RV.Net Open Roads Forum: Fifth-Wheels: stopping at wt. stations or state check points
 > stopping at wt. stations or state check points
Fifth-Wheels Related Tips
rancherwesttx
Wichita Falls, Tx
Posted: 01/16/04 08:52am Link  |  Print  |  Notify Moderator
Wondering if trailers and 5th wheelers had regulations about Truck Weigh Stations and State entry check stations. Sometime I see them stopped and others just go right on by. This has always been a worry of mine when I start my new 5ht wheel experience. Rancherwesttx
and more
shepdog29
Janesville, WI
Posted: 01/16/04 08:57am Link  |  Print  |  Notify Moderator
The only time I go into those weigh stations is when it says RV's. If you go into them they get PO'd if your not called in.
Good Sam Life Members
Steve & Linda Sheppard
2003 Windsport 33SL on a Workhorse Chassis 8.1 & Allison
West Highland White Terrier (Named RV)
Delivering MCI Coaches Coast to Coast.
Mortdd
Northern, Ca
Posted: 01/16/04 08:59am Link  |  Print  |  Notify Moderator
In California you are not to go into a state weight station.
I expect each state differs.
D and K
Just the 2 of us now! Unless the grandkids come along.
2003 Everest 312M, 2008 F350 4x4 Off Road Super Duty V10 Dually 4.10 rearend
GoodSam and KOA Member
cruizer
~ U S A ~
Posted: 01/16/04 09:07am Link  |  Print  |  Notify Moderator
What states require an RV to stop at a weigh station ?
If you think knowledge is expensive , think about the price of ignorance .......
rancherwesttx
Wichita Falls, Tx
Posted: 01/16/04 09:12am Link  |  Print  |  Notify Moderator
are there many wt. or state checks that do post RVs to stop????
sneaks
Encinitas CA
Posted: 01/16/04 09:34am Link  |  Print  |  Notify Moderator
Been through almost every state in the lower 48 and have never stopped or been asked to stop at a weight station.
Did stop at an empty one in Washington State and asked if they would kindly weigh me and they did it but as a favor.
Don, Mary, and Sammy the Wonder Dog.
Lazy Daze 23 1/2 TK, sometimes towing a 2005 C-Dory,
5th wheel RV'er 1975 - 2005
fppf
Buffalo, NY, USA
Posted: 01/16/04 10:01am Link  |  Print  |  Notify Moderator
There is not a weigh station out there that is going to get mad at you for stopping.
I have had my wife follow me through with the car when I was bob tail. They just give you a green or wave you throuhg.
If your towing with a pickup you don't need to stop but if useing anything large I would stop.
1997 International 9800 Flat Floor COE
2004 Fleetwood Terry Quantuim AX6 365FLTS
Trailair Air Ride Pin Box with custom Fab auto ride height leveling
Trailer Wire Convertors:
2 wire to 3 wire
3 wire to 2 wire
tibbitts
Norman, OK
Posted: 01/16/04 10:10am Link  |  Print  |  Notify Moderator
I would like to be able to stop for free weighing sometimes if I could do that, but have almost never found it is a good idea. Often the lines extend out far onto the highway shoulder and more vehicles in line just create more of a hazzard. Also I imagine the truck drivers are mostly losing money while waiting in line so I'd feel bad wasting their time.
Maybe if you have a class 8 or something you might have to stop to avoid misunderstandings; have no experience with that.
I have read you can stop in some closed weigh stations and see your weight on the scale, but don't have the list of which states where that applies.
Paul
mowermech
Billings, MT
Posted: 01/16/04 10:18am Link  |  Print  |  Notify Moderator
Generally speaking, weigh stations are for commercial vehicles only. Some inspection stations will want all livestock haulers to stop.
I have seen some weigh stations that have weight limitations ("Anything over XXXXXX must stop", usually 26,000 pounds or more).
I have seen some that require anything over 5 axles to stop.
Just read the signs as you approach the station, and usually they will tell you what is required. Many will say "NO PICKUPS".
CM1, USN (RET)
'94 Dodge 3500 4X2 CTD, 5 speed, 4.10 LS diff., Jacobs Rambrake, 274,000 Miles
'99 Monaco McKenzie 32' triple slide
'95 Tioga 29H Ford-based Class C
Daily driver: '08 Subaru Outback
Towed: '06 Jeep Rubicon Unlimited/Load Trail 16' flatbed
elh0146
Sioux Falls, SD
Posted: 01/16/04 12:07pm Link  |  Print  |  Notify Moderator
If you have an MDT, or larger, truck with which you pull your privately owned RV, you do not need to stop at the weigh stations. That's one of the reasons you'll see almost all privately owned MDT's with something like "Not For Hire," "Private RV Hauler," or some such wording written on the side.
When we were fulltiming, we pulled our fifth wheel with an MDT and never stopped at a weigh station and never had any problems (we had "Not for Hire" written on the side).
