RV.Net Open Roads Forum: Tow Vehicles: Links for Tow Vehicle Info
Search only in Tow Vehicles
 > Links for Tow Vehicle Info
Page of 6
Lost One
Salt Lake
Posted: 10/22/08 09:09pm Link  |  Quote  |  Print  |  Notify Moderator
mtkbuckeye wrote:
Does anyone have a link that will tell you by VIn # what axle ratio one has on a Dodge truck??
It is on the inside of the glove box (Nope I'm not kidding), Look just under the lock on the glove box door and it will be right there. Why they put it there instead of on the door I will never know.
2012 Ford F350 King Ranch CC LB 6.7L
1992 NU-WA Hitchhiker Premier 32' with slide
Q5 Fifth wheel hitch
bluetrailerjockey
new york
Posted: 01/13/09 08:49am Link  |  Quote  |  Print  |  Notify Moderator
I have a dodge durango 2008 5.7 hemi engine 4 wheel drive can anyone tell me how much i can tow. HAVE THE TOW PACKAGE AND TOW/HAUL MODE
ramcneal
Colorado
Posted: 01/29/09 02:11pm Link  |  Quote  |  Print  |  Notify Moderator
Visit this site:
http://www.dodge.com/hostc/towing/guide.do
Select your vehicle and equipment package and it'll tell you.
2008 Keystone Challenger 32RKS
2006 Dodge 2500 Cummins, 6-speed manual, exhaust brake, air bags, Rancho 9000 shocks
DDTee
Ontario, Canada
Posted: 04/22/09 10:06am Link  |  Quote  |  Print  |  Notify Moderator
tpguy1 wrote:
I'm also new:
We bought a 2002, Ram quad cab,short bed, 5.9L, V8, 4x4, book says it has a max trail weight of 8100 lbs.......says GVWR is 6650 lbs., GCWR is 12,500 lbs.
Trailer is a Jayco Flight, 27BH, unloaded vehicle weight is 4950, dry hitch 635, Gross vehicle weight rating 7,500. Does this sound o.k.?
Is there any website that could help me figure it out??
Hello TPguy1... Did you find any information regarding your setup.
I too also have a 26JTX which is the same as the 27BH from a weight and layout standpoint. What tow vehicle did you settle on to tow this trailer??..
Thanks,
Darren
1997 Dodge Ram 1500 2X4, 5.2L V8
2007 Jayco Jay Flight 26JTX
Equalizer & Prodigy
shick2356
Fergus, Ontario
Posted: 05/06/09 01:01pm Link  |  Quote  |  Print  |  Notify Moderator
2008 F250 Lariat
mcewena
Canada
Posted: 06/02/11 07:27am Link  |  Quote  |  Print  |  Notify Moderator
Any recommendations for a single web site that has the towing/payload ratings for the 3 brands of late model 3/4 ton trucks? Failing that, how about a section of the factory sites that deals with prior model years?
Ford's no problem I found a site for them https://www.fleet.ford.com/showroom/rv_trailer_towing/default.aspGM & Dodge it's harder find specifics for the variety of models/trims/years/engines/diffs unless you're looking for the current model year.
I'm looking mostly at 07 thru 10 model years and the main factory sites usually only talk current year (funny how they're ALL "class leading"?)
Thanks,
N7SJN
SE Washington State
Posted: 07/19/11 10:41am Link  |  Quote  |  Print  |  Notify Moderator
I found this ref in my local paper. Beginning 2013 there will be a SAE std for those mfgs that wish to use it. See phelan@freep.com
DW-gray
Lompoc, CA
Posted: 10/31/11 07:51pm Link  |  Quote  |  Print  |  Notify Moderator
Here's another website that has towing guides, online calculators, printable worksheets and safety report for RVers, farmers and ranchers who tow fifth wheel, gooseneck and conventional trailers. You can weigh your vehicle and trailer and print your weight safety report in 4 steps.
Fifth Wheel St.
* This post was last edited 09/30/14 02:24pm by DW-gray *   View edit history
Dave & Amy
08 Dodge Ram 3500 4X4, Dually, 6.7L Diesel, 09 Heartland Cyclone 4012 with smart car in the garage.
mayo30
Up here in the cold,cold north.
Posted: 11/13/11 06:35pm Link  |  Quote  |  Print  |  Notify Moderator
They wanted to be the same place my 2001 1500HD has the information sticker.
notruffinit
Minnesota
Posted: 02/25/12 09:23pm Link  |  Quote  |  Print  |  Notify Moderator
[image][/img]
Got it new today! Gonna pull my Cameo 34SB3. Camping season can't come fast enough here in Minnesota!
'11 Ram 3500 Cummins
'12 Cameo 34SB3
Page of 6
© 2016 CWI, Inc. © 2016 Good Sam Enterprises, LLC. All Rights Reserved. | Terms & Conditions | PRIVACY POLICY | YOUR PRIVACY RIGHTS
