be aware that if you hear a funny noise in reverse, you'll lose the reverse gear (mine took about 6k mi. after the noise before it was gone). Allison no longer makes or rebuilds the 542 series due to this problem, the 545 which I now have is the direct bolt in replacement, it was an option when the 542 was installed, but most m/h manufacturers as well as school bus and trash truck mfg all went the cheap route with the 542. The reverse gears are smaller on the 542 (less meat on the teeth etc.),so with the heavy loads required to move, eventually all the teeth strip, and you have no reverse.
'91 FRED 35' Oshkosh Journey ('89 chassis)
'93 6BT5.9L Cummins 230 HP TC wastegated/intercooled,Allison 545 4 speed
'74 Jeep CJ6
'80 Suzuki GS850L
FMCA F326065
Pine River, MN
USNret '95
Sorry to be posting to this thread, but....
!996 - Bounder; 34'.
Chevy P30 chassis with 454 engine and 44k miles.
Driving North on I75 just past I275, and I, thankfully, had cleared the construction zone, and it just died! No electric, no nothin'. I coasted to the side of the road. Called for a tow. After about an hour and a half, I heard a clicking. It was the emergency flashers. I then turned the ignition key and it started right up. Cancelled the tow and continued on home. Taking it back to the dealer for a checkup in a week and a half (earliest appointment I could get). Don't know cause, but using the emergency power button didn't help. Weather was light rain and I had headlights and wipers on. We'll see what it was, I hope...
6 years and 64 PAGES of problems and still no summary.
After reading all 454 gas breakdowns, it seems to be a common occurance to be sensors telling computer to shutdown engine for preservation. My question is which sensors can be bypassed to keep engine running until it is convenient to repair.
1999 Chevy 454, still trying to workout 2 engine shutdowns, NO error codes in the computer, first time after two hours at 55mph, no power coasted to side of road. It restarted after checking all fluids, second time again after two hours of driving but at a traffic light on proceeding into intersection, power was limited, it was running enough to make it though intersection, pulling to side of road, turned of key and restarted, drove last mile to home and parked.
May 14th 2009 Fredricksburg MD , 2000 Damon Challenger Workhorse P32 chassis, 7500 miles, after going through heavy traffic brake pedal went to floor when pushed. Pumping brake pedal gave limited brake action. The pedal felt as though there was a leak in the hydraulic line. Examination by mechanic showed that calipers did not release completely and overheated. Calipers, rotors, hoses, and pads replaced.
