RV.Net Open Roads Forum: Truck Campers: Electric Jacks Maintenance
 > Electric Jacks Maintenance
Backcountry Riders
Anoka, MN, USA
Posted: 03/21/04 06:41pm Link  |  Print  |  Notify Moderator
Has anyone lubed, cleaned, performed any preventive or other maintenance on their electric jacks?
Henry
Jeff3161
Pasco,Washington
Posted: 03/21/04 07:30pm Link  |  Print  |  Notify Moderator
No, the manual says to put a couple drops of oil (3 in 1)in the top where the handle crank goes there is a tiny hole. That is for the happy jack electrics.
Noel
Southern Oregon
Posted: 03/22/04 07:27am Link  |  Print  |  Notify Moderator
Henry:
Do you have HappiJacs or ...........?
Noel
2003 National Dolphin LX 6335, W22, 8.1L
MyPops
Maple Valley, WA, USA
Posted: 03/22/04 08:07am Link  |  Print  |  Notify Moderator
My Happi-Jac owners manual says to run them through full travel a couple times a year to make sure the screw is lubed. Also says to wax the exterior surfaces with a good car wax. I suspect the wax may make the seals slide easier.
2002 2500HD EXT Cab, 8.1/Allison
Northern Lite 10-2000
Jothedog
Valley Mills, TX
Posted: 03/22/04 08:48am Link  |  Print  |  Notify Moderator
I have Happijac 4500's on the front and 4100's on the rear. None of these has a lube hole in the crank handle hole. Anybody have these models and know where to lube? Also, how do you wax the insides of the jacks?
2001 1150 Arctic Fox
2002 1-ton dually w/Duramax diesel and Allison tranny.
Torklift tiedowns and bags, SuperHitch
Mack Daddy
Duvall,WA
Posted: 03/22/04 09:42am Link  |  Print  |  Notify Moderator
I have Happijac 4500 (front) and 4100 (rrear) on my camper.
I had one jack start to bind and it would not fully extend under the weight of the camper. Luckily the camper was already on the truck, so I took it to the dealer. They added a teaspoon of motor oil, ran it through a few cycles, and the problem was resolved. I was told to do this once a year. To do so I have to remove the top cover to the jacks- there is no other hole that I can see which would allow for adding oil. Dealer told me that they used to remove the entire jack and send to the factory for service. Since then the Happijac factory told them that all they do is add oil, so the dealer does the same thing without all the hassle.
I was also told to wax the legs of the jacks once a year. I recently sprayed them with WD40 instead, but will be waxing them before the summer season.
05 Dodge 3500 Laramie QC Cummins 4x4
06 Keystone Cougar 245EFS
Pullrite Superglide
Noel
Southern Oregon
Posted: 03/22/04 10:31am Link  |  Print  |  Notify Moderator
On our 4100/4500 jacks there are two 1/4 inch plastic inserts near the top of each leg. They are tough to get out (maybe a small slotted screwdriver) and they provide two holes to inspect the gears and squirt some oil or white lithium grease inside.
I'm a bit wary of removing the top/motor cover as I am a total loser at mechanics and there is a spring inside which may pop out and get lost or .........?
HappiJac technical service has always been helpful and friendly over the phone.
Aktravler
Valdez, Alaska
Posted: 03/22/04 10:38am Link  |  Print  |  Notify Moderator
That was wax the outside of the jacks, for protection from the elements just like you wax your rig.
One note on using WD40, it will attract dirt.
Never use it on door locks and things you want to repel dirt and grime. Use silicone.
Surfing on Hughes.net/Sprint Aircard
Mine-'02 Ram 3500, CTD DRW
S&S Avalanche 11DBS-Torklift TD's,SH & FG's
His-'03 F350 PSD SRW & Raptor 3612DS TH
Air Hitch -Edge Juice w/Attitude
Gas & Gumption!!!
26' Alweld, 200hp jet & prop
Robert Mitch
Atlantic Canada
Posted: 03/22/04 12:22pm Link  |  Print  |  Notify Moderator
There was a pretty good thread about this about 6 months ago. Every spring I take my top covers off (6 screws). You can take all the gears out and clean them easily. I re-grease all the gears and bushings. However, to lube the long screws you have to do as Noel pointed out above. I use two sharp chisels to remove the small plastic covers. I squirt 30 weight oil on the bevel gear and screw. You can look right in this hole and see in there. It usually makes a mess of oil on the leg pad but this can easily be wiped up. After doing this you may notice quite a difference in the noise level from them.
Robert Mitch
Gulfstream BT Cruiser B-5230
Ford E-350
dixieglider
North Carolina
Posted: 03/22/04 01:01pm Link  |  Print  |  Notify Moderator
I've got Atwood electric jacks on my 96 Lance Camper. Anyone tell me how to service these. It's never been done. I have no info in owners manuel.
N4CKM
