RV.Net Open Roads Forum: Tow Vehicles: Links for Tow Vehicle Info
Search only in Tow Vehicles
 > Links for Tow Vehicle Info
Page of 5
stev in niagara
Niagara Falls
Posted: 07/11/05 10:08am Link  |  Quote  |  Print  |  Notify Moderator
One other OEM tire manufacture for off-road, motor-cross, light duty trucks and RV tires.
www.durotire.com
2000 Dodge B1500 V6 3.9L 3.55 tow 4500 RoadMaster MKII-XF
2001 Dodge B2500 V8 5.2L 3.92 tow 8000 RoadMaster MKII-XXF
Reese AccuPower Pilot Digital Brake Controler
1982 Coachmen Cadet 19-1/2 3000#
Coachmen RV Group groups.msn.com/CoachmenRVers/general.msnw
DIYGuy
TX, NY and all points in between.
Posted: 10/09/05 05:09pm Link  |  Quote  |  Print  |  Notify Moderator
Larry Z's Volvo Conversions:Click Here
Far more economical than you might think.
Full-Timers, Class of 2008
2002 Volvo VNL770 Toter - Optimus Prime
2007 SpaceCraft - Just Weight
Yosemite Sam
San Diego, CA
Posted: 12/14/05 04:12pm Link  |  Quote  |  Print  |  Notify Moderator
Found this for tow ratings for vehicles. Sorry if this is in the wrong place.
http://www.bobstravelcenter.com/02towguide.htm
It's for years 1998-2005.
Still Searchin'
Bend, Oregon
Posted: 01/08/06 11:13am Link  |  Quote  |  Print  |  Notify Moderator
Is there any easy-to-use good spec sites (ie, detailed) that might give type of transmission, GAWR, GCWR, etc., drum or brake shoe size, etc. for say,
the 2000-2006 Suburbans, Tahoes, and GMC Denali models?
I couldn't find the actual transmision info. on either the chevy or gmc manufacture sites, and the GMC site is almost unreadable.
2004 Yukon XL K1500 w/ 5.3L & 3.73 diff.
1989 22ft. Wilderness TT @ 5500# loaded
Member: TTN, Escapees, Good Sam
Just retired, will travel!
wetbehindtheears
WA
Posted: 02/20/06 07:43pm Link  |  Quote  |  Print  |  Notify Moderator
Hey guy's, I am completely new to this RVing stuff (hence the user name)here in the states and I saw the start of the string and thought, these guys have some good stuff to read.
I'm looking for towing data for my 1988 Chevy Silverado Ext Cab. Long Bed,4x4 with Auto and 350ci. Weight data missing from sticker on inside edge of door, and I can't read the Axle ratio on the axle tube either. I've e-mailed Chevy with VIN and hopefully they will help me, but if anyone has any data or useful information on using this Tow Vehicle for a 5th wheel trailer, I would appreciate it very much.
Cheers
Dave "still wet behind the ears"
tpguy1
Illinois
Posted: 02/22/06 06:03pm Link  |  Quote  |  Print  |  Notify Moderator
I'm also new:
We bought a 2002, Ram quad cab,short bed, 5.9L, V8, 4x4, book says it has a max trail weight of 8100 lbs.......says GVWR is 6650 lbs., GCWR is 12,500 lbs.
Trailer is a Jayco Flight, 27BH, unloaded vehicle weight is 4950, dry hitch 635, Gross vehicle weight rating 7,500. Does this sound o.k.?
Is there any website that could help me figure it out??
I sell toilet paper, when business is crappy, I'm happy!
MikeSD
Tennessee
Posted: 04/21/06 01:32pm Link  |  Quote  |  Print  |  Notify Moderator
This is the Ford Truck Enthusiast Forum, which is similar to this one-
Here you will find "all matters Ford". A good forum..
Ford Truck Enthusiast's Forum
2002 Ford F-350 Lariat CC, LB 4x4 7.3L PSD
2006 Jayco JayFlight 27BH
dude64
Titusville, Florida, USA
Posted: 05/02/06 08:47pm Link  |  Quote  |  Print  |  Notify Moderator
We are considering the purchase of a 2006 Honda Odyseey. What are the pros and cons of towing this vehicle. What has to be done to the car to tow it.,i,e.pull fuses, install transmission pump, tec. what brand of hitch plate is the best, how about brakeing systems. Is it hard to wire the lights of the car. Thanks.looking for all the info I can get.
Lynwood Dunn
M.J.M.
Viginia
Posted: 05/09/06 08:56pm Link  |  Quote  |  Print  |  Notify Moderator
blt2ski wrote:
Found this 34 pg acrobat file on a GM web site a few weeks back, shows and tells how to spec a class 4 and larger truck, for both HP, torque, gearing, ie tranny and axle gears, to do what YOU want your truck to do performance wise. Look it over, I think most of you will find, if you put info to use on your rig, being it a class 1-3, ie half to 1 ton trucks to 12,500 lbs GVWR, you will have a better understanding of what goes into figureing out GCWR ratings to a degree.
GMperformanceguide
Other interesting sites to read gather info.
GM RPO Codes
GM RPO Codes 2
4lo.com
DavidG’s website
Tech Specs from Fords Body Builder Advisory?
BridgestoneFirstone 9% de-rate P rated
Toyo 9% De-Rate
Tire and rim tech
Warped brake myths and truths
Aceleration Formula
Any others?
Marty
I have some good tow vehicle info on my site you can check it out at:
www.bigpickup.com
Mike Mas
Dynamax M2 / Sportchasis P2 Pickup 330 hp 1000 ft lbs. Mercedes-Benz
mail@rotory.com
web: www.bigpickup.com
Desert Fisherman
Fort Mohave, Arizona
Posted: 05/20/06 02:27pm Link  |  Quote  |  Print  |  Notify Moderator
For official Dodge towing/hauling ratings, go here:
Dodge Towing/Hauling
One beautiful wife
'91 3/4 ton Chevy Silverado 454, '94 Lance Lite 195, '99 Fisher 18' fishing boat, Polaris Sportsman 500 quad.
Page of 5
