Open Roads Forum
Print  |  Close
Topic: Water heater wont work
Posted By: jonaz on 01/11/04 07:54pm
My travel trailer has a Atwood type water heater (White Rogers control?). It is a 2001 Kiwi trailer, and I bought it used two months ago. I can not get the hot water heater to work. There is no gas getting to the pilot. I have crawled all around the trailer, and underneath, and there appears to be no shutoff valve. I have plenty of gas in my propane tanks, and the heater inside works. Do you think the problem is the actual unit, and that it needs to be replaced?
Any tips on troubleshooting?
2007 Dodge Ram 1500 4x4 5.7 Hemi (3.92 gears)
Prodigy brake controller,Weight Distribution Hitch
2013 Dutchmen Aspen Trail 2710 (4700lbs UVW)
Posted By: ngadeerhunter on 01/11/04 08:12pm
sometimes mine has air in the line. After holding in the knob for some time (assuming it is manual) pilot still wont light? could be debris clogging an orfice
1999 Sunline Solaris 2370
1999 Chevy Silverado 5.3,3.42
Posted By: GACamper on 01/11/04 08:37pm
Loosen the gas line where it connects to the water heater gas valve. If you are getting gas there then you might have a plugged pilot assy. You'll need to take it out and apart and clean out the orifice.
2013 Montana 3800RE
RV FlexArmor sprayed RV roof..Big Improvement!
A/C, Color TV and a Microwave...Isn't Nature Great?
04.5 Dodge Ram 3500 Cummins 5.9L
Posted By: msereno on 01/12/04 11:36am
I have the same problem with the water heater in my Cub. I will first turn the stove burners on for a few seconds to purge any air in the lines. Then when I light the heater I don't have to hold the pilot down as long but it still takes sometimes 30 sec or so. The line to the pilot is very small so I guess it takes a bit to clear of air. Hope that helps.
2007 Nissan Titan SE King Cab 4x4
2007 Salem LE 27RB
Posted By: pmfinnegan2 on 01/12/04 12:43pm
I had the same problem with mine. It turned out what I thought was the pilot wasn't. The pilot was much farther in the unit than I thought. This might be possible in your case as well.
2009 Chevrolet Silverado Crew Cab
5.3L Vortec V8, 4X4
2013 Jayco White Hawk 28DSBH
Equal-i-zer Hitch, Prodigy Brake Controller
Posted By: BLYONS on 01/12/04 03:34pm
My unit has an ignitor switch INSIDE the unit...I thought it was for heat but found out the first time when there was no hot water! Our unit will 'spark' three times before giving you a red indicator letting you know there is no gas getting to the pilot.
Probably not that simple on your rig but worth checking. My switch was below the sink.
Good luck.
2000 Ford Expedition XLT 5.4L pulling
Thor Wanderer 229BHS pulling
2005 Genesis I
Posted By: jonaz on 01/12/04 08:33pm
You were absolutely right! I turned on the stove burner for a few minutes, and I guess that purged the air out of the lines. My wife and I are going to have a much better time camping in Death Valley this weekend, thanks to you.
Thanks for all the other posts. You guys saved me a trip to the dealer.
Posted By: msereno on 01/13/04 01:27pm
Good Deal, Jonaz. Glad that worked for you. Now you can have all the hot water you want!
Print  |  Close
