bar425
Oxford, MI
Moved from Fifth Wheels
I was getting ready for a spring trip and cleaning all the winter grime off the awning and found a hole. Looks like maybe a spark from one of the last campfires burned a small one half inch diameter hole thru the vinyl. Any ideas how to repair the hole? I sure wouldn't want to replace the awning as it is only one year old, but would like to fix it so I don't have the rain dripping in.
Hope you guys or ladies have some good ideas.
ron
edited 04/04/04 08:24am by an administrator/moderator *
2004 Dodge Ram 2500HD 4x4
Cummins H.O. (the beast)
2005 Cardinal 30TS
Prodigy Brake Controller
LetsRV
Portland, OR.
Vinyl tape...
You can get it at auto repair shops in many colors. I fixed a tear (about three inches) in an awning with it. Blended right in and was never a problem.
Good Luck
We are all good at something.....
I just happen to be a good bad example.
Occasionally in error but never in doubt.
nelson
Clio,Mi USA
Contact Cement and two small peace of vinyl, One peace for each side. Should last a long time
2002 Damon Challenger 348 Ford V10
Blue Ox Auto Stop and Aventa II Tow Bar
2001 Ford Sport Trac with Remco Driveshaft Disconnect
jwmII
out west
awning manufacturers offer repair kits with material and all needed items to patch a vinyl awning. There are assorted colors available. Jack.
Outbound
Eastern WA USA
Don't have any holes in mine (yet) but this info is good to know. Never really thought about it either. Thats what I like about this forum. Full of information.
Wil
Motorhome
1 dog
bar425
Oxford, MI
Thanks to all for the good suggestions. I'll make sure to have a repair kit with me from now on.
ron
patnchris
Gurnee, Il. USA
They may vinyl repair kits that come with color mixing kits. These kits contain a clear liquid that you mix colors with, to get it to match. Then a "heating iron" to cure the compound. They work quite well for holes, but don't do much for tears....Pat
Patrick and Christine
and Maggie May, the cocker spaniel
1995 Damon Ultrasport 3470
Rallies Attended "15"
macdavis
Clovis, CA, USA
Haven't had a hole yet, but we did have a weak or thin area caused by opening the screen door with the awning out... or maybe by the wheel on the door on a really hot day, not sure..
We used a repair kit from an air mattress (the fabric kind, not thin, slippery plastic) to reinforce it on the wheel area, just in case..
Mac Davis - Clovis, California
99 Dodge Ram, Quad Cab, 360/auto/3.55 - 26' 2003 Tahoe 26GT Travel Trailer
