RV.Net Open Roads Forum: Tow Vehicles: Links for Tow Vehicle Info
Search only in Tow Vehicles
 > Links for Tow Vehicle Info
Page of 6
blt2ski
Kirkland, Wa
Posted: 03/31/04 10:20am Link  |  Quote  |  Print  |  Notify Moderator
Found this 34 pg acrobat file on a GM web site a few weeks back, shows and tells how to spec a class 4 and larger truck, for both HP, torque, gearing, ie tranny and axle gears, to do what YOU want your truck to do performance wise. Look it over, I think most of you will find, if you put info to use on your rig, being it a class 1-3, ie half to 1 ton trucks to 12,500 lbs GVWR, you will have a better understanding of what goes into figureing out GCWR ratings to a degree.
GMperformanceguide
Other interesting sites to read gather info.
GM RPO Codes
GM RPO Codes 2
4lo.com
DavidG’s website
Tech Specs from Fords Body Builder Advisory?
BridgestoneFirstone 9% de-rate P rated
Toyo 9% De-Rate
Tire and rim tech
Warped brake myths and truths
Aceleration Formula
Any others?
Marty
* This post was last edited 05/10/04 07:53pm by blt2ski *   View edit history
05 Chev CC D/A LS Dooley
3 Single axle utility trailers
Check RV.Net Blogs at: blog.rv.net
yepitsaCummins
Fairfield, IA, USA
Posted: 04/01/04 12:29pm Link  |  Quote  |  Print  |  Notify Moderator
The 37500 comes from unit conversions.
550ft-lbs/sec = 1Hp
5280 ft/mile
3600 secs/ hr
550*3600/5280=375
Grade is ft rise/100ft run.
375 x 100 = 37,500
Dodge RAM 2500 QC, 4x4, 3.73, 5.9 CTD, 6 sp, towing mirrors, line-x, P. Blue over Silver
Laredo 25 + 4 RL
formerly
Dodge RAM 1500 QC, 4x4, 3.92, 5.7 Hemi
blt2ski
Kirkland, Wa
Posted: 04/14/04 07:28pm Link  |  Quote  |  Print  |  Notify Moderator
New truck manufacture links
Ford Commercial
Navistar
GM Fleet
Freightliner
Chevrolet
Ford
DodgeTrucks
Any others?
Marty
* This post was last edited 04/22/04 07:59pm by blt2ski *   View edit history
blt2ski
Kirkland, Wa
Posted: 04/14/04 07:36pm Link  |  Quote  |  Print  |  Notify Moderator
OEM manufacture links [url=http://www.interstatebatteries.com/estore/default.asp]Interstate Batteries[/url] [url=http://www.coopertire.com/us/en/corporate/default.asp]Cooper Tires[/url] [url=http://www.conti-online.com/generator/www/us/en/continental/transport/general/home/index_en.html]Continental Truck Tires[/url] [url=http://www.bridgestone-firestone.com/]Bridgstone-Firestone[/url] [url=http://us.webmichelin.com/../public/index.cfm?page=HP22&id_site=6&id_langue=9&flash=1]Michelin USA[/url] [url=http://www.michelin.ca]Michelin Canada[/url] [url=http://www.roadranger.com/index.htm]Eaton/Dana/Fuller[/url] [url=http://www.allisontransmission.com/]Allison Transmissions[/url] [url=http://www.ricksontruck.com/]19.5 tires and wheels[/url [url=http://www.toyo.com/]Toyo tires[/url] [url=http://www.yokohamatire.com/]Yokohama tire[/url] [url=http://www.aam.com/index.html/]American Axle Corp[/url] Others? Marty
Note: Due to invalid formatting, all formatting has been ignored.
* This post was last edited 06/15/04 08:19pm by blt2ski *   View edit history
blt2ski
Kirkland, Wa
Posted: 04/14/04 07:56pm Link  |  Quote  |  Print  |  Notify Moderator
Other forums for specific brand info
http://www.dieseltruckresource.com/
http://www.turbodieselregister.com/
TheDieselPage
http://thedieselplace.com
Others?
Marty
* This post was last edited 05/04/04 11:14am by blt2ski *   View edit history
59022
MT
Posted: 11/25/04 02:26pm Link  |  Quote  |  Print  |  Notify Moderator
http://www.rvcentral.com/towcanada.htm
........tp://www.rvcentral.com/towheavyfiver.htm
59022
MT
Posted: 11/25/04 02:28pm Link  |  Quote  |  Print  |  Notify Moderator
Alaska Puller: Try this site http://www.off-road.com/dunes/products/cabriolet/oct_2000/
George
Lifelong tipi, wall tenter/mule packer. 850-ac in Montana.
61 U404, 99 Dodge V10, 79 Airstream www.nativeradio.com
mrnavy2
New Jersey
Posted: 05/05/05 10:12am Link  |  Quote  |  Print  |  Notify Moderator
Marty.. would be nice if we could also fine Links for Ford Trucks.. I have a 1995 Ford Converstion Van, and would like to know all the infomation about the Ford Converstion van. thanks steve....
dba2003
Akron, OH
Posted: 05/13/05 10:16pm Link  |  Quote  |  Print  |  Notify Moderator
Dave G's site is a good starting point. There are links that deal in greater detail.
Here's where to find the best tongue weight information. http://www.sherline.com/lmbook.htm
www.trailerlife.com how tongue weight can be greater than what you know.
There is no easy determination for length. More than 30 items on both the trailer and tow vehicle would need to be considered to find the actual length limitation one could tow. The bottom line is does your vehicle have enough resistance for any wind force the trailer applies.
The best tow vehicle is a pick-up and the best trailer is a fifth wheel or gooseneck. The resisting weight is in the best location, the location of where the force of the trailer is being applied is the best.
Gromit Dog
Nanaimo B.C.
Posted: 07/10/05 12:05am Link  |  Quote  |  Print  |  Notify Moderator
I just looked at the link for..."Warped brake myths and truths"
As a long time auto repair person, doing significant work in the field of brake repair on both cars and RVs, I can say HOOEY!
I have seen a LOT of warped discs. Still proper break in and use of brakes will give you more pulsation free life from them. Use engine brakes, gear down, and don't drive like a cop, and your brakes will last longer. If they warp, you MIGHT be able to turn them once, but replacement is best. make sure the brake tech mounts the rotors on clean rust free hubs too!. I'll get off the soap box and let you get back to the matter at hand. (Sorry)
Looking for a new tow vehicle for a 5000 gvw trailer, I'll use your good info here to help me find one.
Page of 6
